Help With Toolpath Selection
This is my first time making a part like this and I need help selecting what toolpaths to use. I will be running this part on a Fadal-5-axis vertical mill. The thickness and the diameter will already be turned to size and the middle hole will be to size when the parts comes to me. I plan on locating the part and holding it down with the middle hole. I do not know how to mill the three cutouts and the chamfer that cuts into the OD. Any help is appreciated. Here is a picture of the part. I can supply more pics if needed.
This Looks like a fairly easy job for Multiaxis/swarf 5 axis use these settings
Output format: 5 Axis
Walls: use Chains - select lower, and upper chains
Tipcomp: Lower rail with a - distance number.
This toolpath will work great for the sides, and the chamfer, the only problem will be to get the square corners. if your machine has a c-axis in the table, you may have to raise the part enough to tilt the head and use a curve 5ax toolpath to clean the corners
To cut the od try 3d contour
The 3d contour I am thinking about just controls the tip of the tool, it dosn't tilt the head to cut a draft angle. Is there another 3d contour that will allow you to cut a draft angle? I had to look at the pic from my iPhone, because it is blocked at work, so maybe I am looking at it wrong.
Mcam Nut,
I may be able to create surfaces or wireframe for the geometry that needs to be machined and send you only the surfaces and wireframe. I will have to look into that. I have a few hot jobs to knock out first. I'll get in touch with you when I start to work on this job. I really appreciate all the help I'm getting from everyone.
