.050 ball endmill .025 deep for miles
I have had good results taking a roughing pass first with a 60 or 90 deg offset tip engraving tool. then go back for a single finish pass with the ball endmill. The roughing pass go almost full depth, .002-.003 shy. This will get most of the material out towards the tip of the ball mill which is where your SFM is the worst on a ball mill. The offset tip engraving tools can take a little higher chip load than a ball mill from my experience.
I am using a regular LOC 2 flute .0625" ball em in 304ss at 15k rpm, and .01" depth, 15ipm. Turned down to 10k is 10ipm. So I would think your could start by doubling your DOC. I would think you could up your chip load quite a bit because I am running almost double, with a regular LOC flute, which is less ideal. Also run out is critical on small tools like this I have found. I like to be under .0001" when running tools this small.
Good point about the runout. I am using an ER16 collet and it's tough to get it within .0005. Maybe I'll try 15IPM? As far as the depth, I think I should try deeper on the first pass, then smaller as it gets to the bottom where the tool is almost fully engaged.
Thanks!
Yikes .0005" is a bit much for a small tool like that. Fwiw you can get .0001" with an er16. I use mostly Techniks holders now, and with an er16 holder with their regular collets I am almost always under .0002" Sometimes I am lucky and am less then .0001". We always torque to spec, which I have found makes a difference.
We have Briney holders. I guess I'll try to tap it in. Thanks for the help!
