Rotary axis on machining centers
nickz
My question involves a "A" or "B" axis on vertical and horizontal machining centers. We are using Mastercam V8 (level 1). What is the most efficient way of programming the rotary axis. Presently we are creating the geometry at different view levels, utilizing a misc. real for degrees, and creating an operation for every single location. Is there a easier method? Is a higher level needed to make this easier?
A = Rotary about/around the X Axis
B = Rotary about/around the Y Axis
The easiest way for ME is to draw it how it will sit on the machine. Change toolplanes as you need to index. Make sure you have your centerline of rotation correct, in a nutshell that's it. It's a tad more complicated than that but that's pretty much it. You can check it real easy in Backplot too. You can set it to make the part rotate and the tool will stay stationary.
Fun stuff, and it's more productive too. all the proper relationships are maintained between planes that way.
James Meyette
The geometry is 2D, and I can't rotate the part. For example, I have 2 different bores. Both will share X0, but different Y locations. I put them on different view levels so I can distinguish between the two, (usually there are a few dozen), create a drilling operation and input the degrees in a misc. real (mr9, post is modified to accept this). It's pretty much a flat drawing.
Frank,
Go to Backplot. Set "Interpolate", "Animate" with "0" delay, ckeck "Simulate Axis Substitution" I usually use 1 Degree, then check "Simulate Rotary Axis", selct your tool orientation, and set the axis that you want it rotate about. That's it. Then run it. It really impresses people if you've got a lot of rotary motion. Shade your part, run it then walk away from your desk while it runs and see hom many people you have standing by your desk as it runs.
James Meyette
James is right ....draw it the way it will be
fixtured......one thing that might save you
a ton of time is to use the named views,set
them up in your tplanes,if your gonna do
multiple ops like face,ctour,drill and such
on several parts take a cpl minutes and set
up your named views,that way you can just use
ALT+N hot key call em and set your t&c planes
right from there to work your way around your parts when you`ll be doin several ops,
also you can set up all your offsets right
from there and they`ll be in your tc planes
setting in your tool parameters page already
when you toolpath..i find that to be the best
way for me that way i dont gotta remember 12
or so offsets...since the whole idea behind
the horizontal is to save time and be able to
work on sides and angles and what ever else
on the part
[This message has been edited by d0gFartz (edited 01-23-2001).]
Hi Nick:
Maybe your just off to a bad start. Go to side view, set Z to 5.000, create a point at X0, Y0, now click on Cplane rotate, X+ and type 90. degrees, save. Change your Gview to the same number as your Cplane, create a point X0, Y0,. Now make sure your Tplane is also at the same number your Cplane is and do a drill cycle on your point, change all your planes to side, and do a drill cycle on the point you created at side. Now backplot. That example I use for horizontal machining, for vertical I use Top plane and rotate my Y + . Hope this helped. Also James I tried to backplot the way you described and it still didn't rotate the part.
Frank
[email protected]
ok, need a chance to catch up. I completely understand that it needs to be drawn the same way it is going to be fixtured, but I need to understand one very important item. It should be drawn as 2D?, 3D wireframe?, solids?
What level of MC-Mill are you using? This has become very confusing. If anyone has a sample file for this situation, I would greatly appreciate the help.
[This message has been edited by nickz (edited 01-24-2001).]
Frank,
Do you have rotary motion in your code? If not it will not work. Go to side view, side construction plane. Create an arc 1.0 Dia. at Z0. Set your Z to -5.0. Now create another arc that is 3.0 Dia at the same center point as the other arc. Create 2 other arcs at the 0 deg. pos. and the 180 deg pos. at 1.0 Dia. Trim and fillet the three arcs together. Then go to isometric view while maintaining the side C/P. Create, Surface, Loft, pick one chain, then the other, make sure they(the chain arrows) run the same direction. Change C/P back to top. Then Toolpaths, Multi-Axis, Rotary 4 Axis. Pick the surface, select your tool, turn retract off and feed off as well (Only for illustrative purposes, I would never do that for real life stuff), then change direction to one way. Leave everythig else at the default. Once the toolpath calculates, filter it to .002 (it will speed the display up) Go to backplot and do what I said before and it will work.
James Meyette
Chip Maker
I just tryed for the first time getting the tombstone to rotate to the z axis spindal"Side plane".From the tool path parameters box I set tool & cplane to each tomb stone face & set the rotary axis Rotation type to rotary axis positioning & rotate about z. Then set the back plot display simulate rotary axis to about z and tool orientation back .
Then back plot & watch the merry go round show ! Looks real kweul
Kenny
James.
I learn the rotary axis learn stuff by studying the lathe c axis sample files.That got me started. E Z
Once i got it thru my thick skull, the difference between axis substiution & axis positioning, getting the tombstone to rotate during back plot issue became clearer.
Stayed up all night doing crazy things with tombstoning. I added multiple vises with parts loaded all over, Shaded every thing & got dizzy watching the backplot show. biggrin.gif
The verify is still tool only rotation.
Can 8.1 verify rotate the rotary axis ?
Kenny
[This message has been edited by Kenneth Potter (edited 02-02-2001).]
Kenneth,
Thanks for the explaning it for me. i forget to turn on my axis rotation in the tool path parameters page. However, when I do turn the rotation axis on and set it to rotary axis positioning and rotate about z, when I go to regen the operation Mastercam crashed on me. Actually good old Dr. Watson pops up forcing me to crash. I've tryed this several times but with the same result. Help confused.gif
MC V8.0 L1 running NT4 SP5
[This message has been edited by Chip Maker (edited 02-09-2001).]
Actually, I noticed that when the Ctour8.dll patch runs, that when MC crashes. I'll try downloading the new one.
Kenneth, My T&C planes are both the same. I am using named veiws for my T&C planes They all have the same origin, so i don't think thats the problem. I'll let you guys know how the new Ctour8.dll works.
Getting the part to rotate instead of the tool in the backplot for a horizontal applicaiton is not as intuitive as a vertical application, but goes as follows:
Using toolplanes, enable the Rotary Axis button under Tool parameters. Select Rotary axis positioning with Rotate about Z Axis (i.e. the universal Mastercam Z-Axis). During the backplot Simulate Rotary Axis using Y or Z as the Axis of Rotation.
I didn't mean to drag this topic on for so long.
I downloaded the current Ctour8.dll patch and then it worked just fine. Thanks to everyone for you input. I've created a lot of 4-axis positional programs for our horizontal machine with no problem, but was never able to get the table to rotate in backplot lke everyone said it could. Having the tombstone rotate rather than the tool rotating doesn't help much in terms of verifying if the program is correct or not, but it looks a lot cooler for demos. Thanks again.
Keep those tombstones-a-turning!
