Fanuc M29 Before G84 Tap?
machinetec
Here is what I did to my mpmaster.pst to put the M29 into the .NC program:
ptap #Canned Tap Cycle
pdrlcommonb
#RH/LH based on spindle direction
if use_pitch, pbld, n, "G95", e
if use_pitch = 0,
pbld, n, "M29", *speed, e
pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
prdrlout, *feed, strcantext, e
else,
if met_tool, pitch = n_tap_thds # Tap pitch (mm per thread)
else, pitch = 1/n_tap_thds # Tap pitch (inches per thread)
prdrlout, *pitch, !feed, strcantext, e
pcom_movea
tapflg = 1
This works good for me.
edit: by making this change, I believe that I only have option for rigid tap now. If for some reason (haven't found one in 3 1/2 years) I would like to post code without rigid tap I would have to edit my post.
[ 09-17-2003, 10:02 PM: Message edited by: Matthew ]
I read my fanuc book and G84 is the standard tapping cycle.M29 The synchronous tap is such that the feed rate during tapping is synchronous with the spindle rotating speed for tapping.The spindle during tapping rotates normally and reversly in synchronism with Z-axis.Accordingly,when this functionis used,a tapping holder for tapping may not be used,and even a milling chuck or slim chuck can also be used for this purpose.
Note:The feed rate at tapping is "F"=Rotating speed x pith.
