How get rid of comments on the top in post?
Hello,
We have a machine that can only hold so many characters and can't drip feed so I need to delete as much as possible.. Where in the post does it control the below comments so I can delete them? I tried unchecking all on the output comments in the machine group properties but there are still there...
N5
O0037 (2ND OPP DAM SPACER)
(MCX FILE - C:\USERS\JAMIE\DOCUMENTS\DAM PARTS\DAM SPACER.MCX-6) <---------------------- Need this line gone----------------------------------->
(PROGRAM - 2ND OPP DAM SPACER.NC) <---------------------- Need this line gone----------------------------------->
(DATE - JAN-24-2013) <---------------------- Need this line gone----------------------------------->
(TIME - 10:56 AM) <---------------------- Need this line gone----------------------------------->
(T6 - 1/2 SPOT DRILL - H6 - D71 - D0.5000") <----------------------------------------------------------------------------Would like to get rid of spaces on these lines for the tool list ------------------------------------------>
(T7 - 27/64 DRILL - H7 - D7 - D0.4219")
(T9 - 1/2-13 TAP - H9 - D9 - D0.5000")
(T16 - 1.0" FACEMILL - H10 - D10 - D1.0000" - R0.0300")
(T1 - 1/2 ENDMILL - H11 - D11 - D0.5000")
(OVERALL MAX - Z3.)
(OVERALL MIN - Z-1.625)
N6G00G17G20G40G80G90
N7G91
Is it in the post in this area?
# Start of File and Toolchange Setup
psof0$ #Start of file for tool zero
psof$
psof$ #Start of file for non-zero tool number
ptravel
pwritbuf5
pcuttype
toolchng = one
if ntools$ = one,
#skip single tool outputs, stagetool must be on
#stagetool = m_one
!next_tool$
tooltotal = rbuf(4,0) #Reads total tool and null tool changes
if toolcountn <= tooltotal, nexttool = rbuf(4,toolcountn)
else, nexttool = first_tool$
if tool_table = 2, ppredstck
if tool_table = 3, pmetastck
spaces$=0
if output_z = yes$ & tcnt > 1,
scomm_str, "OVERALL MAX - ", *z_tmax, scomm_end, e$
scomm_str, "OVERALL MIN - ", *z_tmin, scomm_end, e$
spaces$=sav_spc
if plane$ < 0 | opcode$ = 3 | opcode$ = 16, plane$ = 0
pbld, n$, *sgcode, *sgplane, *smetric, "G40", "G80", *sgabsinc, e$
sav_absinc = absinc$
absinc$ = one
if wcstype <= one, #Work coordinate system
pfbld, n$, sgabsinc, e$
pfbld, n$, "G92", *xh$, *yh$, *zh$, e$
else,
pbld, n$, sgabsinc, e$
Try this, place a # sign in front the lines the you dont want output
psof$
ptravel
pwritbuf5
pcuttype
toolchng = one
if ntools$ = one,
#stagetool = m_one
!next_tool$
#if tool_table = 2, ppredstck<-------------------------------------Like this
#if tool_table = 3, pmetastck<-------------------------------------Like this
spaces$=0
#scomm_str, "OVERALL MAX - ", *z_tmax, scomm_end, e$ <-------------------------------------Like this
# scomm_str, "OVERALL MIN - ", *z_tmin, scomm_end, e$ <-------------------------------------Like this
spaces$=sav_spc
absinc$ = one
else,
this section of the post controls what gets posted. I have changed some myself, these are the notes I have made for my own records you can use them to help guide you through as well. I have a habit of putting 3pound signs to indicate my edits
### "%", e$ ###turns off percent sign at top of program
### " ", e$ ### added line space
spaces$=0
### *progno$, " ", scomm_str, sprogname$, scomm_end, e$
*progno$, scomm_str, sprogname$, scomm_end, e$ ###removed " " between prog. # and comment
spathnc$ = ucase(spathnc$)
smcname$ = ucase(smcname$)
comment$ # File descriptor
spaces$=0
" ", e$ ### added line space between manual comment and header
#scomm_str, "PROGRAM NAME - ", sprogname, scomm_end, e
#scomm_str, "DATE=DD-MM-YY - ", date, " TIME=HH:MM - ", time, scomm_end, e
#scomm_str, "MASTERCAM - V", *vers_no$, scomm_end, e$
# scomm_str, "MASTERCAM - X", scomm_end, e$
### scomm_str, "MCX FILE - ", smcpath$, smcname$, smcext$, scomm_end, e$ ###turned off MCX comment
if spostname_sav = snull, spostname_sav = spostname
# scomm_str, "POST - ", snamepst$, scomm_end, e$
#scomm_str, "MP - V", *dll_vers$, scomm_end, e$
stck_matl$ = ucase(stck_matl$)
scomm_str, "MATERIAL:", stck_matl$, scomm_end, e$ ###turned on MATERIAL
### scomm_str, "PROGRAM - ", sprogname$, sextnc$, scomm_end, e$ ###turned off PROGRAM comment
scomm_str, "DATE:", *smonth, "/", *day$, "/", *year$, scomm_end, e$ # MON-DD-YYYY ###changed spacing and added :
#scomm_str, "DATE - ", *year$, "/", *month$, "/", *day$, scomm_end, e$ # YYYY/MN/DD
#scomm_str, "DATE - ", *day$, "/", *month$, "/", *year$, scomm_end, e$ # DD/MN/YYYY
#scomm_str, "DATE - ", date$, scomm_end, e$ # DD-MM-YR
scomm_str, "TIME:", *hour, ":", *min, [if time$ < 12, " AM"], [if time$ >= 12, " PM"], scomm_end, e$ # 12 hour ###changed format
#scomm_str, "TIME - ", time$, scomm_end, e$ # 24 hour
#scomm_str, "POST DEVELOPED BY:", *slicense, scomm_end, e$
removing spaces from tool coments can be a bit tricky because of the number of characters changes and the post likes to line everything up but if you can find this area in your post you can "play" with the values and it may help again I use 3# symbols to mark any of my changes. Try changing one value at a time to make sure you end up with the format you want.
good luck
ptoolcomm # Comments from tool library
spaces$ = 0
strtool$=ucase(strtool$)
if strtool$<>snull, pspc1, scomm_str, *strtool$, scomm_end
else, pspc1, scomm_str, "DEFINE TOOL NAMES", scomm_end
spaces$ = sav_spc
plistcomm # Comments from tool library
if strtool$=snull, strtool$ = snocomm
*strtool$
nstrlen = strlen(strtool$)
counter = 0 ###CHANGED from 1
while counter <= (17-nstrlen), pspace ###changed from 20 to give less spaces after tool comment
pmetacomm # Comments from tool library
if strtool$<>snull, *strtool$
else, "DEFINE TOOL NAMES"
pspace # Creates spaces based on tool comment length
counter = counter + 1
ptspace # Creates spaces based on tool number
if t$ < 0, " " ###changed from 10
if t$ >= 10 & t$ < 100, " "
phspace # Creates spaces based on length offset number
if tlngno$ < 0, " " ###changed from 10
if tlngno$ >= 10 & tlngno$ < 100, " "
pdspace # Creates spaces based on diameter offset number
if tloffno$ < 0, " " ###changed from 10
if tloffno$ >= 10 & tloffno$ < 100, " "
pdiamspc # Creates spaces based on diameter offset number
#if tldia$ < 0, " " ###changed from 10
pspc # Creates spaces based tool level setting
if sav_spc = one & omitseq$ = no$, " "
pspc1 # Creates spaces based tool level setting
if sav_spc = one, " "
popnote # Operation note for tool table
if opcode$ = 3 | opcode$ = 16, *sdrnote
else,
if opcode$ = 13 & hst_flg, *sopnotehst
else, *sopnote
hst_flg = 0
good luck
spaces$ = 0
spaces$ = sav_spc
*strtool$
else,
else, *sopnote
hst_flg = 0
Great thanks guys... That worked perfect..
You can also play with these values, they remove some of the spaces around the hyphens. I usually # out the originals and change them below to keep an original of the format and show my changes.
### if tcr$>0, scomm_str, *t$, ptspace, " - ", plistcomm, " - ", *tlngno$, phspace, " - ", *tloffno$, pdspace, " - ", *tldia$, punit, pdiamspc, " - ", *tcr$, punit, scomm_end, e$ ###turned off original
### if tcr$=0, scomm_str, *t$, ptspace, " - ", plistcomm, " - ", *tlngno$, phspace, " - ", *tloffno$, pdspace, " - ", *tldia$, punit, pdiamspc, scomm_end, e$ ###turned off original
if tcr$>0, scomm_str, *t$, "-", plistcomm, "-", *tlngno$, "-", *tloffno$, pdspace, "-", *tldia$, punit, pdiamspc, "-", *tcr$, punit, scomm_end, e$ ###removed all spaces from -
if tcr$=0, scomm_str, *t$, "-", plistcomm, "-", *tlngno$, "-", *tloffno$, pdspace, "-", *tldia$, punit, pdiamspc, scomm_end, e$ ###removed all spaces from -
