Problems Posting using mastercam x5
RICKY J
Im having problems posting using mastercam x5. Im new to mastercam so i dont really know how to setup the post properly . Its for a fanuc 18i-mb controller and i want to post using the ethernet connection at my company. How would i go about setting up the connection and controller.
Sounds like you have the "Send to Machine" box checked. If you uncheck that box, your posted code will be sent to your default NC file directory (unless you have set a different location using Project Manager or change the save location when you are posting) and not attempt to send directly to the machine through a communications port.
You can set it to unchecked in the Post Dialog Defaults tab of the System Configuration. Click on Settings-Configuration-Post Dialog Defaults to get there to change the default state.
Thanks for the info that helped but when it posts to my NC directory it still posts 2 files 1 regular nc file and 1 .err file?
O0000(1)
(DATE=DD-MM-YY - 20-06-13 TIME=HH:MM - 13:30)
(MCX FILE - C:\PROGRAM FILES (X86)\MCAMX5\WORK\SUBPLATE2.MCX-5) <--------------
(NC FILE - X:\AWEA\1.NC) <-------------------------
(MATERIAL - ALUMINUM INCH - 2024)
( T9 | 2" MITSUBISHI HI-FEED | H9 )
Is there any way to get the post not to spit these 2 lines out in the post. The program wont run with them in it
