Operation comment list at beginning of program
are you using horizontal or vertical? It really makes a big different when one of those machine selected. If you need them to be listed you should look into PCOMMENT3 and remove all the #
pcomment3 #Comment from manual entry
if toolchng,
spaces$=0
# if swcsplname <> snull, pbld, n$, pspc, scomm_str, "WCS NAME - ", swcsplname, scomm_end, e$
# if swcsplcomm <> snull, pbld, n$, pspc, scomm_str, "WCS COMMENT - ", swcsplcomm, scomm_end, e$
# if rot_on_x & stoolplname <> snull, pbld, n$, pspc, scomm_str, "TOOLPLANE NAME - ", stoolplname, scomm_end, e$
# if rot_on_x & stoolplcomm <> snull, pbld, n$, pspc, scomm_str, "TOOLPLANE COMMENT - ", stoolplcomm, scomm_end, e$
# if rot_on_x & sconstplname <> snull, pbld, n$, pspc, scomm_str, "CPLANE NAME - ", sconstplname, scomm_end, e$
# if rot_on_x & sconstplcomm <> snull, pbld, n$, pspc, scomm_str, "CPLANE COMMENT - ", sconstplcomm, scomm_end, e$
# if stpgrpname <> snull, pbld, n$, pspc, scomm_str, "TOOLPATH GROUP - ", stpgrpname, scomm_end, e$
if opcode$ <> 3 & opcode$ <> 16, pbld, n$, pspc, scomm_str, "COMPENSATION TYPE - ", *scomp_type, scomm_end, e$
spaces$=sav_spc
if toolchng0 & op_id$ <> last_op_id,
spaces$=0
#if swcsplname <> snull, pbld, n$, pspc, scomm_str, "WCS NAME - ", swcsplname, scomm_end, e$
#if swcsplcomm <> snull, pbld, n$, pspc, scomm_str, "WCS COMMENT - ", swcsplcomm, scomm_end, e$
#if rot_on_x & stoolplname <> snull, pbld, n$, pspc, scomm_str, "TOOLPLANE NAME - ", stoolplname, scomm_end, e$
#if rot_on_x & stoolplcomm <> snull, pbld, n$, pspc, scomm_str, "TOOLPLANE COMMENT - ", stoolplcomm, scomm_end, e$
#if rot_on_x & sconstplname <> snull, pbld, n$, pspc, scomm_str, "CPLANE NAME - ", sconstplname, scomm_end, e$
#if rot_on_x & sconstplcomm <> snull, pbld, n$, pspc, scomm_str, "CPLANE COMMENT - ", sconstplcomm, scomm_end, e$
#if stpgrpname <> snull, pbld, n$, pspc, scomm_str, "TOOLPATH GROUP - ", stpgrpname, scomm_end, e$
#if comp_type <> prv_comp_type & opcode$ <> 3 & opcode$ <> 16, pbld, n$, pspc, scomm_str, "COMPENSATION TYPE - ", *scomp_type, scomm_end, e$
spaces$ = sav_spc
put the PCOMMENT3 command only after the
psof$ #Start of file for non-zero tool number
I'm at the point that it out puts every tool for the PCOMMENT3, I only want it output when next operation only or when B value changes. Anybody knows ?
O1001 (HORIZONTAL.NC)
(SOURCE FILE= HORIZONTAL - ACTUAL.MCX-6)
(POSTED ON OCT.29.2012 AT 14:28)
(ES-450H)
(TOOL LIST)
(T1 4" FACE MILL D61 H1 )
(T2 .759 FLAT ENDMILL D62 H2 )
(T3 1" DRILL H3 )
(T5 1/4 SPOTDRILL H5 )
(T6 NO. 7 DRILL H6 )
(T7 1/4-20 TAPRH H7 )
(T8 7/8 DRILL H8 )
(T9 7/16 DRILL H9 )
(T12 3/8 DRILL H12 )
G90
G10L2P0X0Y0Z0B0(G53ZERO)
G10L2P1X0Y0Z0B0(G54B0.)
G10L2P2X0Y0Z0B0(G55B90.)
G10L2P3X0Y0Z0B0(G56B270.)
M1(CONFIRM YOUR WORKOFFSETS)
N1(FACING 0)
G0 G17 G40 G80 G91 G28 Z0
G28 X0 Y0
T1 (4" FACE MILL)
M6(DOC= Z-.5)
G0 G17 G90 G54 B0.
X-6.9216 Y.7438 S7000 M3
G43 H1(D61) Z1. M8 T2
Z.2
G1 Z0. F100.
X4.8784 F87.5
Y-.756
X-6.9216
G0 Z1.
(FACING 1)
Y.7438
Z.2
G1 Z-.5 F100.
X4.8784 F87.5
Y-.756
X-6.9216
G0 Z1.
(FACING 2)
(Z STK.= .0555)
Y.7438
Z.2
G1 Z.0555 F100.
X4.8784 F87.5
Y-.756
X-6.9216
G0 Z1.
(FACING 3)
Y.7438
Z.2
G1 Z-.5 F100.
X4.8784 F87.5
Y-.756
X-6.9216
G0 Z1. M9
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N2(OD - CONTOUR 0)
G28 X0 Y0
T2 (.759 FLAT ENDMILL)
M6(DOC= Z-1.)
(XY STK.= .0123)
G0 G17 G90 G54 B0.
X-3.0529 Y2.5152 S8750 M3
G43 H2(D62) Z2. M8 T3
Z.2
G1 Z-1. F100.
G41 D62 X-2.5216 F25.
X2.4784 F50.
G2 X3.2497 Y1.7439 I0. J-.7713
G1 Y-1.7561
G2 X2.4784 Y-2.5274 I-.7713 J0.
G1 X-2.5216
G2 X-3.2929 Y-1.7561 I0. J.7713
G1 Y1.7439
G2 G40 X-2.5216 Y2.5152 I.7713 J0.
G0 Z.25
X-3.0529 Y2.1357
Z.2
G1 Z-1. F100.
X2.4784 F50.
G2 X2.8702 Y1.7439 I0. J-.3918
G1 Y-1.7561
G2 X2.4784 Y-2.1479 I-.3918 J0.
G1 X-2.5216
G2 X-2.9134 Y-1.7561 I0. J.3918
G1 Y1.7439
G2 G40 X-2.5216 Y2.1357 I.3918 J0.
G0 Z2.
(OD - CONTOUR 1)
(XY STK.= .001)
(Z STK.= .002)
X-3.0529 Y2.5039
Z.2
G1 Z-.498 F100.
X2.4784 F50.
G2 X3.2384 Y1.7439 I0. J-.76
G1 Y-1.7561
G2 X2.4784 Y-2.5161 I-.76 J0.
G1 X-2.5216
G2 X-3.2816 Y-1.7561 I0. J.76
G1 Y1.7439
G2 G40 X-2.5216 Y2.5039 I.76 J0.
G0 Z.25
X-3.0529 Y2.1244
Z.2
G1 Z-.498 F100.
X2.4784 F50.
G2 X2.8589 Y1.7439 I0. J-.3805
G1 Y-1.7561
G2 X2.4784 Y-2.1366 I-.3805 J0.
G1 X-2.5216
G2 X-2.9021 Y-1.7561 I0. J.3805
G1 Y1.7439
G2 G40 X-2.5216 Y2.1244 I.3805 J0.
G0 Z2.
(OD - CONTOUR - 2)
S5000 M3
(XY STK.= .0123)
(Z STK.= .0543)
X-3.0529 Y2.5152
Z.2
G1 Z-.6957 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z.25
X-3.0529 Y2.1357
Z.2
G1 Z-.6957 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z2.
(OD - CONTOUR 3)
(XY STK.= .001)
(Z STK.= .002)
X-3.0529 Y2.5039
Z.2
G1 Z-.498 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z.25
X-3.0529 Y2.1244
Z.2
G1 Z-.498 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z2.
(OD - CONTOUR - 4)
(XY STK.= .001)
(Z STK.= .002)
X-3.0529 Y2.5039
Z.2
G1 Z-.248 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z.25
X-3.0529 Y2.1244
Z.2
G1 Z-.248 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z2.
(OD - CONTOUR - 5)
(XY STK.= .001)
(Z STK.= .002)
X-3.0529 Y2.5039
Z.2
G1 Z-.1833 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z.25
X-3.0529 Y2.1244
Z.2
G1 Z-.1833 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z.25
X-3.0529 Y2.5039
Z.2
G1 Z-.373 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z.25
X-3.0529 Y2.1244
Z.2
G1 Z-.373 F100.
X2.4784 F50.
G1 Y-1.7561
G1 X-2.5216
G1 Y1.7439
G0 Z2. M9
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N3(PECK DRILL)
G28 X0 Y0
T3 (1" DRILL)
M6(DOC= Z-1.)
(Z STK.= .002)
G0 G17 G90 G54 B0.
X0. Y0. S5000 M3
G43 H3 Z2. T5
G98 G83 Z-1. R.1 Q.225 F17.14
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N5 G91 G28 Z0
M0 (CLAMP ABC)
(1/4-20 ROLL TAP SPOT DRILL)
G28 X0 Y0
T5 ( 1/4 SPOTDRILL)
M6(DOC= Z-.125)
(Z STK.= .002)
G0 G17 G90 G54 B0.
X-1.2716 Y.8689 S5000 M3
G43 H5 Z2. T6
G98 G81 Z-.125 R.1 F25.71
X1.2284
X-1.2716 Y-.8811
X1.2284
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N6(1/4-20 ROLL TAP DRILL SIZE)
G28 X0 Y0
T6 (NO. 7 DRILL)
M6(DOC= Z-1.)
(Z STK.= .002)
G0 G17 G90 G54 B0.
X-1.2716 Y.8689 S2500 M3
G43 H6 Z2. T7
G98 G83 Z-1. R.1 Q.0603 F8.57
X1.2284
X-1.2716 Y-.8811
X1.2284
G80
S5000 M3
(Z STK.= .002)
X-1.2716 Y.8689
X1.2284
X-1.2716 Y-.8811
X1.2284
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N7(1/4-20 ROLL TAP)
G28 X0 Y0
T7 ( 1/4-20 TAPRH)
M6(DOC= Z-1.)
(Z STK.= .002)
G0 G17 G90 G54 B0.
X-1.2716 Y.8689
G43 H7 Z2. T3
M80 S200
G98 G84 Z-1. R.1 F10.
X1.2284
X-1.2716 Y-.8811
X1.2284
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
Op2
N302(DRILL)
G28 X0 Y0
T3 (1" DRILL)
M6(DOC= Z-.75)
(Z STK.= .002)
G0 G17 G90 G55 B90.
X0. Y0. S5000 M3
G43 H3 Z2. T2
G98 G83 Z-.75 R.1 Q.225 F8.57
X-.75 Y1.25
X.75
X-.75 Y-1.25
X.75
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N202(CIRCLE MILL)
G28 X0 Y0
M6(DOC= Z-.7278)
(XY STK.= .0111)
(Z STK.= .0222)
G0 G17 G90 G55 B90.
X-.0805 Y.1379 S5000 M3
G43 H2(D62) Z.1 T3
G3 X.0805 Y-.1379 Z.0737 I.0805 J-.1379 F50.
X-.0805 Y.1379 Z.0474 I-.0805 J.1379
X.0805 Y-.1379 Z.0211 I.0805 J-.1379
X-.0805 Y.1379 Z-.0051 I-.0805 J.1379
X.0805 Y-.1379 Z-.0314 I.0805 J-.1379
X-.0805 Y.1379 Z-.0577 I-.0805 J.1379
X.0805 Y-.1379 Z-.084 I.0805 J-.1379
X-.0805 Y.1379 Z-.1103 I-.0805 J.1379
X.0805 Y-.1379 Z-.1366 I.0805 J-.1379
X-.0805 Y.1379 Z-.1628 I-.0805 J.1379
X.0805 Y-.1379 Z-.1891 I.0805 J-.1379
X-.0805 Y.1379 Z-.2154 I-.0805 J.1379
X.0805 Y-.1379 Z-.2417 I.0805 J-.1379
X-.0805 Y.1379 Z-.268 I-.0805 J.1379
X.0805 Y-.1379 Z-.2943 I.0805 J-.1379
X-.0805 Y.1379 Z-.3206 I-.0805 J.1379
X.0805 Y-.1379 Z-.3468 I.0805 J-.1379
X.0869 Y.1339 Z-.3639 I-.0805 J.1379
X-.0869 Y-.1339 I-.0869 J-.1339
X.0869 Y.1339 I.0869 J.1339
X0. Y.1697 I-.1386 J-.2135
Y-.1697 I0. J-.1697
Y.1697 I0. J.1697
X-.0848 Y.0848 I0. J-.0848
G1 X-.0805 Y.1379
Z-.2639 F5.
G3 X.0805 Y-.1379 Z-.2902 I.0805 J-.1379 F50.
X-.0805 Y.1379 Z-.3165 I-.0805 J.1379
X.0805 Y-.1379 Z-.3428 I.0805 J-.1379
X-.0805 Y.1379 Z-.369 I-.0805 J.1379
X.0805 Y-.1379 Z-.3953 I.0805 J-.1379
X-.0805 Y.1379 Z-.4216 I-.0805 J.1379
X.0805 Y-.1379 Z-.4479 I.0805 J-.1379
X-.0805 Y.1379 Z-.4742 I-.0805 J.1379
X.0805 Y-.1379 Z-.5005 I.0805 J-.1379
X-.0805 Y.1379 Z-.5268 I-.0805 J.1379
X.0805 Y-.1379 Z-.553 I.0805 J-.1379
X-.0805 Y.1379 Z-.5793 I-.0805 J.1379
X.0805 Y-.1379 Z-.6056 I.0805 J-.1379
X-.0805 Y.1379 Z-.6319 I-.0805 J.1379
X.0805 Y-.1379 Z-.6582 I.0805 J-.1379
X-.0805 Y.1379 Z-.6845 I-.0805 J.1379
X.0805 Y-.1379 Z-.7107 I.0805 J-.1379
X.0869 Y.1339 Z-.7278 I-.0805 J.1379
Y-.1697 I0. J-.1697
Y.1697 I0. J.1697
S8000 M3
G1 X0. Y0. F30.
G41 D62 X.1797 Y.1797
G3 X0. Y.3594 I-.1797 J0.
Y-.3594 I0. J-.3594
Y.3594 I0. J.3594
X-.1797 Y.1797 I0. J-.1797
G1 G40 X0. Y0.
G0 Z.25
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N303(SECOND HOLE)
G28 X0 Y0
T3 (1" DRILL)
M6(DOC= Z-.5)
(Z STK.= .0222)
G0 G17 G90 G55 B90.
X0. Y0. S5000 M3
G43 H3 Z2. T8
G98 G83 Z-.5 R.1 Q.225 F8.57
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N8(DRILL)
G28 X0 Y0
T8 ( 7/8 DRILL)
M6(DOC= Z-.75)
(Z STK.= .0222)
G0 G17 G90 G55 B90.
X-.75 Y1.25 S5000 M3
G43 H8 Z2. T9
G98 G83 Z-.75 R.1 Q.2625 F8.57
X.75
X-.75 Y-1.25
X.75
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N9(DRILL FOR REAM HOLES - 1)
G28 X0 Y0
T9 ( 7/16 DRILL)
M6(DOC= Z-.5)
(Z STK.= .0222)
G0 G17 G90 G55 B90.
X.75 Y1.25 S5000 M3
G43 H9 Z2. T5
G98 G83 Z-.235 R.1 Q.1313 F34.29
X-.75
Y-1.25
X.75
G80
G91 G28 Z0.
(ROUGH PILOT HOLE - 2)
S7000 M3
(Z STK.= .0222)
G0 G90 G56 B270. X0. Y0.
G43 H9 Z2.
G98 G83 Z-.5 R.1 Q.1313 F50.
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N502(SPOT DRILL FOR CORNER SLOTS)
G28 X0 Y0
T5 ( 1/4 SPOTDRILL)
M6(DOC= Z-.1)
(Z STK.= .0222)
G0 G17 G90 G56 B270.
X-.6587 Y.8904 S5000 M3
G43 H5 Z2. T12
G98 G81 Z-.1 R.1 F12.
Y-.8904
X.6587
Y.8904
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N12(ROUGH CORNER SLOTS)
G28 X0 Y0
T12 ( 3/8 DRILL)
M6(DOC= Z-.625)
(Z STK.= .0222)
G43 H12 Z2. T2
G98 G83 Z-.625 R.1 Q.1125 F12.
Y-.8904
X.6587
Y.8904
G80
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N203(ROUGH POCKET)
G28 X0 Y0
M6(DOC= Z-.447)
(XY STK.= .0258)
(Z STK.= .053)
(XY STK.= .0258)
X-.0514 Y.2207 S7000 M3
G43 H2(D62) Z2. T12
Z.2
G1 Z-.2572 F5.
G2 Y-.2207 I-2.3682 J-.2207 F50.
X.0514 I.0514 J-1.3546
Y.2207 I2.3682 J.2207
X-.0514 I-.0514 J1.3546
G1 Z-.447 F5.
G1 Z.2 F100.
G0 Z2.
M5
G91 G28 Z0 M19
G28 X0 Y0
G40 G80 G90
M1
N1202(ROUGH DRILL FOR SLOTS)
G28 X0 Y0
T12 ( 3/8 DRILL)
M6(DOC= Z-.357)
(Z STK.= .053)
G43 H12 Z2. T1
G98 G83 Z-.357 R.1 Q.1125 F8.57
X.6587
Y-.8904
X-.6587
G80
G28 G91 Z0
G28 X0 Y0
G28 B0.
M1
T1 M6
G90
