Help Please, Transform a Transform
Fretless
I think do Transform #1 ,use Transform by coordinate, lets say 1
Have 3 more duplicate WCS set with different WCS #'s
Then Copy Paste Transform #1. Change The Work coordinate in Parameters, to lets say 2
Then Copy Paste Transform #1. Change The Work coordinate in Parameters, to lets say 3
Then Copy Paste Transform #1. Change The Work coordinate in Parameters, to lets say 4
2 Cents
Fretless,
You only need one transform op.
- Setup the transform to translate,
- check the box for "tool plane origin only",
- set the method as tool plane,
- try grouping the output by operation order,
- set it to copy the source operations,
- set the work offset numbering to assign new (if you want to use aux work offfsets start with 6)
- go to the translate tab
- set the translate to "between points"
- set the steps to how many work offsets you require
- leave the point to point set to zero because you're not changing the origin
I like gun control too, I choose to use both hands and hit what I'm aiming at with the first shot
Guys I was reading this post and I tried to duplicate what was suggested. I couldn't get it to work. First let me see if I understand what the end result should be. I have a group of toolpaths that I would like to have run at 4 different work offsets, G54, G55, G56 and G57. I tried CJep's suggestion and all I got was each toolpath running 4 times at G54. I couldn't get mchin-pilot's to work either. Maybe I didn't understand what was trying to be accomplished.
Gibbs,
Yes, I typically program everything with Mcam's WCS set to top.
I work my way around the part with user defined tool & construction planes. This way I create my stock in the Mcam top view and I never have to move it in verify, it doesn't matter what custom toolplane I have associated to the toolpath.
Qst -"Well what about if you want to use the top/front/iso Gview, you can't do that if you don't have custom WCS associated to every face"
Ans - That's what dynamic rotation is for, or a Space Pilot and if I tell Mcam to set the Gview = to the toolplane, I'm looking at the part relative to the Z+ direction.
The thing is that custom WCS will work but there are a whole bunch of other variables that I have to maintain associations for.
