Custom drill drill cycle question.
neurosis
I have been making a probing cycle for dialing in a bore and resetting the fixture offset x and y locations. I have been using Ron Branch's example to help me through ( all I can say about that probing code is WOW! Good job Ron!) and its been a tremendous help. I am not doing anything even close to as complicated but there is one thing that I cant figure out.
My code needs to look like this.
G320 D.75 K-.5 E.25 W101 A1. B0.
where the A is the X location from wcs 0 and the B is the y location from wcs 0.
I need these to be forced but instead of an X and Y value they need to be A and B. I have been using pfxout and pfyout to get the values but dont know how to change the format from X and Y to A and B.
This is really easy. Above the probing cycle make the pfxout and pfyout equal to a variable you define. That variable will then be the one you define in the define section of what I set-up for your probing to be portable to other posts down the road.
Here is where I would add this:
# Probe Shared Index deg Format Statements
fmt H 2 feattoler #Tolerance of Feature being Measured
fmt M 2 trueposzone #True Position Tolerenance Zone
fmt B 2 cangtoler #C axis Tolerance for C-Axis Align Cycle
fmt Q 2 covertrav #C Axis Overtravel for Probe Amount
fmt 2 drl_prm1$ #Tolerance Vaule for Repeat Loop in Post
fmt W 4 drl_prm2$ #Print Variable for Increment or Reset
fmt 4 drl_prm6$ #GOTO statement Number to use
fmt A 2 nueraaxis #A axis output for Probing Cycle #<---- Added 6-23-10
fmt B 2 nuerbaxis #B axis output for probing Cycle #<---- Added 6-23-10
Then just do this above the probing cycle you are using:
      if drillcyc$ = 10, #Bore/Boss B0/B90/B180
pdrlcommonb
pfxout = nueraaxis #<---- Added 6-23-10
pfyout = nuerbaxis #<---- Added 6-23-10
if babs = 180,
pbld, n$, *strg659810, *prnrefht, e$
pbld, n$, *strg659814, diedwell, nuerbaxis, nuerbaxis, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if feattoler > 0, *feattoler], e$
pcom_movea
That should do what you are after.
Um. No.
You're not going to get anywhere trying to set a postblock call = a variable.
Easiest solution (without having any idea what the logic in your post looks like) would be to use the nwadrs() function to change the address character of xabs and yabs for output and then to change them back.
To do this you will need four string variables for X,Y, A and B.
i.e.
strX : "X"
strY : "Y"
strA : "A"
strB : "B"
Then in your drilling postblock where you are calling pfxout and pfyout you need to add
result = nwadrs(strA, xabs) #Change address character to A
result = nwadrs(strB, yabs) #Change address character to B
...then the output line where pfxout and pfyout
result = nwadrs(strX, xabs) #Change address character back to X
result = nwadrs(strY, yabs) #Change address character back to Y
Ok,
I think that I have it.. Does this look correct?
      if drillcyc$ = 9, #Probe bore diameter or boss and reset fixture offset
pdrlcommonb
pbld, n$, prorefht, e$
pbld, n$, "G320", diadwell, zbossdep, [if proappr > 0, *proappr], [if wcsupdate > 0,*wcsupdate] pfxout, pfyout, e$
pbld, n$, "G0", *proinitht, e$
pcom_movea
It appears to work.
I did notice one thing that needs addressed. The values of A and B are supposed to be the incremental value of the distance from the location that you are probing, "back" to the ucs x0 y0. Is there a way to change those values from pos to neg and vice versa?
[ 06-23-2010, 01:47 PM: Message edited by: Neurosis ]
Try this:
pdrlcommonb
sav_absinc = absinc$, absinc$ = 1 #Force incremental output
result = nwadrs(strA, xinc) #Change address character to A
result = nwadrs(strB, yinc) #Change address character to B
result = nwadrs(strX, xinc) #Change address character back to X
result = nwadrs(strY, yinc) #Change address character back to Y
absinc$ = sav_absinc
pcom_movea
sav_absinc should already exist in your post, if it doesn't you will need to add an initialization for it:
sav_absinc : 0 #Saved absinc value
Yes, sav_absinc : 0 already exists in the post.
I added what you showed above and got some strange results. I'll post the code just to make sure i didnt botch it somewhere.
pdrlcommonb
pcom_movea
It doesnt output the location of the hole that it is dialing in now. It outputs an X0. Y0. instead of the A and B values.
G00 G20 G49 G40 G80 G90 G53 Z0.
N1 T1 M06 (SPINDLE PROBE)
G00 G17 G90 G54
X1. Y0. S0 M05
G43 H1 Z3.
G94
Z.1
G320 D.75 K-.5 E.25 W101 X0. Y0.
G0 Z3.
G80
G90 G53 Z0.
M160
M30
Figures... biggrin.gif That little code is hard to read on my web browser. (grin)
The output still gives me an A0. B0. I assume that is because the location is called up prior to the probing code?
G00 G17 G90 G54
X1. Y0. S0 M05 <----
so the incremental value from there to itself is 0.?
And is my thinking right here? The incremental value from the wcs origin to the probed hole location will still be a positive number whether absolute "or" incremental?
These values must be converted to negative numbers like as for I's and J's of an arc (distance from the start location back to the center)
Just to be clear, If the output is A1.0 B1.0 now, It needs to be A-1.0 B-1.0. If it were already A-1.0 and B-1.0, it would need to be A1.0 B1.0.
From the book,
The A and B values are the distance and direction from the present probing position to the workpiece zero point.
I still think somewhere you are going to have to store there values from the zabs and xabs and then call them up. Drilling cycles do weird things with X, Y, and Z when you start changing the way they are called.
I tried this and it worked perfectly so not sure why, but here is what I got when I changed my post to like this.
# Probe Shared Index deg Varabiles
offupdate = peckclr$
trueposzone = peck2$
cangtoler = peck1$
covertrav = peck2$
feattoler = peck1$
nueraaxis = zabs #<---- Added 6-23-10
nuerbaxis = yabs #<---- Added 6-23-10
pdrlcst$ #Custom drill cycles 8 - 19 (user option)
#Use this postblock to customize drilling cycles 8 - 19
if drillcyc$ = 8, #XYZ Single Surface Measure B0/B90/B180
pdrlcommonb
if babs = 180,
pbld, n$, *strg659610, prorefht, e$
pbld, n$, *strg659611, *nuerbaxis, *nueraaxis, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if feattoler > 0, *feattoler], e$
pbld, n$, *strg659610, *prorefht, e$
if babs = 90,
if babs = 0,
pbld, n$, *strg659810, prnrefht, e$
pbld, n$, *strg659811, *nuerbaxis, *nueraaxis, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if feattoler > 0, *feattoler], e$
pcom_movea
Here is the posted code:
(TIME         - 11:47 AM)
(PROGRAM REV - N/C)
(POST LICENSE - V&M PRECISION)
(T31 | 1/16 DRILL | EIA SUFFIX - .00 | MAZATROL SUFFIX - .00)
(TOOL DIAMETER PROGRAMMED - .0625 | TOOL RADIUS PROGRAMMED - 0.)
G20 G49 G69 G80 G40 G17 G90 G94
M205
N1
(CUST 9.....)
(WCS NAME - TOP)
(CPLANE NAME - CORRECT BACK)
(TOOLPATH GROUP - E1066100)
G20 G10.9 X0
G91 G30 P3 X0.
G30 P3 Z0.
T31.00 T31 M6
G91 G30 P3 X0. Z0.
G90
M200
M212
G94 G0 G54.1 P1 C0.
M108
G0 B90.
M107
G97 S6000 M03
G68 X0. Y0. Z0. I0. J1. K0. R90.
G0 H31
X4.07 Z2.
Y-1.05
G65P9610 X1.1
G65P9611 B-1.05 A-1.6973 M.015 H.1
G65P9610 X1.1
G69
G91 G30 P3 X0.
G30 P3 Z0. M05
G90
M01
G30 P3 Y0.
M30
Like i said I am a hack, but it gets the job done in a simple way I can understand. This example if for our Integrex you will have to change for your machine. headscratch.gifheadscratch.gif
Ah, then you do not need the incremental value, you need the absolute value inverted. In that case, I would format two new variables for output:
fmt  X  2   probe_x     #Probe X position output
fmt Y 2 probe_y #Probe Y position output
and then use this in the postblock:
pdrlcommonb
probe_x = xabs * -1, probe_y = yabs * -1 #Probe values are from current location back to origin
pbld, n$, "G320", diadwell, zbossdep, [if proappr > 0, *proappr], [if wcsupdate > 0,*wcsupdate] *probe_x, *probe_y, e$
pcom_movea
Here you go:
# Macro Variables as I need them for Probing using Drill Cycles
sequal "=" #Equal Sign
spound "#" #Pound Sign
sminus "-" #Minus Sign
sadd "+" #Addition Sign
sdivide "/" #Division Sign
smultiply "*" #Multiply Sign
seq EQ #Equal Call
sne NE #Not Equal To Call
sgt GT #Greater Than to Call
slt LT #Less Than Call
sge GE #Is Great than or Equal to Call
sle LE #Is Less than or Equal to Call
sin SIN #Sine Math
scos COS #Cosine Math
stan TAN #Tangent Math
satan ATAN #ArcTangent Math
scos ACOS #ArcCosine Math
sqrt SQRT #Sqaure Root Math
sabs ABS #Absoulte Value
sbin BIN #Bin
sbcd BCD #Bcd
sround ROUND #Round to the Nearest Whole Number
sfix FIX #Use for Cutting away any Decimal Numbers
sfup FUP #Counting Decimal Digits as one's
sln LN #Natural Logarithm
sexp EXP #Exponent
sbracketopen "[" #Open Bracket
sbracketclose "]" #Close Bracket
sif IF #If Call
sgoto GOTO #Goto Call
swhile WHILE #While Call
sdo DO #Do Call
sor OR #Or Call
sand AND #And Call
smod MOD #Surplus Math
sdprint DPRNT #Data Output in from Probing Cycles
sfeature FEATURE #Comments for Probing of Features
sm100 100 #Macro Varaible 100 for Spindle Tranfer Operation
sm150 150 #Macro Variable 150 for Math Functions in C Axis Aling Macro
sm151 151 #Macro Variable 151 for Math Functions in C Axis Aling Macro
sm152 152 #Macro Variable 152 Math Functions in C Axis Aling Macro
sm5021 5021 #Machine Postion X Axis Variable
sm5022 5022 #Machine Postion Y Axis Variable
sm5023 5023 #Machine Postion Z Axis Variable
sm5024 5024 #Machine Postion B Axis Variable
sm5025 5025 #Machine Postion C Axis Varaible for Main Spindle
sm5221 5221 #Workoffset Machine Postion X Axis Variable
sm5222 5222 #Workoffset Machine Postion Y Axis Variable
sm5223 5223 #Workoffset Machine Postion Z Axis Variable
sm5224 5224 #Workoffset Machine Postion B Axis Variable
sm5225 5225 #Workoffset Machine Postion C Axis Varaible for Main Spindle
# Probing String Varaibles Put here to keep post cleaner
strg659730 "G65P9730" #Printing Macro Call
strg659732 "G65P9732" #Offset Update Macro
strg659810 "G65P9810" #Probe Protect Cycle
strg659811 "G65P9811" #XYZ Single Surface Measure
strg659812 "G65P9812" #Web / Pocket Measure
strg659814 "G65P9814" #Bore / Boss
strg659815 "G65P9815" #Internal Corner
strg659816 "G65P9816" #External Corner
strg659817 "G65P9817" #4th Axis X measure - Horiziontal
strg659818 "G65P9818" #4th Axis Y Measure - Horiziontal
strg659819 "G65P9819" #Bore / Boss on PCD
strg659820 "G65P9820" #Stock Allowance Measure
strg659821 "G65P9821" #Angle Single Surface Measure
strg659822 "G65P9822" #Angle Web / Pocket Measure
strg659823 "G65P9823" #3-Point Bore / Boss Measure
strg659834 "G65P9834" #Feature to Feature Measure
# Probe Format Statements
fmt Z 2 prorefht #Z Rapid Position for Rapid
fmt Z 2 prnrefht #Z clearence for Protect Cycle
fmt Z 2 zbossdep #Z Position for Probing
fmt D 2 diadwell #P9614 Bore/Boss Measurement Dia call out
fmt C 2 pcddia #P9819 Bolt Circle Diameter for Measurement
fmt K 2 zpcddep #P9819 Z Depth if doing Bores for a Bolt Circle Measurement
fmt R 2 radclear #Radius Clearance Postive for Od and Negative for Id
fmt S 4 offupdate #Used to Fixture Offsets
fmt Y 2 cyspan #Used for Across Distance
fmt H 2 feattol #Tolerance of Feature being Measured
fmt T 4 toolupdate #Used for Updating Tool Offsets
fmt B 2 corn_angtoler#Angle Tolerance for Internal Corner if not 90 deg corner
fmt X 2 drl_prm2$ #Size to Measure for P9812 Cycle X axis
fmt Y 2 drl_prm3$ #Size to Measure for P9812 Cycel Y axis
fmt W 4 drl_prm10$ #Print Variable for Increment or Reset
fmt X 2 xsinsurf #Single Surface for X
fmt Y 2 ysinsurf #Single Surface for Y
fmt Z 2 zsinsurf #Single Surface for Z
fmt Z 2 zcorn #Corner Probing for Z
fmt X 2 xcorn #Corner Probing for X
fmt Y 2 ycorn #Corner Probing for Y
fmt I 2 icorn #Corner Probing for I
fmt J 2 jcorn #Corner Probing for J
fmt 2 xdcorn #Move amount for Corner Cycles
fmt 2 ydcorn #Move amount for Corner Cycles
fmt A 2 apcdang #Angle for 1st Hole on PCd P9819 Measure Cycle
fmt H 2 pcdholtol #Tolerance for Holes in Bolt Hole Circle
# Probe Varabiles Defined to Use with Drill Cycles
prorefht = refht$ #Z Rapid Position for Rapid
prnrefht = tosz$ #Z Clearence for Protect Cycle
diadwell = dwell$ #P9814 Bore/Boss Measurement Dia call out
radclear = retr$ #P9814 Bore/Boss R Postive or Negative for clearance on Boss use Postive on Bore Use Negtive
feattol = shftdrl$ #P9811 Single Surface Measure Toleracne of Surface you are Measuring
zbossdep = depth$ #P9814 Bore/Boss Section Default to Boss use 1 to Make it A Bore Measure Cycle
zpcddep = depth$ #P9819 Bolt Circle Measurement Depth for Id Measurement
zsinsurf = depth$ #P9811 Z Axis Single Surface Use
zcorn = depth$ #P9815 Z Axis Corner Probing
cyspan = dwell$ #Used for Across Distance
jcorn = dwell$ #Used for Internal Corner
icorn = retr$ #Used for Internal Corner
offupdate = peckclr$ #Used to Update Workoffsets if no Vaule is Used Nothing is Posted Out
trueposzone = peck2$ #Used for True Position Callout if no Vaule is Used Nothing is Posted Out
toolupdate = peck1$ #Used for Tooloffset Update to a Known Feature if No Value is Used Nothing is Posted Out
cangtoler = peck1$ #Used for C Axis Tolance in 4th Axis Measurements
corn_angtoler = peck1$ #Used for Internal Corner Angle Tolance
covertrav = peck2$ #Used for C Axis Overtravel Adjustment and setting in Cycle
pcddia = peck1$ #Used for Bolt Hole Circle on PCD P9819 Cycle
apcdang = drl_prm1$ #Used for Angle of 1st Hole on PCD P9819 Cycle
xdcorn = drl_prm2$ #Used for Distance of Safe Position in X for Corner Cycles
ydcorn = drl_prm3$ #Used for Distance of Safe Position in Y for Corner Cycles
pdrlcommonb
if drl_prm2$ <> 0 & drl_prm3$ = 0, #X Axis Single Surface Probing
xsinsurf = (xout + drl_prm2$)
pbld, n$, *strg659810, *xsinsurf, e$
pbld, n$, *strg659810, *prorefht, e$
pbld, n$, *strg659810, *zsinsurf, e$
pbld, n$, *strg659811, *xout, [if offupdate > 0,*offupdate], [if feattol, *feattol],
[if trueposzone > 0, *trueposzone], [if toolupdate > 0, *toolupdate], [if drl_prm10$ > 0, *drl_prm10$], e$
if drl_prm9$ = 1,
spaces$ = 0
"#135=#120(STORE 1ST Z PLANE HIT)", e$
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[", sopcomment, "]", e$
sdprint, "[X*AXIS*SINGLE*SURFACE*PROBING*]", e$
sdprint, "[","*X*#135[24]*ERROR*#140[24]*]", e$
sdprint, "[","*Y*#136[24]*ERROR*#141[24]*]", e$
sdprint, "[","Z*POSITION*IS*#137[24]*Z*ERROR*IS*#142[24]]", e$
sdprint, "[","SIZE*OF*FEATURE*IS*#138[24]*ERROR*IS*#143][24]", e$
sdprint, "[","*TRUE*POSITION*ERROR*#145[24]*]", e$
sdprint, "[","-------------------------------------------","]", e$
"PCLOS", e$
spaces$ = 1
if drl_prm3$ <> 0 & drl_prm2$ = 0, #Y Axis Single Surface Probing
ysinsurf = (yout + drl_prm3$)
pbld, n$, *strg659810, *ysinsurf, e$
pbld, n$, *strg659811, *yout, [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[Y*AXIS*SINGLE*SURFACE*PROBING*]", e$
sdprint, "[","*Y*#136[24]*ERROR*#141[24]*]",e$
sdprint, "[","Z*POSITION*IS*#137[24]*Z*ERROR*IS*#142[24]*]", e$
sdprint, "[","SIZE*OF*FEATURE*IS*#138[24]*ERROR*IS*#143[24]*]", e$
"PCLOS", e$
spaces$ = 1
if drl_prm2$ = 0 & drl_prm3$ = 0, #Z Axis Single Surface Probing
pbld, n$, *strg659811, *zsinsurf, [if offupdate > 0,*offupdate], [if feattol, *feattol],
pbld, n$, *strg659810, *prorefht, e$,
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[Z*AXIS*SINGLE*SURFACE*PROBING*]", e$
"PCLOS", e$
spaces$ = 1
pcom_movea
if drillcyc$ = 9, #Web/Pocket Measure
pdrlcommonb
pbld, n$, *strg659812,[if drl_prm2$ > 0, *drl_prm2$],[if drl_prm3$, *drl_prm3$],[if dwell$ = zero, *zbossdep],[if dwell$ = 1,[if radclear, *radclear]],
[if feattol, *feattol],[if offupdate, *offupdate],[if trueposzone, *trueposzone],[if toolupdate, *toolupdate],[if drl_prm10$, *drl_prm10$],e$
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[","Z*POSITION*IS",*zbossdep,"]", e$
"PCLOS", e$
spaces$ = 1
pcom_movea
pdrlcommonb
pbld, n$, *strg659814, *diadwell, [if shftdrl$ = zero, *zbossdep], [if radclear, *radclear], [if offupdate > 0,*offupdate],
if drl_prm10$,
spaces$ = 0
"POPEN", e$
#sdprint, "[","Z*POSITION*IS",*zbossdep,"]", e$
sdprint, "[","*DIA*#138[24]*ERROR*#143[24]*]", e$
"PCLOS", e$
spaces$ = 1
pbld, n$, *sg00, *zabs, e$
pcom_movea
if drillcyc$ = 11, #Internal Corner Measure
pdrlcommonb
if icorn <> 0 & jcorn = 0, #Internal Corner Probing Using I
if drl_prm1$ = 1,
xcorn = xout + xdcorn
ycorn = yout + ydcorn
if drl_prm1$ = 2,
xcorn = xout - xdcorn
if drl_prm1$ = 3,
ycorn = yout - ydcorn
if drl_prm1$ = 4,
if drl_prm1$ = 0, result = mprint(scornerror), exitpost$
if drl_prm1$ > 4, result = mprint(scornerror), exitpost$
pbld, n$, *strg659810, *xcorn, *ycorn, e$
pbld, n$, *strg659810, *zcorn, e$
pbld, n$, *strg659815, *xout, *yout, [if shftdrl$, *icorn], [if corn_angtoler > 0, *corn_angtoler], [if offupdate > 0,*offupdate], [if feattol, *feattol],
[if trueposzone > 0, *trueposzone], [if drl_prm10$ > 0, *drl_prm10$], e$
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[iNTERNAL*CORNER*PROBING*USING*I]", e$
sdprint, "[ANGLE*OF*X*SURFACE*IS*#139[24]*]", e$
sdprint, "[","Z*POSITION*IS*",*zcorn,"]", e$
"PCLOS", e$
spaces$ = 1
if icorn = 0 & jcorn <> 0, #Internal Corner Probing Using J
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *strg659815, *xout, *yout, [if retr$, *jcorn], [if corn_angtoler > 0, *corn_angtoler], [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[iNTERNAL*CORNER*PROBING*USING*J]", e$
sdprint, "[ANGLE*OF*Y*SURFACE*IIS*#142[24]*]", e$
"PCLOS", e$
spaces$ = 1
if icorn <> 0 & jcorn <> 0, #Internal Corner Probing Using I and J
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *strg659815, *xout, *yout, [if dwell$, *icorn], [if retr$, *jcorn], [if corn_angtoler > 0, *corn_angtoler], [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[iNTERNAL*CORNER*PROBING*USING*I*AND*J]", e$
sdprint, "[ANGLE*OF*X*SURFACE*=*#139]", e$
sdprint, "[ANGLE*OF*Y*SURFACE*IS*#142[24]*]", e$
"PCLOS", e$
spaces$ = 1
if icorn = 0 & jcorn = 0, #Internal Corner Probing 90 deg Corner
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *sg00, *prorefht, e$
pbld, n$, *strg659815, *xout, *yout, [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
"POPEN", e$
sdprint, "[iNTERNAL*CORNER*90*DEG*CORNER*PROBING*]", e$
"PCLOS", e$
spaces$ = 1
pcom_movea
if drillcyc$ = 12, #External Corner Probing Routine
pdrlcommonb
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *strg659816, *xout, *yout, [if shftdrl$, *icorn], [if corn_angtoler > 0, *corn_angtoler], [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
sdprint, "[EXTERNAL*CORNER*PROBING*USING*I]", e$
spaces$ = 1
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *strg659816, *xout, *yout, [if retr$, *jcorn], [if corn_angtoler > 0, *corn_angtoler], [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
sdprint, "[EXTERNAL*CORNER*PROBING*USING*J]", e$
spaces$ = 1
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *strg659816, *xout, *yout, [if dwell$, *icorn], [if retr$, *jcorn], [if corn_angtoler > 0, *corn_angtoler], [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
sdprint, "[EXTERNAL*CORNER*PROBING*USING*I*AND*J]", e$
spaces$ = 1
if drl_prm1$ = 1,
if drl_prm1$ = 2,
if drl_prm1$ = 3,
if drl_prm1$ = 4,
pbld, n$, *strg659816, *xout, *yout, [if offupdate > 0,*offupdate], [if feattol, *feattol],
if drl_prm10$,
spaces$ = 0
sdprint, "[EXTERNAL*CORNER*90*DEG*CORNER*PROBING*]", e$
spaces$ = 1
pcom_movea
if drillcyc$ = 13, #4th Axis X Measure
pdrlcommonb
pbld, n$, "G65P9818", diedwell, pfyout, pfzout, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if toolupdate > 0, *toolupdate], [if drl_prm10$ > 0, *drl_prm10$], e$
pcom_movea
if drillcyc$ = 14, #4th Axis Y Measure
pdrlcommonb
pbld, n$, *strg659811, pfyout, pfzout, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if toolupdate > 0, *toolupdate], [if drl_prm10$ > 0, *drl_prm10$], e$
pcom_movea
if drillcyc$ = 15, #Bore/Boss on PCD
pdrlcommonb
pbld, n$, *strg659819, *pcddia, *diadwell, [if shftdrl$ = zero, *zbossdep], [if shftdrl$ = one, *zpcddep], [if radclear, *radclear],
[if trueposzone > 0, *trueposzone], [ if apcdang, *apcdang], [if drl_prm10$ > 0, *drl_prm10$], e$
if drl_prm10$,
spaces$ = 0
spaces$ = 1
pcom_movea
if drillcyc$ = 16, #Bore/Boss
pdrlcommonb
pbld, n$, *strg659814, *diedwell, pxout, pyout, pzout, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if toolupdate > 0, *toolupdate], [if drl_prm10$ > 0, *drl_prm10$], e$
pcom_movea
if drillcyc$ = 17, #C Axis Measure
pdrlcommonb
pbld, n$, *strg659618, cyspan, pfxout, pfzout, [if offupdate > 0,*offupdate], [if cangtoler > 0, *cangtoler], [if drl_prm2$ > 0, *drl_prm2$], [if drl_prm10$ > 0, *drl_prm10$], e$
*sg00 ,*sg91, sg28, "Z0", e$
*sg00, *sg90, [if workofs$ > 53, *g_wcs], [if workofs$ < 49 , "G54.1", *p_wcs],"C20.",e$
spaces$ = 0
sif,sbracketopen,spound,sm152,sgt,drl_prm1$,sbracketclose,sgoto,"1000", e$
spaces$ = 1
pcom_movea
if drillcyc$ = 18, #Bore/Boss on PCD
pdrlcommonb
pbld, n$, *strg659819, diedwell, pfyout, pfzout, [if offupdate > 0,*offupdate], [if trueposzone > 0, *trueposzone], [if toolupdate > 0, *toolupdate], [if drl_prm10$ > 0, *drl_prm10$], e$
pcom_movea
if drillcyc$ = 19,
pdrlcommonb
pcom_movea
pdrlcst_2$ #Custom drill cycles 8 - 19 (user option)
if drillcyc$ = 8,
pdrlcommonb
pbld, n$, *strg659810, *xsinsurf, *yout, e$
if drl_prm9$ = 1,
spaces$ = 0
"#135=#12X(STORE 1ST Z PLANE HIT)", e$
if drl_prm10$,
spaces$ = 0
spaces$ = 1
pbld, n$, *strg659810, *ysinsurf, *xout, e$
if drl_prm10$,
spaces$ = 0
spaces$ = 1
pbld, n$, *strg659810, *xout, *yout, e$
if drl_prm10$,
spaces$ = 0
spaces$ = 1
pcom_movea
if drillcyc$ = 9,
pdrlcommonb
result = mprint(sperror), exitpost$
pcom_movea
if drillcyc$ = 10,
pdrlcommonb
pcom_movea
if drillcyc$ = 11,
pdrlcommonb
pcom_movea
if drillcyc$ = 12,
pdrlcommonb
pcom_movea
if drillcyc$ = 13,
pdrlcommonb
pbld, n$, `strg659810, `prnrefht, e$
pbld, n$, "G65P9818", diedwell, pfyout, pfzout, [if trueposzone > 0, *trueposzone], e$
pcom_movea
if drillcyc$ = 14,
pdrlcommonb
pbld, n$, *strg659811, pfyout, pfzout, [if trueposzone > 0, *trueposzone], e$
pcom_movea
if drillcyc$ = 15, #Web/Pocket Measure
pdrlcommonb
pbld, n$, *strg659812, diedwell, pfyout, pfzout, [if trueposzone > 0, *trueposzone], e$
pcom_movea
pdrlcommonb
#pbld, n$, *strg659814, diedwell, pfyout, pfzout, [if trueposzone > 0, *trueposzone], e$
pcom_movea
if drillcyc$ = 17,
pdrlcommonb
pcom_movea
if drillcyc$ = 18,
pdrlcommonb
pcom_movea
if drillcyc$ = 19,
pdrlcommonb
pcom_movea
