Posting error
Kenneth Potter
Ok
I have a single surface "Human nose" to machine that has undercut areas . I'm using a lollipop. I rotated the cplane at a a slight angle & set the tool plane to top. That allows the lollipop to perform the undercut. When i post it with mpfan.pst i get a error message"
Seletor varitable plane=1.0
out range for string select. ??????
At this point posting is interupted at the tool that has the rotated plane.
Can someone tell me what does this means & how i can fix this.
Mill V8 mpfan.pst cd
Kenny
[This message has been edited by Kenneth Potter (edited 12-27-2000).]
Ken, The error message you received is indicative of an NCI problem, but you can work around it in the post by validating the plane variable prior to accessing the string select function. The less desirable alternative would be hand editing the ASCII NCI prior to posting, or using the runold C-hook to force the variable to zero (Version 6 and earlier Mill posts), but you will lose too much information to make that a feasible workaround.
If you decide to work around it in the Post Processor (I thought you might) you should be able to get away with adding the following line of code to the ‘pcom_moveb’ postblock of MPFAN (indent at least one space).
if plane < zero | plane > two, plane = zero
This should do the trick.
Best Regards,
Richard Taft
Post Processing Services
CNC Software, Inc.
671 Old Post Road
Tolland, CT USA http://www.mastercam.com
i made the changes & still have the same error
this is how i added the new line
pcom_moveb
c_mmlt #Multiple tool subprogram call
ptoolcomment
comment
pcan
if stagetool >= zero, pbld, n, *t, "M6", e
pindex
if mi1 > one, absinc = zero
pcan1, pbld, n, *sgcode, *sgabsinc, pwcs, pfxout, pfyout,
pfcout, *speed, *spindle, pgear, strcantext, e
pbld, n, "G43", *tlngno, pfzout, scoolant, next_tool, e
absinc = sav_absinc
pcom_movea
toolchng = zero
c_msng #Single tool subprogram call
Ken,
You should add the code snippet to the ‘pcom_moveb’ postblock. A postblock definition always starts in the first column. The indented ‘pcom_moveb’ you found is actually a “Call” to that postblock. Try searching for the postblock again and just hit “find next” until you see the word ‘pcom_moveb’ in the far left column. When you find it open up a line below and insert the code (don’t forget about the indentation).
If it still gives you trouble, you can just email me and I’ll send you an edited post and you can compare the two.
Best Regards,
Richard Taft
CNC Software, Inc.
671 Old Post Road
When listing postblocks on this forum it is helpful to use the UBB Code tag along with an HTML BIG code. Without it, your idents and spacing will be lost. Click on Edit for this message to see how it's done:
plinout #Comment
this area maintains formatting
[This message has been edited by Webmaster (edited 12-29-2000).]
