CNC machine errors NUM 1040
mcuser99
I'm trying to cut a 3D star with a CNC Router. The toolpath is a Surface Rough Parallel. The router has a proprietery format for its native software, which we do have a post for. Any file over 95kb will not load into the memory, we have to use the dripfeed mode. Problem is, the NUM 1040 control is a b*&ch when it comes to complex code. It runs slow, or stops at every change in Z, or spits out circular errors.. I've been experimenting with the control definition, trying to find the right settings that will work. There are settings that work great at first, then it will stop in the middle of nowhere with errors. The manual says to use IJ for > 180 degrees, but I've tried a dozen combinations of arc settings with little succes. Can someone shed some light on what settings to use for the NUM 1040?
What I don't understand about Mastercam's tolerance filter is this:
- - - - - - - - - - - - - - - - NC File Size
min arc size 0.1mm - - - - 1500kb
min arc size 1mm - - - - - 800kb
Shouldn't the code get bigger if there are less arcs?
What I'm thinking is maybe trying to eliminate most of the arcs so i don't run into arc errors.
I would have thought that the arc filter reduces
size?
You can have what looks like a simple arc that is
actuall a polyline or spline made up of lines or arcs.
It its an arc 'like' spline made up of many arc
it should join them so it analyzes as 1 arc,
thus smaller code file. If I am not mistaken.
It is a BIMA 310 Router from IMA (Germany).
The software is IMAWOP. But, I am not outputting to IMAWOP format with this part (too big). I'm generating gcode from Mastercam. Then drip-feed direct to the control by serial port from the CNC's Windows 2000 PC interface.
Rickster, that was my understanding of arc filtering. Perhaps the part shape causes the strange size. Anyway, it doesn't fix the control problems. I still get slowwwww cutting, or freezing with circular errors.
I programmed two connecting helical arcs in IMAWOP.
1st ARC: CW R400 X0 Y0 Z35 to X500 Y100 Z10
2nd Arc: CCW R10 X500 Y100 to X650 Y365 Z75
This is the g-code output:
G02 X500 Y100 Z10 R400
G03 X650 Y365 Z75 I575 J232.5
Does this look familiar? Its native code, runs fast (20m/min) with no errors. Why does it choke on Mastercam's g-code?
This is Mastercam g-code (with drip-feed post) for the exact same toolpath as above:
G94 G17 G02 G90 X500. Y100. Z35. I310.447 J-252.235 F20000.
G01X505.777Y97.183Z32.673
X511.693Y94.632Z30.39
X517.738Y92.354Z28.154
X523.898Y90.352Z25.971
X530.161Y88.63Z23.844
X536.516Y87.192Z21.777
X542.95Y86.041Z19.776
X549.45Y85.179Z17.843
X556.002Y84.607Z15.983
X562.595Y84.327Z14.2
X569.215Y84.34Z12.496
X575.848Y84.645Z10.875
X582.482Y85.241Z9.341
X589.104Y86.128Z7.897
X595.701Y87.304Z6.544
X602.258Y88.766Z5.287
X608.765Y90.512Z4.127
X615.206Y92.538Z3.067
X621.571Y94.84Z2.109
X627.845Y97.414Z1.255
X634.017Y100.253Z.506
X640.075Y103.354Z-.136
X646.007Y106.71Z-.669
X651.8Y110.313Z-1.094
X657.443Y114.157Z-1.408
X662.925Y118.235Z-1.611
X668.236Y122.537Z-1.703
X673.364Y127.056Z-1.684
X678.3Y131.783Z-1.554
X683.033Y136.709Z-1.312
X687.555Y141.822Z-.96
X691.857Y147.115Z-.498
X695.929Y152.575Z.073
X699.764Y158.192Z.752
X703.354Y163.956Z1.537
X706.693Y169.853Z2.427
X709.773Y175.874Z3.421
X712.588Y182.006Z4.515
X715.133Y188.237Z5.709
X717.403Y194.554Z6.999
X719.393Y200.945Z8.384
X721.1Y207.397Z9.86
X722.52Y213.898Z11.424
X723.649Y220.434Z13.074
X724.487Y226.994Z14.805
X725.031Y233.562Z16.616
X725.28Y240.128Z18.501
X725.233Y246.677Z20.458
X724.892Y253.197Z22.482
X724.256Y259.675Z24.57
X723.327Y266.097Z26.716
X722.106Y272.452Z28.918
X720.596Y278.727Z31.171
X718.8Y284.908Z33.47
X716.722Y290.985Z35.811
X714.365Y296.944Z38.188
X711.735Y302.775Z40.598
X708.836Y308.465Z43.035
X705.674Y314.004Z45.496
X702.256Y319.38Z47.974
X698.588Y324.582Z50.465
X694.678Y329.601Z52.964
X690.533Y334.426Z55.466
X686.162Y339.048Z57.966
X681.572Y343.458Z60.459
X676.775Y347.646Z62.94
X671.777Y351.606Z65.405
X666.591Y355.328Z67.848
X661.225Y358.806Z70.265
X655.691Y362.032Z72.65
X650.Y365.Z75.
2 senarios would create point to point machining on arcs
1- splines in place of arcs ( you eliminated that by creating arcs )
2- "Filter" is not being used at all ( under "Lead in/out" )
You want to have "Create arcs in XY" checked on
and you also need the Machine Definition file to have "arcs in XY" enabled
