Milling Partical Board/MDF
OOZ662
I'm unsure of what I can do to keep my cutters happy (and alive) in this stuff. I don't have any real experience, so help is greatly appreciated.
I'm using a Techno DaVinci with stepper motors. The facts sheet says I ought to be able to run up to 94.5 IPM feed speeds and the 600W spindle varies from 8000 to 24000 RPM, but it's controlled by a colored dial so I can't really get an accurate assumption on the speed. I'm cutting with two flute 1/4" Onsrud 40-107 bits.
I generally ran MDF with a 3 flute upcut or compression cutter at 18,000 - 24,000 RPM at 400-700IPM. Been known to push it faster, but that was the ballpark on a Komo. On my Thermwood 3 axis I run the same tool but 300-500IPM. Vortex makes some very nice tools that last quite a long time at these speeds and feeds. I have used a 4 flute tol, but prefer 3 flute. Faster feed rate is better. Much less heating time on the tool.
We quit using MDF because of the tool wear. But I agree with Robert, Vortex tools are the best if you can afford them. The powers that be here are too cheap to buy them so I have to make do with inferior tools. I suggest you try several passes. It's a longer process but it may help with wear.
BrintC , what kind of tool wear are you seeing and how long do you expect a tool to last?
We cut MDF and PB all day , every day with 1/2" tools @approx. 10-18k rpm feeding from 200-500ipm with no adverse tooling issues.
On the bigger pockets, they're ramped in and cut in either three .1" passes or two .15" passes, depending on the shape. I managed to get about 75 IPM today and it's doing much better. Still browning the bit quite a bit, but it'll do for the run. Suggestions still appreciated, though. =)
CH, We do custom cabinet parts and dado's have to be precise. Also in perimeter bits,as they dull, when they take a slow winding path or tight corner the friction and heat cause a smoldering coal to emerge.And in a shop that was devastated by fire once already,smoke is a good way of getting an unwanted extinguisher blast.Our bits generally last about a month between changing. Running about 70% of a 10/hr day,4days a week.
I guess I should be thankful they last as long as they do.
