tool comment
ROB
These post changes will allow you to filter out duplicate (COMMENTS)
*Be sure to save a backup copy of your PST FIRST!
Alter these postblocks in MPFAN.PST ->
pcomment        #Comment (must call pcomment2 if booleans)
pcomment2
pcomment2 #Comment output
scomm = ucase (scomm)
if gcode = 1007, "(", scomm, ")"
else, "(", scomm, ")", e
To look like ->
# Need to declare a couple string variables
s_newcomm sblank # String variable to hold 'current comment string'
s_oldcomm sblank # String variable to hold 'prior comment string'
pcomment2 # Jump to this routine to see if to output the comment
s_newcomm = scomm # Copy the incoming COMMENT string
s_newcomm = ucase(s_newcomm) # make it UPPERCASE
scomm = sblank # MUST kill is original incoming COMMENT string
if (s_oldcomm <> s_newcomm), # Is different?, then output it...
if gcode = 1007, "(", s_newcomm, ")"
else, "(", s_newcomm, ")", e
s_oldcomm = s_newcomm # Remember the COMMENT string output
NOTE!
If the (COMMENT) is the same from one tool to the next tool
across a ToolChange that COMMENT will NOT output on the new Tool
, unless... You make a slight change in the PTLCHG postblock ->>
ptlchg #Tool change
pcuttype
toolchng = one
if mi1 = one, #Work coordinate system
pfbld, n, *sg28ref, "X0.", "Y0.", e
pfbld, n, "G92", *xh, *yh, *zh, e
pbld, n, "M01", e
pcom_moveb
c_mmlt #Multiple tool subprogram call
s_oldcomm = sblank # kill the saved prior comment string <*ADD*>
ptoolcomment
comment
pcan
... rest of the original postblock ...
