pinch turn
Camdude®
i am curious about pinch turn apps. My main question is:
do you set your turrets to cut at the same "X" value or do you stagger the x value so one side cuts at a certain depth and the other tool cuts deeper. the theory being that the first tool is removing a radial value.
Or:
do you leave the value the same and double the feed rate?
You do stagger the X......You also have the shallower X turret lead in Z........
The two turrets remove the same amount of material.......example.......upper turret removes .100......lower turret follows the upper turret about .100 behind and removes an additional .100 making a total of .200 per pass.....
How big are the parts.......?????
Old boss here made us do it to a family of parts that had a head diameter of 2.5 and a shank diameter of 1.0 .......the parts were between 3 and 4 inches long........quantity of the lots were low... between 10 and 15 parts........no major time save to do the pinch turn on them smaller parts.......Longer length parts I'm sure would save some time........
You don't have to trail one of the turrets either because they are opposed 180. One tool is 1/2 turn behind.
Makes sense James.........But our Okuma guys are telling us we have to stagger the turrets.....not sure why.....I think in the operator/programming book it says the same....Maybe turret interference when diameters get smaller..... headscratch.gif
The control can sync the turrets no problems, You can stagger or have parralel turrets for balanced cutting I do it all the time. What machine/control do you have? Are you using LAP3 or LAP4 cycles.
Below is a LAP4 sample from a Macturn
N0001 G13
N0002 G140
N0003 P0010
N0004 M216
N0005 G20 HP=4
N0006 G50 S2500
N0013 G13
N0014 G141
N0100 G13
N0101 G140
NA001
N0102 MT=00101
N0103 M321
N0104 VLMON[2]=10
N0105 G97 S696 M41 M04 P0020
N0106 G20 HP=4
N0107 TL=001001 BA=45 M603
N0108 G00 X128
N0109 Z5.4
N0110 G96 G110 S280 P0030
N0111 G85 NL001 D5 F1.4 M85 P0040
NL001 G83
N0112 G01 X20.4 Z0.2
N0113 X120
N0114 Z-76.2
N0115 G81
N0116 G00 X18.703 Z0.932 G42
N0117 G01 X24.4 Z-1.917 E1.4
N0118 Z-25.8
N0119 X58.1 E2.1
N0120 Z-49.8 E1.4
N0121 X76.2 E2.1
N0122 Z-69.8 E1.4
N0123 X100 E2.1
N0124 G03 X110.4 Z-75 K-5.2 E1.4
N0125 G01 Z-78
N0126 X122.4 E2.1
N0127 G40
N0128 G80
N0129 G00 X128
N0130 VLMON[2]=0
N0131 G97 S696 P0050
N0132 G20 HP=4
N0133 P0070
N0234 G13
N0235 P0090
N0238 G13
N0239 P0130
N0243 G13
N0244 G140
N0245 M215
N0007 G14
N0008 G140
N0009 P0010
N0010 M216
N0011 G00 X800 Z400
N0012 G50 S2500
N0015 G14
N0016 G140
N0200 G14
N0201 G140
NB001
N0202 VLMON[1]=10
N0203 G97 S696 M41 M04 P0020
N0204 G00 Z6 T001001
N0205 X128
N0206 Z5.4
N0207 G96 G110 S280 P0030
N0208 G85 NL002 D5 F1.4 M85 P0040
NL002 G83
N0209 G01 X20.4 Z0.2
N0210 X120
N0211 Z-76.2
N0212 G81
N0213 G00 X18.703 Z0.932 G42
N0214 G01 X24.4 Z-1.917 E1.4
N0215 Z-25.8
N0216 X58.1 E2.1
N0217 Z-49.8 E1.4
N0218 X76.2 E2.1
N0219 Z-69.8 E1.4
N0220 X100 E2.1
N0221 G03 X110.4 Z-75 K-5.2 E1.4
N0222 G01 Z-78
N0223 X122.4 E2.1
N0224 G40
N0225 G80
N0226 G00 X128
N0227 VLMON[1]=0
N0228 G97 S696 P0050
N0229 Z6
N0230 X800
N0231 X800 Z400 T001000
N0232 M05 P0060
N0233 M01 P0080
N0236 G14
N0237 P0090
N0240 G14
N0241 P0130
N0242 M215
N0246 G14
N0247 G140
N0248 M02
thanks for the input we have a twin spindle here and but nobodies tried it yet so iam going to give it a go.
Camdude, these guys are talking about balanced turning. Multiple turrets cutting at the same time on one bar.
Now you mention twin spindles. Are you wanting to pull turn (similar to swiss)? or balance turn?
I have done both fairly successfully.
Stagger .02 if you want to rough/finish, and don't stagger if you want to balance turn a long shaft.
My $.02
This one should work on an LU
0001 G13
N0002 P0010
N0003 G00 X800 Z1000
N0004 G50 S2000
N0100 G13
NAT01
N0101 G97 S884 M42 M03 M08 P0030
N0102 G00 X108 Z4 T010101
N0103 G96 G110 S300 P0040
N0104 G85 N0105 D3 F0.8 U0.4 W0.2 P0050
N0105 G81
N0106 G00 X35
N0107 G01 Z0 G42 E0.8 P0010
N0108 Z-30 P0020
N0109 G02 X45 Z-35 I5 P0030
N0110 G01 X56 E1.2 P0040
N0111 X60 Z-37 E0.8 P0050
N0112 Z-60 P0060
N0113 X100 E1.2 P0070
N0114 G40
N0115 G80
N0116 G97 S884 P0060
N0117 G00 X800 Z1000 T0100
N0118 M05 M09 P0070
N0005 G14
N0006 P0020
N0007 G00 X800 Z1000
N0008 G50 S2000
N0200 G14
NBT01
N0201 G97 S884 M42 M03 M08 P0030
N0202 G00 X108 Z4 T010101
N0203 G96 G110 S300 P0040
N0204 G85 N0205 D3 F0.8 U0.4 W0.2 P0050
N0205 G81
N0206 G00 X35
N0207 G01 Z0 G42 E0.8 P0010
N0208 Z-30 P0020
N0209 G02 X45 Z-35 I5 P0030
N0210 G01 X56 E1.2 P0040
N0211 X60 Z-37 E0.8 P0050
N0212 Z-60 P0060
N0213 X100 E1.2 P0070
N0214 G40
N0215 G80
N0216 G97 S884 P0060
N0217 G00 X800 Z1000 T0100
N0218 M05 M09 P0070
N0219 M02
Makes this
