WCS and 4th axis programming
Elad
I'll try to explain my problem :
When i program 4axis,almost always i set the home position at the center of the 4th axis,and then i cut the top,and when i want to rotate it,i use cplane-rotate,and i set the new wcs.
The problem is that after i finish all the ops,i need to go one by one to the t/c plane and unmark the "working coordinate system" box.
If i will not unmark it,the gcode will come out without rotation.
I tried to select all and edit common parameters,and then unmark the checkbox in the t/c plane but it doesn't work.i have to go to every operation one by one and unmark it.
Annoying.
Any suggestions??
Hi elad,
What I do is go to Gview,Named,now right click on any view and click Create,copy selected and give that a new name. Now I can set my "0's" and offset number as well. The other way is to go to Gview,Entity and pick geo to set new work offset. I always leave my WCS set to top. Just my way of doing things. And I don't need to regen ops.
