Posting 1 deg inc B axis move?
Darin
Hello,
We have a Haas VF TR Series 5X Mill.. We are using the Generic Haas VF-TR_Series 5X Mill post file and GENERIC HAAS VF-TR_SERIES 5X MILL control file. For some reason it posts like below with 1 deg increments B axis moves.. Is there a setting for this? It only happenes on certain programs.. This is a simple mill four flats on a cylinder. So it uses front,back,right ,left planes.....
G20
G0 G17 G40 G49 G80 G90
G0 G28 G91 Z0.
(DST V24826S 3/4 EMC 1-5/8 LOC |TOOL - 1|DIA. OFF. - 1|LEN. - 1|TOOL DIA. - .75)
((FRONT) ROUGH-OUT SLOT - 3/4" EMC)
M11
M13
T1 M6
G0 G54 G90 X2.065 Y-7.3892 B180. A90. S7500 M3
M10
M12
G43 H1 Z3.315
Z1.515
G1 Z1.315 F50.
X1.315 F75.
X-1.315
X-2.065
Z1.515 F100.
G0 Z3.315
((FRONT) FINISH SLOT - 3/4" EMC)
Y-7.6392
Z1.515
G1 Z1.315 F50.
X-1.315 F75.
X1.315
X2.065
Z1.515 F100.
G0 Z3.315
((RIGHT) ROUGH-OUT SLOT - 3/4" EMC)
M13
B181. <-------------------------------------------------------------------- 1 deg B axis moves????---------------------->
M12
Y-7.6364
M13
B182.
M12
Y-7.6336
M13
B183.
M12
Y-7.6309
M13
B184.
M12
Y-7.6281
M13
B185.
M12
Y-7.6253
M13
B186.
M12
Y-7.6225
M13
B187.
M12
Y-7.6198
M13
B188.
M12
Y-7.617
M13
B189.
M12
Y-7.6142
M13
B190.
M12
Y-7.6114
M13
B191.
M12
Y-7.6086
M13
B192.
M12
Y-7.6059
M13
B193.
M12
Y-7.6031
M13
B194.
M12
Y-7.6003
M13
B195.
M12
Y-7.5975
M13
B196.
M12
Y-7.5948
M13
B197.
M12
Y-7.592
M13
B198.
M12
Y-7.5892
M13
B199.
M12
Y-7.5864
M13
B200.
M12
Y-7.5836
M13
B201.
M12
Y-7.5809
M13
B202.
M12
Y-7.5781
M13
B203.
M12
Y-7.5753
M13
B204.
M12
Y-7.5725
M13
B205.
M12
Y-7.5698
M13
B206.
M12
Y-7.567
M13
B207.
M12
Y-7.5642
M13
B208.
M12
Y-7.5614
M13
B209.
M12
Y-7.5586
M13
B210.
M12
Y-7.5559
M13
B211.
M12
Y-7.5531
M13
B212.
M12
Y-7.5503
M13
B213.
M12
Y-7.5475
M13
B214.
M12
Y-7.5448
M13
B215.
M12
Y-7.542
M13
B216.
M12
Y-7.5392
M13
B217.
M12
Y-7.5364
M13
B218.
M12
Y-7.5336
M13
B219.
M12
Y-7.5309
M13
B220.
M12
Y-7.5281
M13
B221.
M12
Y-7.5253
M13
B222.
M12
Y-7.5225
M13
B223.
M12
Y-7.5198
M13
B224.
M12
Y-7.517
M13
B225.
M12
Y-7.5142
M13
B226.
M12
Y-7.5114
M13
B227.
M12
Y-7.5086
M13
B228.
M12
Y-7.5059
M13
B229.
M12
Y-7.5031
M13
B230.
M12
Y-7.5003
M13
B231.
M12
Y-7.4975
M13
B232.
M12
Y-7.4948
M13
B233.
M12
Y-7.492
M13
B234.
M12
Y-7.4892
M13
B235.
M12
Y-7.4864
M13
B236.
M12
Y-7.4836
M13
B237.
M12
Y-7.4809
M13
B238.
M12
Y-7.4781
M13
B239.
M12
Y-7.4753
M13
B240.
M12
Y-7.4725
M13
B241.
M12
Y-7.4698
M13
B242.
M12
Y-7.467
M13
B243.
M12
Y-7.4642
M13
B244.
M12
Y-7.4614
M13
B245.
M12
Y-7.4586
M13
B246.
M12
Y-7.4559
M13
B247.
M12
Y-7.4531
M13
B248.
M12
Y-7.4503
M13
B249.
M12
Y-7.4475
M13
B250.
M12
Y-7.4448
M13
B251.
M12
Y-7.442
M13
B252.
M12
Y-7.4392
M13
B253.
M12
Y-7.4364
M13
B254.
M12
Y-7.4336
M13
B255.
M12
Y-7.4309
M13
B256.
M12
Y-7.4281
M13
B257.
M12
Y-7.4253
M13
B258.
M12
Y-7.4225
M13
B259.
M12
Y-7.4198
M13
B260.
M12
Y-7.417
M13
B261.
M12
Y-7.4142
M13
B262.
M12
Y-7.4114
M13
B263.
M12
Y-7.4086
M13
B264.
M12
Y-7.4059
M13
B265.
M12
Y-7.4031
M13
B266.
M12
Y-7.4003
M13
B267.
M12
Y-7.3975
M13
B268.
M12
Y-7.3948
M13
B269.
M12
Y-7.392
M13
B270.
M12
Y-7.3892
Z1.515
G1 Z1.315 F50.
X1.315 F75.
X-1.315
X-2.065
Z1.515 F100.
G0 Z3.315
((RIGHT) FINISH SLOT - 3/4" EMC)
Y-7.6392
Z1.515
G1 Z1.315 F50.
X-1.315 F75.
X1.315
X, Y, Z - A, B, C
A Rotates around X Axis
B Rotates around Y Axis
C Rotates around Z Axis
You're going to have to create planes most likely. Besides, if it's "... mill four flats on a cylinder...", you can just contour that from the top view and be done.
It is four flats in the center of the cylinder channel only.. So the flat is not the whole side just a channel..
X, Y, Z - A, B, C
Ok created four test planes front,right,back,left... It still posts the 1deg inc... Also I posted it with this post Generic Fanuc 5X Mill and it didn't post the 1deg increments like the Generic Haas VF-TR_Series 5X Mill did..
M10
M12
G43 H1 Z3.315
Z1.515
G1 Z1.315 F50.
X1.315 F75.
X-1.315
X-2.065
Z1.515 F100.
G0 Z3.315
Y-7.6392
Z1.515
G1 Z1.315 F50.
X-1.315 F75.
X1.315
X2.065
Z1.515 F100.
G0 Z3.315
M13
B181.
M12
Y-7.6364
M13
B182.
M12
Y-7.6336
M13
B183.
M12
Y-7.6309
Generic Fanuc 5X Mill post
N100 G20
N102 G0 G17 G40 G80 G90 G94 G98
N104 G0 G28 G91 Z0.
N106 G0 G28 X0. Y0.
N108 T1 M6
N110 G0 G54 G90 X7.3892 Y2.065 C180. B-90. S7500 M3
N112 G43 H1 Z3.315
N114 Z1.515
N116 G1 Z1.315 F50.
N118 Y1.315 F75.
N120 Y-1.315
N122 Y-2.065
N124 Z1.515 F100.
N126 G0 Z3.315
N128 X7.6392
N130 Z1.515
N132 G1 Z1.315 F50.
N134 Y-1.315 F75.
N136 Y1.315
N138 Y2.065
N140 Z1.515 F100.
N142 G0 Z3.315
N144 C90.
N146 X7.3892
N148 Z1.515
N150 G1 Z1.315 F50.
N152 Y1.315 F75.
N154 Y-1.315
N156 Y-2.065
N158 Z1.515 F100.
N160 G0 Z3.315
N162 X7.6392
N164 Z1.515
N166 G1 Z1.315 F50.
N168 Y-1.315 F75.
N170 Y1.315
N172 Y2.065
N174 Z1.515 F100.
N176 G0 Z3.315
((BACK) ROUGH-OUT SLOT - 3/4" EMC)
N178 C0.
N180 X7.3892
N182 Z1.515
N184 G1 Z1.315 F50.
N186 Y1.315 F75.
N188 Y-1.315
N190 Y-2.065
N192 Z1.515 F100.
N194 G0 Z3.315
((BACK) FINISH SLOT - 3/4" EMC)
N196 X7.6392
N198 Z1.515
N200 G1 Z1.315 F50.
N202 Y-1.315 F75.
N204 Y1.315
N206 Y2.065
N208 Z1.515 F100.
N210 G0 Z3.315
((LEFT) ROUGH-OUT SLOT - 3/4" EMC)
N212 C-90.
N214 X7.3892
N216 Z1.515
N218 G1 Z1.315 F50.
This should be a fairly simple solution.
The Haas VF_TR Post has the following variables set:
brk_mv_head  : 1	 #Break the 5 axis moves to remove gouge
brk_max_ang  : 1	 #'brk_mv_head' maximum angle move, applied if chordal
				 #calculation angles moves are greater (negative disables)
The first variable 'brk_mv_head', when set to '1', tells the post processor to break up large rotary moves into smaller moves, to prevent the reposition move from potentially damaging your part. Setting this variable to '0' will disable that post feature, but you should be aware that it could cause other problems.
The next variable 'brk_max_ang' is set to '1', and this is the break-up tolerance in degrees. This is why you are getting 1 degree increments on the moves.
A potential solution would be to leave the 'brk_mv_head' set to '1', but change the max angle setting to '15' or maybe '30' degrees. This would still cause some extra rotary moves, but would also help prevent large rotations with XYZ moves.
