Helical groove, peel mill?
1 of my customers machines level winding screws for winches (a.k.a. diamond screws).
It is a helical groove, 1/2" wide, on a 3" shaft, about 0.4" deep.
He does 4 passes, 0.11" deep each, and uses axis substitution to make the helix. Works OK, but pretty hard on the tool (3 flute).
Has anybody tried peel mill + axis sub?
Peel does wonders on grooves so would using a 3/16" EM to rough out the groove, on the rotary axis be faster/better?
I'm not sure if the rotary axis (on a Haas TM3) would agree.
File would be long but 'tape mode' solves that.
For roughing I would use an endmill with feedmill geometry on the bottom. Axis sub cuts with the tool on centerline and puts a lot of force back into the center cutting portion of the tool. A normal endmill may only be one or two flute effective at the center.
YoDoug,
Thanks for the feedback, do you have an example of such a tool? Mfr/ #?
Like Sandvik high feed CoroMill 210? (It's not ctre cutting)
I also think the lead/lag would be beneficial too. Although it takes a bit more software (for the customer) since it is no longer axis sub but either rolldie or curve5X.
Paul
