Mazak fusion 640
Jeff2005
We are trying to use tapping on our Mazak 640 fusion. Mastercam is not putting out the correct code when writing a EIA program.
SAMPLE CODE: G98 G84 Z-20. R2. F.7
X90. F75.
Now keep in mind we are in metric tapping and we are using a M10 X 1.75 Tap.
Does the Mazak read this differently? please feel free to email me your responses
[email protected]
thanks for all your help.
Jeff
well if i am running a spindle speed of 50 it should be 75 feed. what is the difference between a G98 and a G99?
Feed is independent of spindle speed, because it's called as feed per revolution, which is the same as the pitch of the tap.
If you're in MM mode, your feedrate for M10x1.5 should be "F1.5"
If you're in inch mode, your feedrate will be "F.059"
Are you even able to tap? I am new to Mazak and had to use live tooling to tap a hole down the center.
my code was simple G84 but the machine acted like it didn't want to run the canned cycle.
The tap went in but the spindle kept turning and the tap just reamed out the hole at final depth with no m4 to retract the tool.
G0 X0 Z.1
G84 G99 Z-.5 R0.0 F.0555
g80
did I miss anything or is the Mazak code different than that code in the manual?
Here is a sample of what it is posting. Sorrry it took so long to post.
O1 (TAP)
( JAN.-11-13)
( 10:12 AM)
/T79 M06
/M01
N79
G21
G0 G40 G80 G90 G94 G98
G0 G28 G91 Z0.
G0 G28 X0. Y0.
T79 M06 ( 10.00-1.5 TAP RH)
M38
G0 G54 G90 X0. Y0. S200 M3
G43 H79 Z25.
G99 G84 Z25. F.7 H100.0
X-25.29 Y13.9 F300.
G80
M5
G0 G28 G91 Z0.
G0 G28 X0. Y0.
M30
What post are you using?
Try this code and you'll be fine. (assuming 1.5 pitch tap going 25mm deep with retract height of 2mm)
G43 H79 Z25.
G99 G84 Z-25. R2.F1.5
X-25.29 Y13.9
G80
M5
I have the parameters on my Mazaks set to always default to rigid tap on G84, so I don't know what the rigid tap M code is. If yours doesn't default to rigid tap automatically, you need to insert that M code. But everything else should work fine.
I beleive the rigid tap codes are
G63 (tapping mode) to turn it on
G64 (cutting mode) to turn it off
we have a bunch of Mazak 640 controls and our code looks like this..
FYI, if the G64 is not before the G80 it will alarm out..
(TAP 1/4-20 X .8 DEEP)
(1/4-20 TAP)
T22
M6
G0G17G90G54X-.4881Y.4473S500M3
G43H22Z2.M8T18
G95
G63
G98G84Z-.8R.1F.05
X-1.9714Y-.8402
G64
G80M9
M5
G91G28Z0.
G28Y0.
M01
Thought I would add the relevant sections from the MPmaster post I already modified for this.. essentially this makes the post include the G63 and G64 in the places shown in the code above..
ptap$ #Canned Tap Cycle
pdrlcommonb
#RH/LH based on spindle direction
if rigid_tap, pbld, n$, *sm29, *speed, e$ #Rigid Tapping
if use_pitch = 0,
pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,
prdrlout, [if peck1$, *peck1$], *feed, strcantext, e$
else,
if metvals, pitch = n_tap_thds$ # Tap pitch (mm per thread)
else, pitch = 1/n_tap_thds$ # Tap pitch (inches per thread)
"G63" , e$
prdrlout, [if peck1$, *peck1$], *pitch, !feed, strcantext, e$
pcom_movea
pcanceldc$ #Cancel canned drill cycle
result = newfs (three, zinc)
if drillref = 0, zabs = initht_a #Make the initht the modal Z value
else, zabs = refht_a
prv_zia = zabs
!zabs
ps_inc_calc
prv_gcode$ = zero
if cool_zmove = yes$ & (nextop$=1003 | (nextop$=1011 & t$<>abs(nexttool))), coolant$ = zero
pcan
if drillcyc$ = 3, "G64", e$
if drillcyc$ <> 8, pcan1, pbld, n$, "G80", scoolant, strcantext, e$
pbld, n$, sgfeed, e$
pcan2
