HS Questions, Smotthing + Lead in/outs?
DavidB
With smothing in HS Are Clearance toolpath.
I want the tool to do an arc in the 90 degree areas in X,Y.
I would have thought this would put a max rad of 22mm in the 90 degree corners?
This is a pic of backplot, I want a bigger arc in the 90 degree corners, yes this will leave extra material. I will take corners out later.
I don't like the small rad in the corners!!
Also in the following rest cut to clear corners the lead IN/OUT arcs are Vertical which will rub on the vertical walls. eek.gif
I tried taking the Vertiacl links out and had only Horizontal leads
Hi Chris that's only the smoothing tolerance it wont put a 22m rad into the corners.
From MC help on smothing "Max rad"
Max radius
Enter the radius of the largest arc that you will allow Mastercam to insert to replace a corner. Larger arcs will result in a smoother toolpath, but with greater deviation from the originally programmed toolpath.
