Makino program output
I need to output a bunch of programs on our Makino, the problem, if I output as all, it comes out as 1 large program with everything inside/
Is there a parameter setting that anyone is aware of that will let the individual programs output without having to do each one manually?
Guest MTB Technical Services
The 30i series is a little different on the I/O compared to older models.
If saving to a Memory card, you'll need to give it a 8.3 formatted filename
and then try entering the individual O program numbers without the O address, separated by a comma.
You may be limited to only being able to set the low and high O value.
It's been a long time since I've tried just a range of programs.
For RS-232 just skip the file name.
FWIW, the Fanuc help key will access the instructions for I/O.
You can also use something like TextWedge to separate the individual programs from the ALLPROGRAMS file.
I recently did that with a customer who used up the entire control memory.
Thanks for the suggestions
I don't think I'm going to be able to get what I want
The Cimco editor can only handle 1 file at a time and has no "naming" ability like the DNC does
We need to get into some 3D work, then I'll have a MUCH easier time justifying a full blown DNC
