Edit tool holder, no change in backplt or verify
Thee Rickster ™
X4 MU3
(never change these before)....but
I am cutting a deep (funky contoured) 3d cavity and want to use the shortest
cutter stickout as possible.
When I change the Holder Diameter or hieght, the holder in back plot or verify does
not get bigger or smaller when I change those sizes to match the holder that I will
be using in the machine.
I wonder why you have the option to change those values but it does not change any thing.
Any help will be greatly appreciated.
cheers
Rick
:bump:
Do you have to 'save to library' for the changes to take effect?
Cheers
Rick
The verify and backplot do not use thoses fake numbers. instead it used the holder.mcx file located in your tool lib. the only way to use a defined tool holder is to draw it as a custom tool or select from the holder option if the toolpath allows it.
while we are on the subject, i set up our shared x5 folder on the network and now when i back plot i dont get the a holder, just a round blob that kind of looks like a holder. the weird part is verify shows the default holder fine.
if i select a custom holder it shows fine in back plot and verify.
HTH, Damian
This applies to all toolpaths using the tree style parameters page.
The third item down is "Holders"
Click on that and then "Open library"
There are 13 different libraies of toolholder you can choose from
and they show up in true scale in both backplot and verify
if you turn "Show Holders" on..
You can also build your own or modify and save existing holders.
The downside is they are tied to the Operation, not the Tool library.
This is a big downside IMO, but they work very well when you
really need to check holder clearances.
These holders also work with the collision detection features
in 3D high speed and advanced 5X toolpaths
  • 1 month later...
X5 QUESTION. It seems to be working well, assigning a tool holder on tool paths with the tree style. How do you assign a tool holder
to all the other ones???? How do you change the tool holder in the tp's without the tree style parameter page? Does Mastercam have
any plans to make this work or are we stuck with the default?
thanks if you can help!
