Dynamic Core Milling
Hertz
Hey guys, I was just pulling some older programs and tweaking them a bit and I came across this part. i attached it.
What I'm trying to do is dynamic core around the diameter. Although the file looks correct and the settings seem right, the feed is outputting improper for me.
I am using the Mastercam High feed option to limit my speeds on the corners. Perhaps I'm doing this wrong. Have not seen this issue yet with the amount of Dynamic Cutting I have been doing.
I have my min feedrate to 150 and maximum set to 250. I have set my max air cutting feedrate to 1180, which is the limit of my machine. For some reason though when I post, I was scanning it to see what its doing and it is ramping up to the 1180 IPM while in cut. I guess only those who use the high feed option would know what I'm talking about. Is something wrong with my settings that I can't see? Thanks in advance.
HSM.MCX-7
Hi Hertz,
I'm trying to figure out why you are using High-Feed on the roughing path? The Dynamic Core path will limit the amount of radial engagement the tool will use when removing material. I don't see any internal corners in this path, so I'm not sure running High Feed will give you any benefit. There are many places in your toolpath where the tool uses the "micro-lift" function to come off the floor of the part, and reposition itself to begin the next cut. These passes are already "in the air", so if you set your "Back feedrate" parameter to "1180.", then those should be the moves you are seeing. The tool will pickup off the floor by .01, and move to just before the start of the next cut at your high feedrate value, then slow down and re-engage the material.
Hi Colin. I am using the High feed option to slow down corners. 1180 is too sudden on the machine. If I don't use it, the machine takes the corners too fast and hard. Instead of using the option on the machine for corner smoothing(long story it doesn't work good on our machine) I use the High Feed option in Mastercam. Is this not what its for? Maybe I misunderstand the whole idea behind it? I always thought that's what it was there for.
I do have the back feedrate to 1180 but it is posting to those speeds while in cut, not on the back feedrate. Again this is the first time I see this. I agree with you and usually only gets to those high speeds on the back feedrate. But for some reason the settings I have is different. Maybe I should post the code so you can see what I mean?
This is the output its posting. Note all the way around the part, the speed exceeds my maximum feedrate of 250 while its in cut. Sorry for the long quote. I do not know how to make it small.
G40G80
G00G91G28Z0.
T8M06(3/4 5 FLUTE CARBIDE ENDMILL)
(MAX - Z-1.375)
(MIN - Z3.)
M39
G00G17G90G54X-3.5735Y-6.7431Z3.S5000M3
G43H8Z3.
Z.1
G94G01Z-1.345F250.
X-3.5883Y-6.708Z-1.348F147.32
X-3.6032Y-6.673Z-1.351F167.32
X-3.6117Y-6.6586Z-1.3524F187.32
X-3.6216Y-6.6452Z-1.3537F207.32
X-3.6328Y-6.6328Z-1.355F220.
G02X-3.6687Y-6.5723R.4425F200.
X-3.726Y-6.3863R.5652
X-3.7371Y-6.2076R1.4404
X-3.7372Y-6.2005R1.4404
X-3.7364Y-6.066R63.2723F240.
X-3.736Y-5.9987R63.2722F260.
X-3.7354Y-5.9315R63.2723F280.
X-3.7348Y-5.8642R63.2722F300.
X-3.7341Y-5.7969R63.2722F320.
X-3.7334Y-5.7297R63.2722F340.
X-3.7326Y-5.6624R63.2723F360.
X-3.7317Y-5.5952R63.2723F380.
G01X-3.7313Y-5.565F400.
X-3.7296Y-5.4166F440.
X-3.7287Y-5.3424F460.
X-3.7279Y-5.2681F480.
X-3.727Y-5.1939F500.
X-3.7262Y-5.1197F520.
X-3.7253Y-5.0455F540.
X-3.7245Y-4.9713F560.
X-3.7236Y-4.897F580.
X-3.721Y-4.6744F550.
X-3.7202Y-4.6002F530.
X-3.7193Y-4.5259F510.
X-3.7185Y-4.4517F490.
X-3.7176Y-4.3775F470.
X-3.7167Y-4.3033F450.
X-3.7159Y-4.229F430.
X-3.715Y-4.1548F410.
X-3.7142Y-4.0806F390.
X-3.7133Y-4.0064F370.
X-3.7125Y-3.9322F350.
X-3.7116Y-3.8579F330.
X-3.7107Y-3.7837F310.
X-3.7099Y-3.7095F290.
X-3.709Y-3.6353F270.
X-3.7082Y-3.5611F250.
X-3.6962Y-2.522
X-3.6762Y-.7422
X-3.6751Y.0577F240.
X-3.675Y.1304F220.
G02X-3.6751Y.1392R.3906F200.
X-3.667Y.2182R.3906
X-3.5973Y.3699R.4026
X-3.4731Y.4904R.5268
X-3.3138Y.5742R.7325
X-3.0836Y.6343R1.1849
X-2.773Y.664R2.6917
X-2.2631Y.6738R13.2081
G01X-2.2622
G02X-1.8554Y.6748R98.1963
G01X-1.8242
X1.2958Y.675
X3.1392Y.6749
X3.1848Y.6725
X3.227Y.665F220.
G02X3.3576Y.606R.4042F200.
X3.4958Y.4652R.5275
X3.5772Y.3057R.7457
X3.6355Y.0761R1.2104
X3.6643Y-.2337R2.7599
X3.669Y-.3795R13.5765F240.
X3.6739Y-.7433R13.5765F250.
G01Y-.7442
G02X3.6748Y-1.1197R97.3329
G01Y-1.151
X3.675Y-3.6024F270.
Y-3.6767F290.
Y-3.751F310.
Y-3.8253F330.
Y-3.8996F350.
Y-3.9738F370.
Y-4.0481F390.
Y-4.1224F410.
Y-4.1967F430.
Y-4.271F450.
Y-4.4154F490.
Y-4.4876F510.
Y-4.5598F530.
Y-4.6321F550.
Y-4.7043F570.
X3.6749Y-4.7765F590.
Y-4.8487F610.
Y-4.9931F580.
Y-5.0653F560.
Y-5.1376F540.
Y-5.2098F520.
Y-5.282F500.
Y-5.3542F480.
Y-5.4264F460.
Y-5.4986F440.
Y-5.5708F420.
X3.6748Y-5.6431F400.
Y-5.7153F380.
Y-5.7875F360.
Y-5.8597F340.
Y-5.9319F320.
Y-6.0041F300.
Y-6.0763F280.
Y-6.1486F260.
X3.6714Y-6.1933F240.
X3.6627Y-6.2359F220.
G02X3.6003Y-6.3658R.4105F200.
X3.4573Y-6.5011R.5348
X3.2976Y-6.5802R.759
X3.0687Y-6.6367R1.2367
X2.7596Y-6.6646R2.8302
X2.6139Y-6.6692R13.9562F240.
X2.541Y-6.6709R13.9562F260.
X2.4681Y-6.6722R13.9562F280.
X2.3952Y-6.6731R13.9562F300.
X2.3223Y-6.6737R13.9562F320.
X2.2504Y-6.6739R13.9562F340.
G01X2.2494
G02X2.1117Y-6.6744R92.1486F380.
X2.0428Y-6.6746R92.1486F400.
X1.974Y-6.6747R92.1486F420.
X1.9051Y-6.6748R92.1486F440.
G01X1.8739F460.
X1.7253F500.
X1.6511F520.
X1.5768F540.
X1.5025F560.
X1.4282F580.
X1.3539F600.
X1.2796F620.
X1.2053F640.
X1.131F660.
X1.0568F680.
X.9825Y-6.6749F700.
X.9082F720.
X.8339F740.
X.7596F760.
X.6853F780.
X.611F800.
X.5367F820.
X.4625F840.
X.3882F860.
X.3139F880.
X.2396F900.
X.1653F920.
X.091F940.
X.0167F960.
X-.0575F980.
X-.1318F1000.
X-.2061F1020.
X-.3547F1000.
X-.429F980.
X-.5033Y-6.675F960.
X-.5776F940.
X-.6518F920.
X-.7261F900.
X-.8004F880.
X-.8747F860.
X-.949F840.
X-1.0233F820.
X-1.0976F800.
X-1.1718F780.
X-1.2461F760.
X-1.3959F720.
X-1.4708F700.
X-1.5456F680.
X-1.6205F660.
X-1.6954F640.
X-1.7703F620.
X-1.8451F600.
X-1.92F580.
X-1.9949F560.
X-2.0698F540.
X-2.1446F520.
X-2.2195F500.
X-2.2944F480.
X-2.3693F460.
X-2.4441F440.
X-2.519F420.
X-2.5939F400.
X-2.6688F380.
X-2.7436F360.
X-2.8185F340.
X-2.8934F320.
X-2.9683F300.
X-3.0431F280.
X-3.118F260.
X-3.1619Y-6.6728F240.
X-3.2067Y-6.6649F220.
G02X-3.3184Y-6.6197R.4125F200.
X-3.4797Y-6.4671R.5252
X-3.5626Y-6.3071R.7299
X-3.6209Y-6.0758R1.1749
X-3.6474Y-5.7646R2.6598
X-3.6507Y-5.6186R13.0348F240.
X-3.6517Y-5.5456R13.0349F260.
X-3.6522Y-5.4726R13.0349F280.
X-3.6524Y-5.4049R13.0348F300.
G01Y-5.3996
G02X-3.6522Y-5.3265R13.0348F320.
X-3.6515Y-5.2535R13.0348F340.
X-3.6505Y-5.1179R96.711F380.
X-3.6499Y-5.0501R96.711F400.
X-3.6493Y-4.9823R96.711F420.
X-3.6486Y-4.9145R96.7111F440.
X-3.6478Y-4.8467R96.7111F460.
G01X-3.6475Y-4.8155F480.
X-3.6441Y-4.5184F470.
X-3.6432Y-4.4441F450.
X-3.6424Y-4.3698F430.
X-3.6415Y-4.2956F410.
X-3.6407Y-4.2213F390.
X-3.6398Y-4.147F370.
X-3.6389Y-4.0727F350.
X-3.6381Y-3.9984F330.
X-3.6372Y-3.9242F310.
X-3.6364Y-3.8499F290.
X-3.6355Y-3.7756F270.
X-3.6347Y-3.7013F250.
X-3.6116Y-1.6957
X-3.6018Y-.7615
X-3.6002Y-.1412F240.
X-3.6Y-.0723F220.
G02X-3.4717Y.2685R.5391F200.
X-3.2961Y.4164R.6767
X-3.0671Y.5139R.9808
X-2.7783Y.5689R1.757
X-2.6325Y.5819R4.4405F240.
X-2.4132Y.5922R4.4406F248.41
X-1.7975Y.5995R26.1271F250.
G01X-1.7503Y.5994
X-1.719Y.5995
X1.4013Y.6
X2.8646Y.5996F240.
X2.9378F220.
G02X3.2762Y.465R.5398F200.
X3.4212Y.2879R.6847
X3.5162Y.0589R.9965
X3.5698Y-.2292R1.7923
X3.5812Y-.3612R4.8573F240.
X3.5933Y-.6259R4.8572F250.
X3.5997Y-1.2775R33.3061
X3.5996Y-1.3503R33.3061
G01X3.5997Y-1.3816
X3.5999Y-3.6102F270.
Y-3.6845F290.
Y-3.7588F310.
Y-3.8331F330.
Y-3.9074F350.
Y-3.9817F370.
X3.6Y-4.056F390.
Y-4.1303F410.
Y-4.2046F430.
Y-4.2788F450.
Y-4.3531F470.
Y-4.4274F490.
Y-4.5017F510.
Y-4.6495F550.
Y-4.7973F520.
Y-4.8712F500.
Y-4.9451F480.
Y-5.019F460.
Y-5.0929F440.
Y-5.1668F420.
Y-5.2407F400.
Y-5.3146F380.
Y-5.3885F360.
Y-5.4624F340.
Y-5.5363F320.
Y-5.6102F300.
Y-5.6841F280.
Y-5.758F260.
Y-5.8319F240.
Y-5.9058F220.
G02X3.6002Y-5.9187R.5412F200.
X3.4582Y-6.284R.5412
X3.299Y-6.4147R.6813
X3.0699Y-6.5131R.9753
X2.7809Y-6.5686R1.7448
X2.635Y-6.5817R4.404F240.
X2.4156Y-6.5922R4.404F247.38
X2.2683Y-6.5953R25.89F287.38
X2.1946Y-6.5965R25.89F307.38
X2.1209Y-6.5975R25.89F327.38
X2.0473Y-6.5983R25.89F347.38
X1.9736Y-6.5989R25.89F367.38
X1.8999Y-6.5993R25.89F387.38
X1.8262Y-6.5995R25.89F407.38
G01X1.7997F427.38
X1.7526
X1.7213F447.38
X1.5727F487.38
X1.4984Y-6.5996F507.38
X1.4241F527.38
X1.3498F547.38
X1.2755F567.38
X1.2012F587.38
X1.1269F607.38
X1.0526F627.38
X.9783F647.38
X.904F667.38
X.8298Y-6.5997F687.38
X.7555F707.38
X.6812F727.38
X.6069F747.38
X.5326F767.38
X.4583F787.38
X.384F807.38
X.3097F827.38
X.2354F847.38
X.1611Y-6.5998F867.38
X.0868F887.38
X.0125F907.38
X-.0618F927.38
X-.1361F947.38
X-.2847F920.
X-.3589F900.
X-.4332F880.
X-.5075Y-6.5999F860.
X-.5818F840.
X-.6561F820.
X-.7304F800.
X-.8047F780.
X-.879F760.
X-.9533F740.
X-1.0276F720.
X-1.1019F700.
X-1.1762Y-6.6F680.
X-1.2505F660.
X-1.3248F640.
X-1.3991F620.
X-1.5489F580.
X-1.6239F560.
X-1.6988F540.
X-1.7737F520.
X-1.8487F500.
X-1.9236F480.
X-1.9985F460.
X-2.0735F440.
X-2.1484F420.
X-2.2233F400.
X-2.2983F380.
X-2.3732F360.
X-2.4481F340.
X-2.523F320.
X-2.598F300.
X-2.6729F280.
X-2.7478F260.
X-2.8228F240.
X-2.8977F220.
X-2.9031F200.
G02X-3.2766Y-6.4518R.5448
X-3.4049Y-6.2909R.6842
X-3.5003Y-6.0608R.9789
X-3.5523Y-5.7713R1.7499
X-3.5637Y-5.6253R4.4137F240.
X-3.5716Y-5.4058R4.4137F247.66
X-3.573Y-5.2584R25.8784F287.66
X-3.5734Y-5.1847R25.8785F307.66
X-3.5736Y-5.1111R25.8785F327.66
G01Y-5.0888F347.66
G02X-3.5735Y-5.0374R25.8785
X-3.5733Y-4.9637R25.8785F367.66
X-3.5728Y-4.89R25.8785F387.66
X-3.5721Y-4.8164R25.8785F407.66
X-3.5713Y-4.7427R25.8784F427.66
G01X-3.571Y-4.7114F447.66
X-3.5693Y-4.5629F487.66
X-3.5676Y-4.4143F450.
X-3.5667Y-4.34F430.
X-3.5659Y-4.2657F410.
X-3.565Y-4.1914F390.
X-3.5642Y-4.1171F370.
X-3.5633Y-4.0428F350.
X-3.5625Y-3.9685F330.
X-3.5617Y-3.8943F310.
X-3.5608Y-3.82F290.
X-3.56Y-3.7457F270.
X-3.5591Y-3.6714F250.
X-3.5354Y-1.5913
X-3.5271Y-.7507
X-3.525Y-.3163F240.
X-3.5247Y-.2439F220.
G02X-3.497Y-.0645R.707F200.
X-3.373Y.1637R.6334
X-3.2044Y.3102R.7393
X-2.9807Y.4155R1.0083
X-2.6916Y.4815R1.6611
X-2.3226Y.5128R3.731F227.7
X-1.7506Y.5235R16.2425F250.
X-1.3438Y.5247R95.5827
G01X-1.3126
X1.8075Y.525
X2.6785Y.5244F240.
X2.7511F220.
G02X2.9302Y.4982R.7155F200.
X3.194Y.3456R.6368
X3.3505Y.1345R.7942
X3.4464Y-.126R1.164
X3.4972Y-.442R2.1598
X3.5078Y-.5835R5.9738F240.
X3.5189Y-.8669R5.9739F250.
X3.5248Y-1.5954R44.7131
X3.5247Y-1.684R44.7131
G01X3.5248Y-1.7152
X3.5249Y-3.6467F270.
Y-3.721F290.
Y-3.7953F310.
Y-3.8696F330.
Y-3.9439F350.
Y-4.0181F370.
Y-4.0924F390.
Y-4.1667F410.
Y-4.241F430.
X3.525Y-4.3153F450.
Y-4.3896F470.
Y-4.4639F490.
Y-4.5382F510.
Y-4.6124F530.
Y-4.761F500.
Y-4.8353F480.
X3.5249Y-4.9755F440.
Y-5.0456F420.
X3.5248Y-5.1157F400.
Y-5.1859F380.
Y-5.256F360.
X3.5247Y-5.3261F340.
Y-5.3962F320.
X3.5246Y-5.4663F300.
Y-5.5364F280.
Y-5.6065F260.
X3.5245Y-5.6766F240.
Y-5.7468F220.
G02X3.4996Y-5.9253R.7249F200.
X3.3642Y-6.1737R.636
X3.1936Y-6.3169R.7491
X2.9698Y-6.4191R1.0265
X2.6813Y-6.4829R1.6996
X2.3131Y-6.5132R3.8357F230.87
X2.1791Y-6.5174R17.2474F270.87
X2.1121Y-6.5191R17.2474F290.87
X2.0451Y-6.5205R17.2475F310.87
X1.9781Y-6.5217R17.2474F330.87
X1.9111Y-6.5226R17.2475F350.87
X1.8441Y-6.5232R17.2475F370.87
X1.7771Y-6.5236R17.2474F390.87
X1.7112Y-6.5237R17.2474F410.87
G01X1.71
G02X1.5724Y-6.5242R99.4431F450.87
X1.5035Y-6.5244R99.4431F470.87
X1.4347Y-6.5246R99.4431F490.87
X1.3659Y-6.5247R99.4431F510.87
G01X1.3346F530.87
X1.1861F570.87
X1.1118F590.87
X1.0375F610.87
X.9632F630.87
X.8889F650.87
X.8146F670.87
X.7403F690.87
X.666Y-6.5248F710.87
X.5918F730.87
X.5175F750.87
X.4432F770.87
X.3689F790.87
X.2946F810.87
X.2203F830.87
X.146F850.87
X.0717F870.87
X-.0025F890.87
X-.0768F910.87
X-.2997F880.
X-.374Y-6.5249F860.
X-.4483F840.
X-.5226F820.
X-.5969F800.
X-.6711F780.
X-.7454F760.
X-.8197F740.
X-.894F720.
X-.9683F700.
X-1.0426F680.
X-1.1169F660.
X-1.1912F640.
X-1.2654F620.
X-1.3397F600.
X-1.414Y-6.525F580.
X-1.4883F560.
X-1.5626F540.
X-1.6369F520.
X-1.7112F500.
X-1.7855F480.
X-1.9304Y-6.5249F440.
X-2.0028F420.
X-2.0753F400.
X-2.1477Y-6.5248F380.
X-2.2201F360.
X-2.2926F340.
X-2.365Y-6.5247F320.
X-2.4375F300.
X-2.5099F280.
X-2.5824Y-6.5246F260.
X-2.6548F240.
X-2.7273F220.
G02X-2.9048Y-6.5012R.7408F200.
X-3.1548Y-6.3678R.6326
X-3.2992Y-6.1973R.7397
X-3.4017Y-5.9724R1.0092
X-3.4642Y-5.6826R1.6639
X-3.4912Y-5.3133R3.7376F227.9
X-3.4941Y-5.1703R16.2674F267.9
X-3.4951Y-5.0988R16.2674F287.9
X-3.4958Y-5.0273R16.2674F307.9
X-3.4961Y-4.9558R16.2674F327.9
X-3.4962Y-4.9114R16.2674F347.9
G01X-3.4961Y-4.8843
G02X-3.4959Y-4.8128R16.2674F367.9
X-3.4953Y-4.7413R16.2674F387.9
X-3.4943Y-4.6057R95.6148F427.9
X-3.4938Y-4.5379R95.6148F447.9
X-3.4932Y-4.4701R95.6148F467.9
X-3.4918Y-4.3345R95.6148F450.
G01X-3.4915Y-4.3033F430.
X-3.4898Y-4.1547F390.
X-3.4889Y-4.0804F370.
X-3.4881Y-4.0062F350.
X-3.4872Y-3.9319F330.
X-3.4864Y-3.8576F310.
X-3.4855Y-3.7833F290.
X-3.4847Y-3.7091F270.
X-3.4838Y-3.6348F250.
X-3.4558Y-1.1837
X-3.4511Y-.5008F240.
X-3.4506Y-.4326F220.
G02X-3.4371Y-.2713R1.0717F200.
X-3.2267Y.123R.7
X-3.0164Y.2697R.8721
X-2.7594Y.3639R1.2418
X-2.4446Y.4174R2.2013
X-2.3028Y.4292R5.6151F240.
X-2.0186Y.4421R5.615F250.
X-1.3119Y.4495R33.722
G01X-1.2629
X-1.2316
X1.8887Y.45
X2.5124Y.4493F240.
X2.5817Y.4492F220.
G02X2.7462Y.4331R.9813F200.
X3.1045Y.2449R.6951
X3.2584Y.0376R.848
X3.3583Y-.2197R1.1963
X3.4152Y-.5359R2.1013
X3.4278Y-.678R5.3157F240.
X3.4416Y-.963R5.3157F250.
X3.4494Y-1.6467R29.9095
G01Y-1.6879
Y-1.7192
X3.4498Y-3.5766F270.
Y-3.6509F290.
Y-3.7252F310.
Y-3.7994F330.
Y-3.8737F350.
Y-3.948F370.
Y-4.0223F390.
X3.4499Y-4.0966F410.
Y-4.1709F430.
Y-4.2452F450.
Y-4.3195F470.
Y-4.3938F490.
Y-4.4681F510.
X3.45Y-4.6167F480.
Y-4.691F460.
Y-4.7653F440.
Y-4.8396F420.
X3.4499Y-4.9839F380.
Y-5.056F360.
X3.4498Y-5.1281F340.
Y-5.2003F320.
Y-5.2724F300.
X3.4497Y-5.3446F280.
Y-5.4167F260.
Y-5.4889F240.
X3.4496Y-5.561F220.
G02X3.4376Y-5.7211R1.1074F200.
X3.2315Y-6.1179R.6984
X3.022Y-6.2667R.8649
X2.7649Y-6.3624R1.2287
X2.4496Y-6.4168R2.1731
X2.3078Y-6.4288R5.5318F240.
X2.2367Y-6.4335R5.5318F260.
X2.0234Y-6.442R5.5318F277.26
X1.886Y-6.4446R33.1421F317.26
X1.8172Y-6.4457R33.1421F337.26
X1.7485Y-6.4467R33.1421F357.26
X1.6798Y-6.4475R33.1421F377.26
X1.6111Y-6.4482R33.1421F397.26
X1.5424Y-6.4487R33.1421F417.26
X1.4737Y-6.4491R33.1421F437.26
X1.4049Y-6.4494R33.1421F457.26
X1.3362Y-6.4495R33.1421F477.26
G01X1.317F497.26
G02X1.2675Y-6.4494R33.1421
G01X1.2362Y-6.4495F517.26
X1.0876F557.26
X1.0134F577.26
X.9391Y-6.4496F597.26
X.8648F617.26
X.7905F637.26
X.7162F657.26
X.6419F677.26
X.5676F697.26
X.4933F717.26
X.419F737.26
X.3447F757.26
X.2704Y-6.4497F777.26
X.1961F797.26
X.1218F817.26
X.0476F837.26
X-.0267F857.26
X-.101F877.26
X-.2496F840.
X-.3239F820.
X-.3982Y-6.4498F800.
X-.4725F780.
X-.5468F760.
X-.6211F740.
X-.6954F720.
X-.7697F700.
X-.844F680.
X-.9182F660.
X-.9925Y-6.4499F640.
X-1.0668F620.
X-1.1411F600.
X-1.2154F580.
X-1.2897F560.
X-1.364F540.
X-1.4383F520.
X-1.5126F500.
X-1.5869F480.
X-1.6612Y-6.45F460.
X-1.7355F440.
X-1.8098F420.
X-1.884F400.
X-2.0304Y-6.4499F360.
X-2.1036F340.
X-2.1768Y-6.4498F320.
X-2.25F300.
X-2.3232F280.
X-2.3964Y-6.4497F260.
X-2.4696F240.
X-2.5427F220.
G02X-2.7019Y-6.4383R1.1382F200.
X-3.1Y-6.2338R.6943
X-3.2492Y-6.0235R.8547
X-3.344Y-5.7652R1.2113
X-3.396Y-5.4488R2.1374
X-3.4067Y-5.3067R5.4267F240.
X-3.4106Y-5.2356R5.4268F260.
X-3.4168Y-5.0219R5.4267F274.61
X-3.4179Y-4.8844R32.4324F314.61
X-3.4183Y-4.8157R32.4324F334.61
X-3.4184Y-4.747R32.4324F354.61
X-3.4185Y-4.6896R32.4324F374.61
G01X-3.4184Y-4.6782
G02Y-4.6095R32.4324F394.61
X-3.4182Y-4.5408R32.4324F414.61
X-3.4178Y-4.472R32.4324F434.61
X-3.4172Y-4.4033R32.4324F454.61
X-3.4157Y-4.2658R32.4324F430.
G01X-3.4154Y-4.2346F410.
X-3.4138Y-4.086F370.
X-3.4129Y-4.0118F350.
X-3.4121Y-3.9375F330.
X-3.4112Y-3.8632F310.
X-3.4104Y-3.7889F290.
X-3.4096Y-3.7147F270.
X-3.4087Y-3.6404F250.
X-3.3803Y-1.1151
X-3.3766Y-.6481F240.
X-3.3761Y-.5814F220.
G02X-3.3594Y-.3874R1.31F200.
X-3.1304Y.0366R.7488
X-2.8867Y.1995R.9287
X-2.5968Y.2962R1.4058
X-2.2527Y.3467R2.6354
X-2.123Y.3558R7.1609F240.
X-1.7984Y.3684R7.1608F250.
X-1.033Y.3747R46.4563
X-.9503Y.3746R46.4563
G01X-.9191Y.3747
X2.201Y.375
G02X2.2618Y.3752R9.8064F240.
X2.3958Y.3743R9.8064
X2.4607Y.3732R9.8064F220.
X2.6637Y.3475R1.0535F200.
X3.0429Y.1229R.7468
X3.2032Y-.1218R.9365
X3.2979Y-.4115R1.4239
X3.3473Y-.7552R2.6798
X3.3568Y-.8938R7.4954F240.
X3.3692Y-1.2409R7.4954F250.
X3.3748Y-2.0423R56.9417
X3.3747Y-2.1508R56.9417
G01X3.3748Y-2.182
X3.3749Y-3.5935F270.
Y-3.6678F290.
Y-3.7421F310.
Y-3.8164F330.
Y-3.8906F350.
Y-3.9649F370.
Y-4.0392F390.
Y-4.1135F410.
Y-4.1878F430.
Y-4.2621F450.
Y-4.3364F470.
Y-4.5592F431.21
Y-4.6335F411.21
Y-4.7078F391.21
X3.375Y-4.7821F371.21
Y-4.8564F351.21
Y-4.9307F331.21
Y-5.005F311.21
Y-5.0793F291.21
Y-5.1535F271.21
Y-5.2278F251.21
Y-5.3021F231.21
G02X3.3752Y-5.3376R3.2103F211.21
X3.3707Y-5.5078R3.2103
X3.3327Y-5.7167R.9046F200.
X3.1152Y-6.0498R.7487
X2.8695Y-6.2072R.9464
X2.5801Y-6.2998R1.4456
X2.2369Y-6.348R2.7302
X2.0984Y-6.3572R7.6591F240.
X2.0291Y-6.3609R7.6591F260.
X1.9597Y-6.364R7.6591F280.
X1.8904Y-6.3664R7.6592F300.
X1.821Y-6.3682R7.6591F320.
X1.7516Y-6.3693R7.6591F326.24
X1.6068Y-6.3711R61.693F366.24
X1.5344Y-6.3719R61.6931F386.24
X1.462Y-6.3725R61.6931F406.24
X1.3897Y-6.3731R61.693F426.24
X1.3173Y-6.3736R61.693F446.24
X1.2449Y-6.374R61.693F466.24
X1.1725Y-6.3744R61.693F486.24
X1.1001Y-6.3746R61.6931F506.24
X1.0277Y-6.3748R61.693F526.24
X.9554Y-6.3749R61.6931F546.24
G01X.9258F566.24
X.883
G02X.8106Y-6.3748R61.6931F586.24
G01X.7794F606.24
X.6308F646.24
X.5564F666.24
X.4821F686.24
X.4078F706.24
X.3335F726.24
X.2592F746.24
X.1849F766.24
X.1106F786.24
X.0363F806.24
X-.038F826.24
X-.1866F800.
X-.2609F780.
X-.3353F760.
X-.4096F740.
X-.4839F720.
X-.5582F700.
X-.6325F680.
X-.7068F660.
X-.7811F640.
X-.8554F620.
X-.9297F600.
X-1.004F580.
X-1.0783F560.
X-1.1527Y-6.3749F540.
X-1.227F520.
X-1.3013F500.
X-1.3756F480.
X-1.4499F460.
X-1.5242F440.
X-1.5985F420.
X-1.6728F400.
X-1.7471F380.
X-1.8214F360.
X-1.8957F340.
X-1.9701F320.
X-2.0444F300.
X-2.1187F280.
X-2.193F260.
X-2.2673F240.
X-2.3416F220.
X-2.3529F200.
G02X-2.5212Y-6.3684R2.1604
X-2.7324Y-6.3221R.8451
X-3.0265Y-6.1228R.7463
X-3.186Y-5.8766R.9284
X-3.2786Y-5.5856R1.4111
X-3.3246Y-5.2411R2.654
X-3.3321Y-5.1114R7.2318F240.
X-3.335Y-5.0466R7.2317F260.
X-3.3373Y-4.9816R7.2317F280.
X-3.3391Y-4.9167R7.2317F300.
X-3.3408Y-4.7868R7.2318F317.01
X-3.3412Y-4.6403R49.6868F357.01
G01Y-4.5714F377.01
G02X-3.3413Y-4.567R49.6867
X-3.3412Y-4.4937R49.6868F397.01
X-3.341Y-4.4204R49.6868F417.01
X-3.3407Y-4.3472R49.6867F437.01
X-3.3399Y-4.2006R49.6867F410.
X-3.3393Y-4.1274R49.6868F390.
X-3.3386Y-4.0541R49.6868F370.
X-3.3377Y-3.9808R49.6868F350.
X-3.3368Y-3.9075R49.6867F330.
G01X-3.3365Y-3.8763F310.
X-3.3349Y-3.7292F270.
X-3.334Y-3.6556F250.
X-3.3046Y-1.007
G02X-3.302Y-.7516R19.389F240.
X-3.3009Y-.6877R19.3889F220.
X-3.282Y-.4954R1.3637F200.
X-3.1483Y-.1735R.7956
X-2.9321Y.036R.8401
X-2.6817Y.1619R1.1215
X-2.3622Y.2421R1.7706
X-1.9605Y.2823R3.8129F230.19
X-1.3867Y.2971R13.5061F250.
X-.6595Y.2998R99.2981
G01X-.6043Y.2997
X-.5731Y.2998
X2.1956Y.2993F240.
X2.2704F220.
G02X2.4554Y.2878R1.7144F200.
X2.704Y.2181R.8465
X2.9804Y.0046R.8016
X3.1305Y-.2406R1.0049
X3.2212Y-.5278R1.5127
X3.2704Y-.8702R2.7808
X3.2802Y-1.0088R7.4372F240.
X3.2934Y-1.3559R7.4372F250.
X3.2998Y-2.1684R51.8719
X3.2997Y-2.2662R51.8719
G01Y-2.2975
X3.2995Y-3.6331F270.
Y-3.7073F290.
Y-3.7815F310.
Y-3.8557F330.
Y-3.9299F350.
Y-4.0041F370.
Y-4.0783F390.
Y-4.1525F410.
Y-4.2267F430.
Y-4.3009F450.
X3.2994Y-4.5235F420.
Y-4.5977F400.
Y-4.6719F380.
Y-4.7461F360.
Y-4.8203F340.
Y-4.8945F320.
Y-4.9687F300.
Y-5.0429F280.
Y-5.1171F260.
Y-5.1913F240.
X3.2993Y-5.2655F220.
G02X3.2885Y-5.4497R1.774F200.
X3.2207Y-5.6982R.853
X3.0094Y-5.9763R.7989
X2.7647Y-6.1281R.9984
X2.4772Y-6.2201R1.4995
X2.1346Y-6.27R2.7511
X1.996Y-6.2799R7.3432F240.
X1.9266Y-6.2839R7.3432F260.
X1.8571Y-6.2872R7.3432F280.
X1.7877Y-6.2899R7.3431F300.
X1.6487Y-6.2933R7.3432F319.44
X1.5022Y-6.2954R50.0338F359.44
X1.4289Y-6.2963R50.0338F379.44
X1.3556Y-6.2971R50.0338F399.44
X1.2824Y-6.2978R50.0338F419.44
X1.2091Y-6.2984R50.0338F439.44
X1.1358Y-6.2989R50.0338F459.44
X1.0626Y-6.2992R50.0338F479.44
X.9893Y-6.2995R50.0338F499.44
X.9161Y-6.2996R50.0338F519.44
G01X.8492F539.44
G02X.8428Y-6.2997R50.0337
X.7695Y-6.2996R50.0338F559.44
G01X.7383Y-6.2997F579.44
X.5899Y-6.2996F619.44
X.5158F639.44
X.4416F659.44
X.3674F679.44
X.2933F699.44
X.2191F719.44
X.1449F739.44
X.0708F759.44
X-.0034F779.44
X-.0776F799.44
X-.2259F760.
X-.3001F740.
X-.3742F720.
X-.4484F700.
X-.5226F680.
X-.5967F660.
X-.6709F640.
X-.7451F620.
X-.8192F600.
X-.8934F580.
X-.9676F560.
X-1.0418F540.
X-1.1159F520.
X-1.1901F500.
X-1.2643F480.
X-1.3384F460.
X-1.4126F440.
X-1.4868F420.
X-1.5609F400.
X-1.6351F380.
X-1.7093F360.
X-1.7834F340.
X-1.8576F320.
X-1.9318F300.
X-2.0059F280.
X-2.0801F260.
X-2.1543F240.
X-2.2284F220.
X-2.2368F200.
G02X-2.4484Y-6.2867R1.7429
X-2.6973Y-6.2137R.832
X-2.9704Y-5.9956R.7993
X-3.1162Y-5.7482R1.0077
X-3.2025Y-5.4599R1.5236
X-3.247Y-5.1173R2.8117
X-3.2551Y-4.9786R7.546F240.
X-3.2581Y-4.9092R7.5461F260.
X-3.2606Y-4.8398R7.546F280.
X-3.2624Y-4.7704R7.5461F300.
X-3.2635Y-4.701R7.5461F320.
X-3.264Y-4.6315R7.546F323.82
X-3.2644Y-4.4915R52.7716F363.82
G01Y-4.4291F383.82
Y-4.4215
G02X-3.2643Y-4.3514R52.7716F403.82
X-3.2636Y-4.1414R52.7716F370.
X-3.2632Y-4.0714R52.7716F350.
X-3.2627Y-4.0014R52.7716F330.
X-3.2621Y-3.9313R52.7716F310.
X-3.2614Y-3.8613R52.7716F290.
X-3.2606Y-3.7913R52.7717F270.
X-3.2597Y-3.7213R52.7717F250.
G01X-3.2593Y-3.6901
X-3.23Y-1.0391
G02X-3.2271Y-.8433R7.2145F240.
X-3.225Y-.778R7.2145F220.
X-3.1934Y-.5446R1.2249F200.
X-2.9228Y-.109R.8226
X-2.6804Y.0428R1.0267
X-2.3944Y.1376R1.5105
X-2.0516Y.1909R2.6931
X-1.9126Y.2019R6.8694F240.
X-1.5645Y.2169R6.8695F250.
X-.7777Y.2244R41.0453
G01X-.7158
X-.6845Y.2245
X2.0534Y.2243F240.
X2.1274F220.
G02X2.3444Y.2115R1.9089F200.
X2.5894Y.1463R.907
X2.8989Y-.0881R.8275
X3.063Y-.3674R1.0666
X3.1546Y-.6874R1.6594
X3.2001Y-1.059R3.2483F212.46
X3.2197Y-1.5732R9.5818F250.
X3.2249Y-2.4668R76.9238
X3.2248Y-2.6071R76.9238
G01Y-2.6384
X3.2247Y-3.6851F270.
Y-3.7599F290.
Y-3.8347F310.
Y-3.9094F330.
Y-3.9842F350.
X3.2246Y-4.059F370.
Y-4.1338F390.
Y-4.2085F410.
Y-4.2833F430.
Y-4.4328F400.
Y-4.5076F380.
Y-4.5824F360.
Y-4.6571F340.
Y-4.7319F320.
Y-4.8067F300.
Y-4.8815F280.
X3.2245Y-4.9562F260.
Y-5.031F240.
Y-5.1058F220.
Y-5.1086F200.
G02X3.2146Y-5.3186R2.2252
X3.1572Y-5.5627R.9447
X2.9332Y-5.8807R.8198
X2.6922Y-6.0369R1.0094
X2.4059Y-6.1347R1.4777
X2.0624Y-6.1898R2.6252
X1.9323Y-6.2005R6.5179F240.
X1.8673Y-6.2049R6.5179F260.
X1.8021Y-6.2086R6.518F280.
X1.737Y-6.2116R6.5179F300.
X1.6066Y-6.2158R6.5179F300.96
X1.4635Y-6.2187R33.6232F340.96
X1.392Y-6.2199R33.6232F360.96
X1.3204Y-6.221R33.6232F380.96
X1.2489Y-6.2219R33.6232F400.96
X1.1773Y-6.2227R33.6232F420.96
X1.1058Y-6.2233R33.6233F440.96
X1.0342Y-6.2238R33.6232F460.96
X.9627Y-6.2241R33.6233F480.96
X.8911Y-6.2242R33.6233F500.96
G01X.8543F520.96
X.8196
X.7883Y-6.2243F540.96
X.641F580.96
X.5673F600.96
X.4936F620.96
X.4199F640.96
X.3463F660.96
X.2726F680.96
X.1989Y-6.2244F700.96
X.1253F720.96
X.0516F740.96
X-.0221F760.96
X-.1694F740.
X-.2431F720.
X-.3168F700.
X-.3904F680.
X-.4641F660.
X-.5378F640.
X-.6115F620.
X-.6851F600.
X-.7588F580.
X-.8325Y-6.2245F560.
X-.9061F540.
X-.9798F520.
X-1.0535F500.
X-1.1271F480.
X-1.2008F460.
X-1.2745F440.
X-1.3482F420.
X-1.4218F400.
X-1.4955F380.
X-1.5692F360.
X-1.6428F340.
X-1.7165F320.
X-1.7902F300.
X-1.8639Y-6.2246F280.
X-1.9375F260.
X-2.0112F240.
X-2.0849F220.
X-2.0896F200.
G02X-2.2967Y-6.2153R2.3106
X-2.541Y-6.1593R.947
X-2.8604Y-5.9356R.8119
X-3.0164Y-5.6935R.9972
X-3.1127Y-5.4058R1.4581
X-3.1647Y-5.0612R2.5872
X-3.1741Y-4.931R6.4272F240.
X-3.1778Y-4.8658R6.4273F260.
X-3.1808Y-4.8006R6.4273F280.
X-3.1859Y-4.6049R6.4273F298.86
X-3.1872Y-4.4618R33.1312F338.86
X-3.1876Y-4.3902R33.1312F358.86
X-3.1878Y-4.3186R33.1312F378.86
X-3.1879Y-4.2471R33.1311F398.86
G01Y-4.2354F370.
G02X-3.1873Y-4.0324R33.1311
X-3.1868Y-3.9608R33.1311F350.
X-3.1861Y-3.8893R33.1311F330.
X-3.1853Y-3.8177R33.1311F310.
G01X-3.185Y-3.7865F290.
X-3.1834Y-3.6384F250.
X-3.1543Y-1.0483F240.
X-3.1535Y-.9743F220.
G02X-3.1385Y-.7587R1.9938F200.
X-3.0752Y-.5176R.967
X-2.8502Y-.2046R.8494
X-2.5758Y-.0316R1.0598
X-2.2562Y.0685R1.5994
X-1.8829Y.1202R3.0199F204.85
X-1.7356Y.13R8.4593F244.85
X-1.3669Y.1433R8.4593F250.
X-.514Y.1497R57.2501
X-.4257Y.1496R57.2501
G01X-.3944Y.1497
X1.9055Y.1494F240.
X1.9796F220.
X1.9808F200.
G02X2.2266Y.1369R2.4106
X2.4681Y.0784R.9804
X2.8136Y-.1728R.8512
X2.9788Y-.4499R1.0865
X3.0734Y-.7689R1.66
X3.122Y-1.141R3.1653F209.73
X3.1313Y-1.288R8.9509F249.73
X3.1438Y-1.6561R8.951F250.
X3.1498Y-2.5214R62.3685
X3.1497Y-2.6282R62.3685
G01Y-2.6594
X3.1496Y-3.5541F270.
Y-3.6287F290.
Y-3.7032F310.
Y-3.7778F330.
Y-3.8524F350.
Y-3.9269F370.
Y-4.0015F390.
Y-4.076F410.
Y-4.1506F430.
Y-4.2997F400.
Y-4.3743F380.
X3.1495Y-4.4488F360.
Y-4.5234F340.
Y-4.5979F320.
Y-4.6725F300.
Y-4.747F280.
Y-4.8216F260.
Y-4.8961F240.
Y-4.9707F220.
Y-4.9741F200.
G02X3.1381Y-5.216R2.5667
X3.0826Y-5.457R.9987
X2.8359Y-5.8062R.8482
X2.56Y-5.9746R1.0743
X2.2406Y-6.0715R1.6338
X1.868Y-6.1213R3.1049F207.72
X1.7209Y-6.1308R8.752F247.72
X1.6473Y-6.1346R8.752F267.72
X1.5736Y-6.1378R8.752F287.72
X1.4999Y-6.1403R8.752F307.72
X1.4262Y-6.1423R8.752F327.72
X1.3525Y-6.1436R8.752F347.72
X1.2029Y-6.1455R60.7771F387.72
X1.1282Y-6.1464R60.777F407.72
X1.0534Y-6.1471R60.7771F427.72
X.9786Y-6.1478R60.777F447.72
X.9038Y-6.1483R60.7771F467.72
X.829Y-6.1488R60.777F487.72
X.7542Y-6.1492R60.7771F507.72
X.6794Y-6.1494R60.7771F527.72
X.6046Y-6.1496R60.777F547.72
X.5299Y-6.1497R60.777F567.72
G01X.4876F587.72
X.4551
G02X.3803R60.777F607.72
G01X.3491F627.72
X.1999F667.72
X.1254F687.72
X.0508F707.72
X-.0238Y-6.1496F727.72
X-.1729F700.
X-.2475F680.
X-.322F660.
X-.3966F640.
X-.4712F620.
X-.5457F600.
X-.6203F580.
X-.6949F560.
X-.7694F540.
X-.844F520.
X-.9186Y-6.1495F500.
X-.9931F480.
X-1.0677F460.
X-1.1423F440.
X-1.2168F420.
X-1.2914F400.
X-1.366F380.
X-1.4405F360.
X-1.5151F340.
X-1.5897F320.
X-1.6642F300.
X-1.7388F280.
X-1.8134F260.
X-1.8879Y-6.1494F240.
X-1.9625F220.
X-1.9646F200.
G02X-2.2094Y-6.137R2.4171
X-2.4513Y-6.0783R.9723
X-2.7963Y-5.8249R.8441
X-2.9594Y-5.5459R1.0793
X-3.0507Y-5.2257R1.652
X-3.0951Y-4.853R3.1553F209.4
X-3.1027Y-4.7058R8.9394F249.4
X-3.1055Y-4.6322R8.9394F269.4
X-3.1078Y-4.5586R8.9394F289.4
X-3.1094Y-4.4849R8.9394F309.4
X-3.1104Y-4.4112R8.9394F329.4
X-3.1109Y-4.3376R8.9393F349.4
X-3.1111Y-4.1938R62.4007F389.4
X-3.111Y-4.188R62.4007
Y-4.1132R62.4006F370.
X-3.1108Y-4.0385R62.4007F350.
X-3.1106Y-3.9637R62.4006F330.
X-3.1103Y-3.8889R62.4006F310.
X-3.1099Y-3.8141R62.4006F290.
X-3.1094Y-3.7393R62.4007F270.
X-3.1088Y-3.6646R62.4007F250.
X-3.1055Y-3.3655R62.4006
G01X-3.1052Y-3.3343
X-3.0808Y-1.1902F240.
X-3.08Y-1.1162F220.
G02X-3.0644Y-.87R2.438F200.
X-3.0062Y-.6317R1.034
X-2.7624Y-.2845R.8731
X-2.4893Y-.1127R1.0848
X-2.1708Y-.0112R1.6168
X-1.7975Y.0426R2.994F203.98
X-1.6501Y.053R8.1115F243.98
X-1.2808Y.0674R8.1115F250.
X-.4426Y.0745R49.377
G01X-.3703
X-.3391
X1.7747Y.0744F244.73
X1.8476F224.73
G02X2.0887Y.0646R3.0161F204.73
X2.3254Y.018R1.1083F200.
X2.7144Y-.2387R.8669
X2.8868Y-.5116R1.0802
X2.9887Y-.8302R1.6112
X3.0426Y-1.2037R2.987F203.74
X3.053Y-1.3511R8.1024F243.74
X3.0674Y-1.7204R8.1024F250.
X3.0745Y-2.5585R49.3814
G01Y-2.6308
Y-2.6621
Y-3.6097F270.
Y-3.6825F290.
Y-3.7554F310.
Y-3.8283F330.
Y-3.9012F350.
Y-3.9741F370.
Y-4.047F390.
Y-4.1199F410.
X3.0744Y-4.2657F383.93
Y-4.3386F363.93
Y-4.4115F343.93
Y-4.4843F323.93
Y-4.5572F303.93
Y-4.6301F283.93
Y-4.703F263.93
Y-4.7759F243.93
Y-4.8488F223.93
G02X3.0645Y-5.0902R2.9926F203.93
X3.0175Y-5.3268R1.1047F200.
X2.7602Y-5.7154R.867
X2.487Y-5.8875R1.0816
X2.1685Y-5.989R1.6146
X1.7951Y-6.0427R2.9945F203.99
X1.6477Y-6.0531R8.1261F243.99
X1.5739Y-6.0573R8.126F263.99
X1.5001Y-6.0609R8.126F283.99
X1.4262Y-6.0637R8.1261F303.99
X1.3524Y-6.0659R8.126F323.99
X1.2785Y-6.0675R8.126F336.04
X1.1384Y-6.0696R49.5212F376.04
X1.0684Y-6.0706R49.5211F396.04
X.9983Y-6.0714R49.5212F416.04
X.9283Y-6.0721R49.5211F436.04
X.8583Y-6.0728R49.5211F456.04
X.7882Y-6.0733R49.5212F476.04
X.7182Y-6.0738R49.5211F496.04
X.6482Y-6.0741R49.5212F516.04
X.5781Y-6.0743R49.5211F536.04
X.5081Y-6.0745R49.5211F556.04
G01X.4409F576.04
X.4381
G02X.368R49.5211F596.04
G01X.3368F616.04
X.191F656.04
X.1181F676.04
X.0452F696.04
X-.0278F716.04
X-.1736F680.
X-.2465Y-6.0744F660.
X-.3194F640.
X-.3923F620.
X-.4652F600.
X-.5381F580.
X-.611F560.
X-.684F540.
X-.7569F520.
X-.8298F500.
X-.9027F480.
X-.9756F460.
X-1.0485Y-6.0743F440.
X-1.1214F420.
X-1.1943F400.
X-1.2672F380.
X-1.3402F360.
X-1.4131F340.
X-1.486F320.
X-1.5589F300.
X-1.6318F280.
X-1.7047F260.
X-1.7776Y-6.0742F240.
X-1.8505F220.
G02X-2.0951Y-6.0623R2.6221F200.
X-2.3338Y-6.0092R1.0454
X-2.7139Y-5.7384R.8635
X-2.8766Y-5.4611R1.1002
X-2.9699Y-5.1417R1.6622
X-3.0165Y-4.7688R3.1127F207.98
X-3.0247Y-4.6215R8.5268F247.98
X-3.0278Y-4.5478R8.5268F267.98
X-3.0303Y-4.474R8.5267F287.98
X-3.0322Y-4.4002R8.5267F307.98
X-3.0334Y-4.3265R8.5268F327.98
X-3.034Y-4.2527R8.5267F344.23
X-3.0345Y-4.0283R55.0798F330.
X-3.0344Y-3.963R55.0798
X-3.0343Y-3.8906R55.0797F310.
X-3.0341Y-3.8182R55.0798F290.
X-3.0337Y-3.7458R55.0798F270.
X-3.0333Y-3.6734R55.0797F250.
X-3.0298Y-3.3113R55.0797
G01X-3.0295Y-3.2801
X-3.0064Y-1.2496F227.52
G02X-2.994Y-1.0093R3.099F207.52
X-2.9477Y-.7759R1.1754F200.
X-2.6685Y-.3574R.8945
X-2.3957Y-.1894R1.1166
X-2.0783Y-.0886R1.6538
X-1.7054Y-.0342R3.0229F204.96
X-1.5579Y-.0234R7.9825F244.96
X-1.1885Y-.0083R7.9825F250.
X-.3418Y-.0006R46.4253
G01X-.2777
X-.2465Y-.0005
X1.7217Y-.0006F227.68
X1.7308F207.68
G02X1.9956Y-.0119R3.1039
X2.2304Y-.0585R1.1463F200.
X2.6478Y-.3405R.8902
X2.8139Y-.6141R1.1215
X2.9131Y-.9314R1.6691
X2.9665Y-1.304R3.0631F206.31
X2.9771Y-1.4514R8.1222F246.31
X2.9919Y-1.8206R8.1222F250.
X2.9995Y-2.6667R47.3919
X2.9994Y-2.7313R47.3919
G01X2.9995Y-2.7625
X2.9994Y-3.6374F270.
Y-3.7103F290.
Y-3.7832F310.
Y-3.8561F330.
Y-3.929F350.
Y-4.0019F370.
Y-4.0748F390.
Y-4.2935F358.22
Y-4.3664F338.22
Y-4.4393F318.22
Y-4.5122F298.22
X2.9993Y-4.5851F278.22
Y-4.658F258.22
Y-4.7309F238.22
G02X2.9905Y-4.9693R3.4268F218.22
X2.9501Y-5.2019R1.2201F200.
X2.6503Y-5.6553R.8913
X2.3757Y-5.8183R1.134
X2.0586Y-5.9152R1.6955
X1.6536Y-5.9701R3.2508F212.54
X1.517Y-5.979R9.2038F252.54
X1.4487Y-5.9827R9.2038F272.54
X1.3804Y-5.9858R9.2038F292.54
X1.312Y-5.9885R9.2038F312.54
X1.2437Y-5.9906R9.2038F332.54
X1.1753Y-5.9923R9.2037F352.54
X1.1069Y-5.9934R9.2038F357.63
X.9636Y-5.9952R64.953F397.63
X.8919Y-5.996R64.9529F417.63
X.8202Y-5.9968R64.9529F437.63
X.7486Y-5.9974R64.953F457.63
X.6769Y-5.998R64.953F477.63
X.6053Y-5.9985R64.953F497.63
X.5336Y-5.9989R64.953F517.63
X.4619Y-5.9992R64.953F537.63
X.3903Y-5.9994R64.953F557.63
X.3186Y-5.9996R64.953F577.63
X.2469Y-5.9997R64.953F597.63
G01X.2036F617.63
X.1753
G02X.1036Y-5.9996R64.953F637.63
G01X.0724F657.63
X-.1502F644.49
X-.2244F624.49
X-.2986F604.49
X-.3728F584.49
X-.447F564.49
X-.5212F544.49
X-.5954F524.49
X-.6696Y-5.9995F504.49
X-.7438F484.49
X-.818F464.49
X-.8922F444.49
X-.9664F424.49
X-1.0406F404.49
X-1.1148F384.49
X-1.189F364.49
X-1.2633F344.49
X-1.3375Y-5.9994F324.49
X-1.4117F304.49
X-1.4859F284.49
X-1.5601F264.49
X-1.6343F244.49
X-1.7085F224.49
X-1.7177F204.49
G02X-1.9832Y-5.9877R3.009
X-2.2188Y-5.9394R1.1214F200.
X-2.6335Y-5.6516R.8834
X-2.7954Y-5.3754R1.1212
X-2.8899Y-5.057R1.6771
X-2.9382Y-4.684R3.0895F207.2
X-2.947Y-4.5365R8.2352F247.2
X-2.9503Y-4.4628R8.2353F267.2
X-2.953Y-4.3889R8.2352F287.2
X-2.9551Y-4.3151R8.2352F307.2
X-2.9565Y-4.2412R8.2352F327.2
X-2.9572Y-4.1674R8.2352F338.29
X-2.958Y-3.9572R48.2976F330.
X-2.9581Y-3.8872R48.2976F310.
G01Y-3.8799F290.
G02X-2.958Y-3.8171R48.2976
X-2.9579Y-3.7471R48.2975F270.
X-2.9576Y-3.677R48.2976F250.
X-2.954Y-3.2568R48.2975
G01X-2.9537Y-3.2256
X-2.933Y-1.4226F240.
X-2.9322Y-1.3504F220.
G02X-2.9154Y-1.074R2.7754F200.
X-2.8481Y-.8011R1.1219
X-2.5759Y-.4302R.9151
X-2.3033Y-.2655R1.1464
X-1.9869Y-.1656R1.6895
X-1.5814Y-.1078R3.1742F210.02
X-1.0656Y-.0832R8.5159F250.
X-.2126Y-.0756R47.9902
G01X-.155Y-.0757
X-.1238Y-.0756
X1.5945
X1.6013F220.
G02X1.8637Y-.0845R3.8313
X2.0936Y-.122R1.3023F200.
X2.5797Y-.4395R.9109
X2.7405Y-.7134R1.1592
X2.8375Y-1.0298R1.7212
X2.8934Y-1.4346R3.2563F212.72
X2.9178Y-1.9816R8.9998F250.
X2.9246Y-2.8691R57.9976
X2.9245Y-2.9539R57.9976
G01X2.9246Y-2.9852
X2.9245Y-3.6499F270.
Y-3.7238F290.
X2.9244Y-3.7976F310.
Y-3.8715F330.
Y-3.9454F350.
Y-4.0192F370.
Y-4.2408F338.79
Y-4.3147F318.79
Y-4.3885F298.79
X2.9243Y-4.4624F278.79
Y-4.5363F258.79
Y-4.6101F238.79
Y-4.6141F218.79
G02X2.9139Y-4.8816R3.4448
X2.8726Y-5.113R1.2439F200.
X2.5768Y-5.5663R.908
X2.3045Y-5.7328R1.1365
X1.9879Y-5.8337R1.6751
X1.6153Y-5.8891R3.0283F205.14
X1.4677Y-5.9003R7.8332F245.14
X1.3938Y-5.9048R7.8332F265.14
X1.32Y-5.9087R7.8331F285.14
X1.246Y-5.9118R7.8332F305.14
X1.1721Y-5.9143R7.8331F325.14
X1.0981Y-5.916R7.8332F329.93
X.9515Y-5.9186R42.9132F369.93
X.8781Y-5.9198R42.9132F389.93
X.8048Y-5.9208R42.9133F409.93
X.7315Y-5.9216R42.9133F429.93
X.6582Y-5.9224R42.9132F449.93
X.5849Y-5.923R42.9133F469.93
X.5115Y-5.9235R42.9133F489.93
X.4382Y-5.9239R42.9133F509.93
X.3649Y-5.9241R42.9133F529.93
X.2916Y-5.9242R42.9132F549.93
G01X.2572F569.93
X.2182
X.187Y-5.9243F589.93
X.0386F629.93
X-.0357F649.93
X-.1841F617.14
X-.2583F597.14
X-.3325F577.14
X-.4067F557.14
X-.481F537.14
X-.5552F517.14
X-.6294F497.14
X-.7036F477.14
X-.7778F457.14
X-.852F437.14
X-.9262F417.14
X-1.0005F397.14
X-1.0747F377.14
X-1.1489F357.14
X-1.2231F337.14
X-1.2973F317.14
X-1.3715F297.14
X-1.4457F277.14
X-1.52F257.14
X-1.5942F237.14
X-1.5988F217.14
G02X-1.8661Y-5.9138R3.3929
X-2.0981Y-5.8716R1.2221F200.
X-2.5496Y-5.5708R.8996
X-2.7126Y-5.2962R1.1334
X-2.8092Y-4.9783R1.6775
X-2.8623Y-4.5721R3.1654F209.73
X-2.8707Y-4.4248R8.5374F249.73
X-2.874Y-4.3511R8.5374F269.73
X-2.8766Y-4.2774R8.5374F289.73
X-2.8787Y-4.2036R8.5373F309.73
X-2.88Y-4.1299R8.5374F329.73
X-2.8808Y-4.0561R8.5374F344.44
X-2.8814Y-3.916R48.4061F330.
X-2.8816Y-3.846R48.406F310.
Y-3.7759R48.4061F290.
G01Y-3.7629F270.
Y-3.7059
G02X-2.8815Y-3.6359R48.406F250.
X-2.8777Y-3.1456R48.4061
G01X-2.8774Y-3.1143
X-2.8589Y-1.4896F246.25
G02X-2.8461Y-1.2196R3.6837F220.
X-2.7942Y-.9523R1.2961F200.
X-2.4906Y-.5078R.9312
X-2.2187Y-.3442R1.1686
X-1.9031Y-.2438R1.7065
X-1.4977Y-.1846R3.1664F209.77
X-1.3505Y-.174R8.3182F249.77
X-.9816Y-.1589R8.3182F250.
X-.1213Y-.1507R45.1662
G01X-.0707
X-.0395
X1.4919
X1.4929F220.
G02X1.7602Y-.1596R4.0279
X2.0269Y-.2051R1.3408F200.
X2.5056Y-.5299R.9278
X2.664Y-.8035R1.187
X2.7605Y-1.119R1.7505
X2.817Y-1.5235R3.2764F213.38
X2.8423Y-2.0707R8.8734F250.
X2.8496Y-2.9652R55.0702
X2.8495Y-3.0433R55.0702
G01Y-3.0745
Y-3.5926F270.
Y-3.6666F290.
Y-3.7406F310.
Y-3.8146F330.
X2.8494Y-3.8887F350.
Y-3.9627F370.
Y-4.1847F345.75
Y-4.2587F325.75
Y-4.3327F305.75
Y-4.4067F285.75
Y-4.4807F265.75
Y-4.4835F240.
G02X2.8449Y-4.681R4.3458
X2.8414Y-4.7477R4.3458F220.
X2.7988Y-5.013R1.3873F200.
X2.4813Y-5.4967R.926
X2.2088Y-5.6587R1.1712
X1.8931Y-5.7579R1.7184
X1.488Y-5.8161R3.2027F210.96
X1.3408Y-5.8265R8.4486F250.96
X1.2671Y-5.8307R8.4485F270.96
X1.1934Y-5.8343R8.4485F290.96
X1.1197Y-5.8373R8.4485F310.96
X1.0459Y-5.8396R8.4485F330.96
X.9721Y-5.8413R8.4485F342.64
X.832Y-5.8437R46.0546F382.64
X.762Y-5.8447R46.0546F402.64
X.6919Y-5.8457R46.0546F422.64
X.6219Y-5.8465R46.0546F442.64
X.5518Y-5.8472R46.0546F462.64
X.4817Y-5.8478R46.0546F482.64
X.4117Y-5.8483R46.0546F502.64
X.3416Y-5.8487R46.0546F522.64
X.2715Y-5.849R46.0546F542.64
X.2015Y-5.8492R46.0546F562.64
X.1314Y-5.8493R46.0546F582.64
G01X.1128F602.64
X.0614
X.0301F622.64
X-.1842F619.4
X-.2556F599.4
X-.327F579.4
X-.3985F559.4
X-.4699F539.4
X-.5413F519.4
X-.6128F499.4
X-.6842F479.4
X-.7556Y-5.8494F459.4
X-.8271F439.4
X-.8985F419.4
X-.9699F399.4
X-1.0413F379.4
X-1.1128F359.4
X-1.1842F339.4
X-1.2556F319.4
X-1.3271F299.4
X-1.3985F279.4
X-1.4699F259.4
X-1.4725F220.
G02X-1.7377Y-5.8408R4.1243
X-1.9652Y-5.8064R1.383F200.
X-2.4837Y-5.4691R.9189
X-2.6403Y-5.1938R1.1764
X-2.7337Y-4.8769R1.7381
X-2.7857Y-4.4717R3.2607F212.86
X-2.7936Y-4.3349R8.8588F252.86
X-2.7968Y-4.2665R8.8588F272.86
X-2.7994Y-4.1981R8.8589F292.86
X-2.8015Y-4.1296R8.8589F312.86
X-2.803Y-4.0612R8.8589F332.86
X-2.8046Y-3.9242R8.8588F330.
X-2.8054Y-3.7849R32.749F290.
X-2.8055Y-3.7152R32.749F270.
G01Y-3.6747F250.
Y-3.6455
G02X-2.8051Y-3.5061R32.7489F240.
X-2.8047Y-3.4365R32.7489F220.
G01Y-3.436F200.
G03X-2.8055Y-3.4248R.075
G02X-2.8376Y-2.9976R2.8621
X-2.8151Y-2.6394R2.8621
G03X-2.8051Y-2.4978R5.5365F240.
X-2.7968Y-2.2851R5.5365F250.
X-2.7858Y-1.6327R53.5546
G02X-2.7782Y-1.4081R4.7431F240.
X-2.7733Y-1.3334R4.7431F220.
X-2.7273Y-1.0697R1.4149F200.
X-2.3789Y-.5637R.9512
X-2.07Y-.3958R1.2486
X-1.7219Y-.3017R1.9686
X-1.2886Y-.2514R3.8772F232.12
X-.7132Y-.2308R11.6285F250.
X-.6203Y-.2295R26.8498F220.
G03X-.6053Y-.2278R.075F200.
G02X.0021Y-.1624R2.8517
X.461Y-.1995R2.8517
G03X.745Y-.2183R3.181F210.25
X1.298Y-.2247R23.8311F250.
G01X1.2994
X1.3149F240.
G02X1.5611Y-.2294R6.4544
X1.6264Y-.2322R6.4544F220.
X1.8868Y-.2679R1.5643F200.
X2.2612Y-.446R.952
X2.5029Y-.7238R1.0092
X2.6401Y-1.0381R1.4038
X2.7149Y-1.3829R2.3221
X2.7311Y-1.5142R4.9335F240.
X2.7561Y-1.8439R4.9335F250.
X2.7697Y-2.3126R14.991F240.
X2.7705Y-2.3796R14.9909F220.
G03X2.7722Y-2.3946R.0749F200.
G02X2.8377Y-3.0021R2.8519
X2.8004Y-3.4611R2.8519
G03X2.7817Y-3.7451R3.1828F210.3
X2.7789Y-3.8837R23.8427F250.3
X2.7778Y-3.953R23.8427F270.3
X2.7769Y-4.0223R23.8427F290.3
X2.7762Y-4.0916R23.8427F310.3
X2.7757Y-4.1609R23.8427F330.3
X2.7753Y-4.2981R23.8427F319.47
G01Y-4.2995
Y-4.3149F280.
G02X2.7742Y-4.4303R6.4537
X2.7727Y-4.4957R6.4536F260.
X2.7706Y-4.5611R6.4536F240.
X2.7678Y-4.6264R6.4537F220.
X2.732Y-4.887R1.564F200.
X2.5539Y-5.2613R.9518
X2.2761Y-5.5029R1.0093
X1.9618Y-5.6401R1.4039
X1.617Y-5.7149R2.3227
X1.4857Y-5.7311R4.9344F240.
X1.4199Y-5.7379R4.9345F260.
X1.156Y-5.7561R4.9345F261.86
X1.0221Y-5.7615R14.9844F301.86
X.8213Y-5.7673R14.9845F280.
X.7544Y-5.7686R14.9844F260.
X.6874Y-5.7697R14.9844F240.
X.6205Y-5.7704R14.9844F220.
G03X.6054Y-5.7722R.075F200.
G02X-.0021Y-5.8377R2.852
X-.4613Y-5.8004R2.852
G03X-.7453Y-5.7817R3.1841F210.35
X-.884Y-5.7789R24.2662F250.35
X-.9533Y-5.7777R24.2662F270.35
X-1.0226Y-5.7768R24.2663F290.35
X-1.0919Y-5.7761R24.2662F310.35
X-1.1613Y-5.7756R24.2662F330.35
X-1.2999Y-5.7752R24.2662F300.
G02X-1.4471Y-5.7735R6.6795F260.
X-1.5206Y-5.7715R6.6795F240.
X-1.5941Y-5.7686R6.6795F220.
X-1.8535Y-5.7353R1.6124F200.
X-2.1961Y-5.5862R.9583
X-2.4528Y-5.3174R.9703
X-2.6002Y-5.0029R1.3179
X-2.6792Y-4.6554R2.1462
X-2.6969Y-4.5121R4.3294F240.
X-2.718Y-4.2242R4.3293F245.28
X-2.7233Y-4.0791R11.4501F285.28
X-2.7268Y-3.9339R11.4501F260.
X-2.7279Y-3.8613R11.4501F240.
X-2.7285Y-3.7887R11.4501F220.
G03X-2.7313Y-3.769R.075F200.
G02X-2.8087Y-3.403R2.8375
G01X-2.8119Y-3.3866Z-1.3543F220.
X-2.8167Y-3.3706Z-1.3536F240.
X-2.8231Y-3.3552Z-1.3529F260.
X-2.8778Y-3.2619Z-1.3483F300.
X-2.8886Y-3.2459Z-1.3475F280.
X-2.9012Y-3.2313Z-1.3466F260.
X-2.9154Y-3.2181Z-1.3458F240.
X-2.931Y-3.2067Z-1.345F220.
G03X-3.0227Y-3.1796R.1688F200.
X-3.1915Y-3.3484R.1688
X-3.1417Y-3.468R.1688
G01X-3.0496Y-3.5597F240.
X-3.0036Y-3.6055F260.
X-2.9576Y-3.6513F280.
X-2.9115Y-3.6971F260.
X-2.8655Y-3.7429F240.
X-2.8195Y-3.7888F220.
G02X-2.7797Y-3.8826R.1349F200.
G03X-2.7775Y-4.0179R8.2496F240.
X-2.7756Y-4.0855R8.2495F260.
X-2.7731Y-4.1532R8.2495F280.
X-2.7665Y-4.2883R8.2495F268.3
X-2.7624Y-4.3559R8.2495F248.3
X-2.7577Y-4.4234R8.2496F228.3
X-2.6994Y-4.8353R3.1222F208.3
X-2.5915Y-5.1708R1.7409F200.
X-2.3856Y-5.4887R1.1701
X-1.8982Y-5.7781R.9825
X-1.6295Y-5.8187R1.5045
X-1.4806Y-5.825R5.3152F240.
X-1.406Y-5.8266R5.3151F260.
X-1.3315Y-5.8272R5.3151F271.77
X-1.1857Y-5.828R93.9869F311.77
X-1.1128Y-5.8284R93.9869F320.
G02X-.9913Y-5.8293R14.02F280.
X-.9305Y-5.8301R14.0199F260.
X-.8698Y-5.8312R14.02F240.
X-.809Y-5.8326R14.02F220.
X-.727Y-5.8712R.1349F200.
G01X-.6357Y-5.9621F240.
X-.59Y-6.0076F260.
X-.4987Y-6.0985F240.
X-.453Y-6.1439F220.
G03X-.3339Y-6.1931R.1688F200.
X-.1651Y-6.0243R.1688
X-.1927Y-5.932R.1688
G01X-.2042Y-5.9164Z-1.3458F220.
X-.2174Y-5.9023Z-1.3466F240.
X-.2321Y-5.8898Z-1.3475F260.
X-.2483Y-5.8789Z-1.3483F280.
X-.3417Y-5.8247Z-1.3529
X-.3571Y-5.8185Z-1.3536F260.
X-.3732Y-5.8137Z-1.3543F240.
X-.3896Y-5.8106Z-1.355F220.
G02X-.7107Y-5.7471R2.8375F200.
G03X-.9141Y-5.7184R1.4452
X-1.0447Y-5.7104R5.8617F240.
X-1.1101Y-5.7075R5.8617F260.
X-1.1755Y-5.7054R5.8617F280.
X-1.2409Y-5.7039R5.8616F285.4
G02X-1.388Y-5.6997R6.676F260.
X-1.4615Y-5.6964R6.676F240.
X-1.5349Y-5.6923R6.676F220.
X-1.7957Y-5.6523R1.5291F200.
X-2.1667Y-5.4674R.9533
X-2.4035Y-5.1864R1.0188
X-2.5366Y-4.8711R1.4157
X-2.6121Y-4.4919R2.3779
X-2.6256Y-4.3625R5.2496F240.
X-2.6311Y-4.2978R5.2497F260.
X-2.6429Y-4.1031R5.2496F240.
X-2.6452Y-4.0381R5.2497F220.
G03X-2.6501Y-4.014R.0751F200.
G02X-2.7373Y-3.7473R2.8375
G01X-2.7425Y-3.7314Z-1.3543F220.
X-2.7492Y-3.7161Z-1.3536F240.
X-2.7575Y-3.7016Z-1.3529F260.
X-2.8233Y-3.6158Z-1.3483F300.
X-2.836Y-3.6013Z-1.3475F280.
X-2.8504Y-3.5883Z-1.3466F260.
X-2.8661Y-3.577Z-1.3458F240.
X-2.883Y-3.5676Z-1.345F220.
G03X-2.9564Y-3.5508R.1688F200.
X-3.1252Y-3.7196R.1688
X-3.0739Y-3.8407R.1688
G01X-2.9747Y-3.937F240.
X-2.9251Y-3.9852F260.
X-2.8754Y-4.0333F280.
X-2.8258Y-4.0815F260.
X-2.7762Y-4.1296F240.
X-2.7266Y-4.1778F220.
G02X-2.6859Y-4.2651R.135F200.
G03X-2.6368Y-4.6746R3.5886F220.
X-2.5344Y-5.0365R1.9092F200.
X-2.3479Y-5.3586R1.2456
X-1.8012Y-5.7046R1.0018
X-1.5358Y-5.7446R1.5874
X-1.389Y-5.7521R6.1584F240.
X-1.3156Y-5.7545R6.1584F260.
X-1.2421Y-5.7561R6.1583
G02X-1.1383Y-5.7594R4.1545F220.
X-1.0586Y-5.7968R.135F200.
G01X-.9553Y-5.8971F240.
X-.9036Y-5.9472F260.
X-.8003Y-6.0475F240.
X-.7486Y-6.0976F220.
G03X-.6311Y-6.1452R.1687F200.
X-.4624Y-5.9765R.1687
X-.4814Y-5.8986R.1687
G01X-.4913Y-5.882Z-1.3458F220.
X-.503Y-5.8666Z-1.3466F240.
X-.5164Y-5.8527Z-1.3475F260.
X-.5315Y-5.8403Z-1.3483F280.
X-.6191Y-5.7771Z-1.3529
X-.6338Y-5.7694Z-1.3536F260.
X-.6493Y-5.7631Z-1.3543F240.
X-.6653Y-5.7584Z-1.355F220.
G02X-.9034Y-5.6899R2.8375F200.
G03X-1.0657Y-5.6561R.9637
X-1.3277Y-5.6322R4.1302F231.82
G02X-1.5658Y-5.6078R3.2288F211.82
X-1.8321Y-5.5382R1.2269F200.
X-2.2295Y-5.2435R.9627
X-2.4064Y-4.9372R1.2124
X-2.5065Y-4.5878R1.863
X-2.5508Y-4.254R3.3053F214.32
G03X-2.5579Y-4.2282R.075F200.
G02X-2.6559Y-3.9988R2.8375
G01X-2.6626Y-3.9834Z-1.3543F220.
X-2.6707Y-3.9689Z-1.3536F240.
X-2.6802Y-3.9552Z-1.3529F260.
X-2.7538Y-3.8759Z-1.3483F300.
X-2.7678Y-3.8626Z-1.3475F280.
X-2.7833Y-3.851Z-1.3466F260.
X-2.7999Y-3.8412Z-1.3458F240.
X-2.8176Y-3.8334Z-1.345F220.
G03X-2.8766Y-3.8228R.1688F200.
X-3.0454Y-3.9916R.1688
X-2.9928Y-4.114R.1688
G01X-2.8959Y-4.2059F240.
X-2.8475Y-4.2519F260.
X-2.799Y-4.2978F280.
X-2.7021Y-4.3898F260.
X-2.6537Y-4.4358F240.
X-2.6053Y-4.4817F220.
G02X-2.5637Y-4.5653R.1376F200.
G03X-2.4671Y-4.9254R2.0031
X-2.2914Y-5.2488R1.3061
X-1.7231Y-5.6287R1.0214
X-1.4621Y-5.6733R1.6877
X-1.3864Y-5.6801R3.6506F220.
G02X-1.3041Y-5.7167R.1349F200.
G01X-1.2048Y-5.811F240.
X-1.1551Y-5.8582F260.
X-1.1054Y-5.9053F280.
X-1.0557Y-5.9525F260.
X-1.006Y-5.9996F240.
X-.9564Y-6.0468F220.
G03X-.8402Y-6.0932R.1688F200.
X-.6714Y-5.9244R.1688
X-.6854Y-5.8573R.1688
G01X-.6941Y-5.84Z-1.3458F220.
X-.7047Y-5.8238Z-1.3466F240.
X-.7171Y-5.809Z-1.3475F260.
X-.7312Y-5.7955Z-1.3483F280.
X-.8141Y-5.7264Z-1.3529
X-.8283Y-5.7176Z-1.3536F260.
X-.8433Y-5.7102Z-1.3543F240.
X-.8589Y-5.7044Z-1.355F220.
G02X-1.0729Y-5.6268R2.8375F200.
G03X-1.2336Y-5.5859R.9579
X-1.3759Y-5.5616R10.3132F240.
X-1.4471Y-5.5502R10.3132F220.
G02X-1.7009Y-5.4854R1.5819F200.
X-2.1853Y-5.1189R1.001
X-2.3462Y-4.8096R1.2978
X-2.4366Y-4.4631R2.0237
G03X-2.4458Y-4.4386R.075
G02X-2.5627Y-4.2182R2.8375
G01X-2.5706Y-4.2035Z-1.3543F220.
X-2.5799Y-4.1897Z-1.3536F240.
X-2.5905Y-4.1768Z-1.3529F260.
X-2.6705Y-4.104Z-1.3483F300.
X-2.6856Y-4.0919Z-1.3475F280.
X-2.702Y-4.0817Z-1.3466F260.
X-2.7194Y-4.0734Z-1.3458F240.
X-2.7377Y-4.0671Z-1.345F220.
G03X-2.7832Y-4.0609R.1687F200.
X-2.9519Y-4.2296R.1687
X-2.8981Y-4.3532R.1687
G01X-2.7923Y-4.4515F240.
X-2.7394Y-4.5007F260.
X-2.6865Y-4.5499F280.
X-2.6337Y-4.5991F300.
X-2.5808Y-4.6483F280.
X-2.5279Y-4.6975F260.
X-2.475Y-4.7467F240.
X-2.4221Y-4.7959F220.
G02X-2.3832Y-4.8589R.1442F200.
G03X-2.1975Y-5.1894R1.3037
X-1.6727Y-5.55R1.0566
X-1.6072Y-5.5692R1.2305
G02X-1.5598Y-5.5978R.135
G01X-1.4547Y-5.6955F240.
X-1.4022Y-5.7443F260.
X-1.3497Y-5.7932F280.
X-1.2447Y-5.8908F260.
X-1.1922Y-5.9397F240.
X-1.1397Y-5.9885F220.
G03X-1.0248Y-6.0337R.1688F200.
X-.856Y-5.8649R.1688
X-.866Y-5.8078R.1688
G01X-.8736Y-5.79Z-1.3458F220.
X-.8831Y-5.7732Z-1.3466F240.
X-.8945Y-5.7576Z-1.3475F260.
X-.9078Y-5.7433Z-1.3483F280.
X-.9861Y-5.669Z-1.3529F294.91
X-.9997Y-5.6593Z-1.3536F274.91
X-1.0142Y-5.651Z-1.3543F254.91
X-1.0294Y-5.6442Z-1.355F234.91
G02X-1.2354Y-5.555R3.3236F214.91
G03X-1.3809Y-5.5051R1.4285F200.
G02X-1.5747Y-5.4426R3.2426F212.27
X-1.8547Y-5.2975R1.1873F200.
X-2.1536Y-4.9718R1.0741
X-2.2816Y-4.6927R1.421
G03X-2.292Y-4.6728R.075
G02X-2.4617Y-4.4112R2.8375
G01X-2.4724Y-4.3947Z-1.3542F220.
X-2.485Y-4.3797Z-1.3533F240.
X-2.4992Y-4.3662Z-1.3525F260.
X-2.5149Y-4.3544Z-1.3517F280.
X-2.5319Y-4.3445Z-1.3508F300.
X-2.5499Y-4.3367Z-1.35F320.
X-2.5687Y-4.331Z-1.3492
X-2.588Y-4.3275Z-1.3483F300.
X-2.6076Y-4.3263Z-1.3475F280.
X-2.6272Y-4.3274Z-1.3467F260.
X-2.6465Y-4.3308Z-1.3458F240.
X-2.6653Y-4.3363Z-1.345F220.
G03X-2.7769Y-4.4951R.1688F200.
X-2.7217Y-4.6199R.1688
G01X-2.6127Y-4.7192F240.
X-2.5581Y-4.7688F260.
X-2.5036Y-4.8185F280.
X-2.4491Y-4.8681F300.
X-2.3945Y-4.9178F320.
X-2.34Y-4.9674F340.
X-2.2855Y-5.0171F360.
X-2.2309Y-5.0668F380.
X-2.1764Y-5.1164F400.
X-2.1218Y-5.1661F420.
X-2.0673Y-5.2157F440.
X-2.0128Y-5.2654F460.
X-1.9582Y-5.315F440.
X-1.9037Y-5.3647F420.
X-1.8492Y-5.4143F400.
X-1.7946Y-5.464F380.
X-1.7401Y-5.5136F360.
X-1.6856Y-5.5633F340.
X-1.631Y-5.6129F320.
X-1.5765Y-5.6626F300.
X-1.522Y-5.7123F280.
X-1.4674Y-5.7619F260.
X-1.4129Y-5.8116F240.
X-1.3584Y-5.8612F220.
G03X-1.2448Y-5.9052R.1688F200.
X-1.0814Y-5.7786R.1688
G01X-1.0776Y-5.7593Z-1.3458F220.
X-1.076Y-5.7398Z-1.3467F240.
X-1.0768Y-5.7201Z-1.3475F260.
X-1.0798Y-5.7008Z-1.3483F280.
X-1.0851Y-5.6819Z-1.3492F300.
X-1.0925Y-5.6637Z-1.35F320.
X-1.102Y-5.6465Z-1.3508
X-1.1134Y-5.6305Z-1.3517F300.
X-1.1266Y-5.616Z-1.3525F280.
X-1.1414Y-5.6031Z-1.3533F260.
X-1.1575Y-5.592Z-1.3542F240.
X-1.1749Y-5.5828Z-1.355F220.
G02X-1.4378Y-5.4463R2.8375F200.
X-1.5482Y-5.386R18.0776F240.
X-1.6033Y-5.3555R18.0776F220.
X-1.8514Y-5.1781R1.3711F200.
X-2.0024Y-5.0114R1.1756
G03X-2.0089Y-5.0039R.075
G02X-2.3106Y-4.6469R2.8375
G01X-2.3229Y-4.6316Z-1.3542F220.
X-2.3369Y-4.6179Z-1.3533F240.
X-2.3524Y-4.6058Z-1.3525F260.
X-2.3692Y-4.5957Z-1.3517F280.
X-2.3871Y-4.5875Z-1.3508F300.
X-2.4058Y-4.5815Z-1.35F320.
X-2.425Y-4.5777Z-1.3492
X-2.4446Y-4.5761Z-1.3483F300.
X-2.4642Y-4.5769Z-1.3475F280.
X-2.4836Y-4.5799Z-1.3467F260.
X-2.5025Y-4.5851Z-1.3458F240.
X-2.5207Y-4.5925Z-1.345F220.
G03X-2.6169Y-4.7449R.1688F200.
X-2.561Y-4.8702R.1688
G01X-2.4535Y-4.9671F240.
X-2.3997Y-5.0155F260.
X-2.346Y-5.0639F280.
X-2.2922Y-5.1124F300.
X-2.2384Y-5.1608F320.
X-2.1847Y-5.2092F340.
X-2.1309Y-5.2576F360.
X-2.0771Y-5.3061F380.
X-1.9696Y-5.4029F360.
X-1.9159Y-5.4513F340.
X-1.8621Y-5.4998F320.
X-1.8083Y-5.5482F300.
X-1.7546Y-5.5966F280.
X-1.7008Y-5.645F260.
X-1.647Y-5.6935F240.
X-1.5933Y-5.7419F220.
G03X-1.4803Y-5.7853R.1688F200.
X-1.3213Y-5.6728R.1688
G01X-1.3158Y-5.654Z-1.3458F220.
X-1.3126Y-5.6346Z-1.3467F240.
X-1.3116Y-5.615Z-1.3475F260.
X-1.3129Y-5.5955Z-1.3483F280.
X-1.3165Y-5.5762Z-1.3492F300.
X-1.3223Y-5.5574Z-1.35F320.
X-1.3302Y-5.5395Z-1.3508
X-1.3402Y-5.5226Z-1.3517F300.
X-1.352Y-5.5069Z-1.3525F280.
X-1.3656Y-5.4928Z-1.3533F260.
X-1.3808Y-5.4803Z-1.3542F240.
X-1.3972Y-5.4696Z-1.355F220.
G02X-2.0261Y-4.9866R2.8374F200.
G01X-2.0383Y-4.9753Z-1.3543F220.
X-2.0516Y-4.9652Z-1.3536F240.
X-2.0659Y-4.9565Z-1.3529F260.
X-2.1756Y-4.9089Z-1.3478F280.
X-2.1954Y-4.8971Z-1.3468F260.
X-2.2134Y-4.8828Z-1.3458F240.
X-2.2272Y-4.8685Z-1.345F220.
G02X-2.2618Y-4.8071R.1815F200.
G03X-2.2829Y-4.7717R.1687
G02X-2.8899Y-3.0309R2.8934F200.52
G03X-2.9012Y-2.9794R.1988F200.
G02X-2.9065Y-2.9379R.1654
X-2.9064Y-2.9308R.1654
G01X-2.9059Y-2.9224Z-1.3454F220.
X-2.9023Y-2.8997Z-1.3463F240.
X-2.8957Y-2.8777Z-1.3473F260.
X-2.886Y-2.8566Z-1.3483F250.
X-2.8353Y-2.7614Z-1.3529
X-2.8296Y-2.7457Z-1.3536
X-2.8255Y-2.7295Z-1.3543F243.25
X-2.8229Y-2.713Z-1.355F223.25
G02X-2.757Y-2.3262R2.9727F203.25
G03X-2.7287Y-2.0853R1.9095F200.
X-2.7219Y-1.9538R10.6187F240.
X-2.7131Y-1.6905R10.6187F250.
G02X-2.7043Y-1.4912R4.5965F240.
X-2.6994Y-1.4249R4.5965F220.
X-2.6539Y-1.1632R1.4748F200.
X-2.3131Y-.6543R.9634
X-2.0066Y-.4813R1.2398
X-1.6585Y-.3826R1.9244
X-1.2243Y-.329R3.7261F227.55
X-.9834Y-.3157R8.2334F240.
X-.9231Y-.3135R8.2334F220.
G03X-.9019Y-.3096R.075F200.
G02X-.5707Y-.2205R2.8375
G01X-.5546Y-.2163Z-1.3543F220.
X-.5389Y-.2106Z-1.3536F240.
X-.5238Y-.2033Z-1.3529F250.
X-.434Y-.1431Z-1.3483F270.
X-.4187Y-.1313Z-1.3475F280.
X-.4048Y-.1179Z-1.3466F260.
X-.3926Y-.1029Z-1.3458F240.
X-.3821Y-.0866Z-1.345F220.
G03X-.3603Y-.0037R.1688F200.
X-.5291Y.1651R.1688
X-.6476Y.1164R.1688
G01X-.7477Y.0176F240.
X-.7977Y-.0318F260.
X-.8478Y-.0812F280.
X-.8978Y-.1306F260.
X-.9478Y-.18F240.
X-.9979Y-.2294F220.
G02X-1.095Y-.2688R.1394F200.
G01X-1.0981
G03X-1.231Y-.2769R4.7845F240.
X-1.5619Y-.3131R4.7844F220.
X-1.9216Y-.3954R2.3199F200.
X-2.2478Y-.5449R1.4429
X-2.5557Y-.8337R1.0557
X-2.7164Y-1.1967R1.0401
X-2.7545Y-1.4587R1.6959
X-2.7616Y-1.5884R7.6554F240.
X-2.7643Y-1.6532R7.6554F260.
X-2.7664Y-1.7181R7.6554F280.
X-2.768Y-1.783R7.6554
G02X-2.7714Y-1.8886R6.8561F240.
X-2.7738Y-1.9413R6.8561F220.
X-2.813Y-2.022R.135F200.
G01X-2.9114Y-2.1192F240.
X-2.9605Y-2.1677F260.
X-3.0589Y-2.2648F240.
X-3.1081Y-2.3134F220.
G03X-3.1583Y-2.4335R.1688F200.
X-2.9895Y-2.6023R.1688
X-2.9083Y-2.5814R.1688
G01X-2.892Y-2.5712Z-1.3458F220.
X-2.8769Y-2.5591Z-1.3466F240.
X-2.8632Y-2.5454Z-1.3475F260.
X-2.8511Y-2.5301Z-1.3483F280.
X-2.7899Y-2.4412Z-1.3529F250.
X-2.7825Y-2.4263Z-1.3536
X-2.7765Y-2.4107Z-1.3543F247.22
X-2.7722Y-2.3945Z-1.355F227.22
G02X-2.6969Y-2.1164R3.0901F207.22
G03X-2.662Y-1.9185R1.2914F200.
X-2.6498Y-1.7841R6.6618F240.
X-2.6403Y-1.6495R6.6618F223.8
G02X-2.6151Y-1.4098R2.9887F203.8
X-2.5442Y-1.1443R1.2379F200.
X-2.2196Y-.7227R.9836
X-1.9128Y-.5543R1.2727
X-1.5656Y-.4576R1.9733
X-1.1621Y-.4067R3.7316F220.
G03X-1.1379Y-.4006R.075F200.
G02X-.8755Y-.3009R2.8376
G01X-.8599Y-.295Z-1.3543F220.
X-.8449Y-.2876Z-1.3536F240.
X-.8308Y-.2787Z-1.3529F250.
X-.7482Y-.2089Z-1.3483F290.
X-.7343Y-.1955Z-1.3475F280.
X-.722Y-.1805Z-1.3466F260.
X-.7115Y-.1643Z-1.3458F240.
X-.7029Y-.147Z-1.345F220.
G03X-.6894Y-.0808R.1687F200.
X-.8581Y.0879R.1687
X-.9787Y.0372R.1687
G01X-1.0719Y-.0579F240.
X-1.1185Y-.1054F260.
X-1.165Y-.153F280.
X-1.2582Y-.2481F260.
X-1.3048Y-.2957F240.
X-1.3514Y-.3433F220.
G02X-1.4393Y-.3839R.1387F200.
G03X-1.8277Y-.4691R2.4121
X-2.1532Y-.6146R1.4805
X-2.4701Y-.903R1.0818
X-2.6419Y-1.2789R1.0598
X-2.6844Y-1.5481R1.7969
X-2.695Y-1.6777R5.6401F220.
G02X-2.7322Y-1.7531R.1349F200.
G01X-2.825Y-1.8478F240.
X-2.8714Y-1.8952F260.
X-2.9178Y-1.9426F280.
X-2.9642Y-1.99F260.
X-3.0106Y-2.0373F240.
X-3.057Y-2.0847F220.
G03X-3.1052Y-2.2028R.1688F200.
X-2.9364Y-2.3716R.1688
X-2.867Y-2.3566R.1688
G01X-2.8499Y-2.3476Z-1.3458F220.
X-2.8339Y-2.3368Z-1.3466F240.
X-2.8192Y-2.3242Z-1.3475F260.
X-2.806Y-2.3098Z-1.3483F280.
X-2.738Y-2.226Z-1.3529F250.
X-2.7294Y-2.2117Z-1.3536
X-2.7223Y-2.1966Z-1.3543
X-2.7167Y-2.1808Z-1.355F232.5
G02X-2.6334Y-1.9415R3.2494F212.5
G03X-2.5943Y-1.7753R1.0779F200.
X-2.5718Y-1.6332R9.9503F240.
X-2.5613Y-1.5619R9.9503F220.
G02X-2.5032Y-1.3105R1.7293F200.
X-2.1252Y-.7892R1.0147
X-1.818Y-.6263R1.3141
X-1.4716Y-.5321R2.0324
X-1.3824Y-.5169R2.9179F201.37
G03X-1.3582Y-.5087R.0749F200.
G02X-1.1055Y-.3867R2.8375
G01X-1.0905Y-.3794Z-1.3543F220.
X-1.0762Y-.3707Z-1.3536F240.
X-1.0629Y-.3607Z-1.3529F250.
X-.9866Y-.284Z-1.3483F290.
X-.9739Y-.2694Z-1.3475F280.
X-.963Y-.2535Z-1.3466F260.
X-.9539Y-.2364Z-1.3458F240.
X-.9469Y-.2184Z-1.345F220.
G03X-.9385Y-.1659R.1687F200.
X-1.1072Y.0028R.1687
X-1.229Y-.0491R.1687
G01X-1.3258Y-.15F240.
X-1.3743Y-.2005F260.
X-1.4227Y-.251F280.
X-1.4711Y-.3014F300.
X-1.5195Y-.3519F280.
X-1.5679Y-.4024F260.
X-1.6164Y-.4528F240.
X-1.6648Y-.5033F220.
G02X-1.7326Y-.542R.1406F200.
G03X-2.0808Y-.6968R1.5047
X-2.4042Y-.9961R1.0981
X-2.5666Y-1.3395R1.1145
X-2.5941Y-1.45R2.0559
G02X-2.6262Y-1.5053R.135
G01X-2.7194Y-1.6025F240.
X-2.7661Y-1.6511F260.
X-2.8127Y-1.6997F280.
X-2.906Y-1.7969F260.
X-2.9526Y-1.8455F240.
X-2.9992Y-1.8941F220.
G03X-3.0462Y-2.0109R.1687F200.
X-2.8775Y-2.1796R.1687
X-2.8183Y-2.169R.1687
G01X-2.8007Y-2.1612Z-1.3458F220.
X-2.784Y-2.1514Z-1.3466F240.
X-2.7685Y-2.1398Z-1.3475F260.
X-2.7544Y-2.1264Z-1.3483F280.
X-2.681Y-2.0472Z-1.3529F250.
X-2.6715Y-2.0335Z-1.3536
X-2.6634Y-2.0189Z-1.3543F240.
X-2.6568Y-2.0035Z-1.355F220.
G02X-2.5693Y-1.7958R2.8375F200.
G03X-2.5224Y-1.6567R1.1305
X-2.4977Y-1.568R13.0219F220.
G02X-2.4172Y-1.3286R1.966F200.
X-2.0097Y-.8398R1.0735
X-1.7011Y-.6896R1.4001
X-1.6131Y-.6613R1.806
G03X-1.5926Y-.6516R.075
G02X-1.3253Y-.491R2.8375
G01X-1.3109Y-.4825Z-1.3543F220.
X-1.2975Y-.4726Z-1.3536F240.
X-1.2851Y-.4614Z-1.3529F250.
X-1.2157Y-.3785Z-1.3483F270.
X-1.2042Y-.3629Z-1.3475F280.
X-1.1947Y-.3461Z-1.3466F260.
X-1.1871Y-.3283Z-1.3458F240.
X-1.1816Y-.3098Z-1.345F220.
G03X-1.1771Y-.2712R.1688F200.
X-1.3459Y-.1024R.1688
X-1.469Y-.1557R.1688
G01X-1.5712Y-.2647F240.
X-1.6223Y-.3192F260.
X-1.6734Y-.3737F280.
X-1.7245Y-.4282F300.
X-1.7756Y-.4826F320.
X-1.8267Y-.5371F340.
X-1.8778Y-.5916F360.
X-1.9289Y-.6461F340.
X-1.98Y-.7006F320.
X-2.0311Y-.7551F300.
X-2.0821Y-.8095F280.
X-2.1332Y-.864F260.
X-2.2085Y-.9319F220.
G03X-2.3422Y-1.0866R1.1364F200.
G01X-2.3475Y-1.0925F220.
X-2.445Y-1.1965F260.
X-2.4938Y-1.2485F280.
X-2.5425Y-1.3005F300.
X-2.5913Y-1.3525F320.
X-2.64Y-1.4044F340.
X-2.6888Y-1.4564F320.
X-2.7376Y-1.5084F300.
X-2.7863Y-1.5604F280.
X-2.8351Y-1.6124F260.
X-2.8839Y-1.6644F240.
X-2.9326Y-1.7164F220.
G03X-2.9783Y-1.8319R.1688F200.
X-2.8095Y-2.0007R.1688
X-2.7605Y-1.9933R.1688
G01X-2.7423Y-1.9867Z-1.3458F220.
X-2.7251Y-1.978Z-1.3466F240.
X-2.7089Y-1.9674Z-1.3475F260.
X-2.6939Y-1.9548Z-1.3483F250.
X-2.6158Y-1.8804Z-1.3529
X-2.6054Y-1.8673Z-1.3536
X-2.5964Y-1.8532Z-1.3543F240.
X-2.5888Y-1.8384Z-1.355F220.
G02X-2.4705Y-1.6043R2.8375F200.
G03X-2.3913Y-1.4447R4.0513F220.
G02X-2.2588Y-1.2208R1.6103F200.
X-1.9077Y-.8978R1.1792
G03X-1.8966Y-.8895R.075
G02X-1.5766Y-.6408R2.8375
G01X-1.561Y-.629Z-1.3542F220.
X-1.5468Y-.6154Z-1.3533F240.
X-1.5343Y-.6003Z-1.3525F260.
X-1.5236Y-.5838Z-1.3517F280.
X-1.515Y-.5662Z-1.3508F300.
X-1.5084Y-.5477Z-1.35F320.
X-1.504Y-.5286Z-1.3492
X-1.5019Y-.5091Z-1.3483F300.
X-1.502Y-.4895Z-1.3475F280.
X-1.5044Y-.47Z-1.3467F260.
X-1.5091Y-.451Z-1.3458F240.
X-1.5159Y-.4326Z-1.345F220.
G03X-1.6704Y-.3317R.1688F200.
X-1.795Y-.3868R.1688
G01X-1.8922Y-.4932F240.
X-1.9407Y-.5464F260.
X-1.9893Y-.5996F280.
X-2.0378Y-.6528F300.
X-2.0864Y-.706F320.
X-2.1349Y-.7592F340.
X-2.1835Y-.8125F360.
X-2.232Y-.8657F380.
X-2.2806Y-.9189F400.
X-2.3777Y-1.0253F380.
X-2.4263Y-1.0785F360.
X-2.4748Y-1.1317F340.
X-2.5234Y-1.1849F320.
X-2.5719Y-1.2381F300.
X-2.6205Y-1.2913F280.
X-2.669Y-1.3445F260.
X-2.7176Y-1.3977F240.
X-2.7661Y-1.4509F220.
G03X-2.8102Y-1.5647R.1687F200.
X-2.6951Y-1.7247R.1687
G01X-2.6761Y-1.7298Z-1.3458F220.
X-2.6567Y-1.7327Z-1.3467F240.
X-2.6371Y-1.7334Z-1.3475F260.
X-2.6176Y-1.7317Z-1.3483F280.
X-2.5983Y-1.7278Z-1.3492F300.
X-2.5797Y-1.7217Z-1.35F290.
X-2.5619Y-1.7135Z-1.3508F270.
X-2.5451Y-1.7032Z-1.3517F250.
X-2.5297Y-1.6911Z-1.3525
X-2.5158Y-1.6773Z-1.3533
X-2.5036Y-1.6619Z-1.3542F240.
X-2.4932Y-1.6453Z-1.355F220.
G02X-1.8853Y-.8794R2.8375F200.
G01X-1.8734Y-.8677Z-1.3543F220.
X-1.8627Y-.8549Z-1.3536F240.
X-1.8533Y-.8411Z-1.3529F250.
X-1.8004Y-.7338Z-1.3478
X-1.7877Y-.7146Z-1.3468
X-1.7725Y-.6973Z-1.3458F240.
X-1.7576Y-.6843Z-1.345F220.
G02X-1.6945Y-.6527R.1807F200.
G03X-1.6581Y-.6334R.1688
G02X.0021Y-.11R2.895F200.57
X.074Y-.1109R2.895
G03X.1259Y-.1014R.1988F200.
G02X.1616Y-.0975R.1654
X.1747Y-.0981R.1654
G01X.183Y-.0988Z-1.3454F220.
X.2056Y-.1032Z-1.3463F240.
X.2273Y-.1107Z-1.3473F260.
X.2481Y-.1211Z-1.3483F280.
X.3414Y-.1752Z-1.3529F270.
X.3569Y-.1815Z-1.3536F250.
X.3729Y-.1862Z-1.3543F240.
X.3893Y-.1893Z-1.355F220.
G02X.7105Y-.2529R2.8375F200.
G03X.9138Y-.2815R1.4427
X1.0567Y-.29R6.4769F240.
X1.2714Y-.2967R6.4769F250.
G02X1.4932Y-.3044R5.8642F240.
X1.5671Y-.3088R5.8643F220.
X1.8287Y-.3511R1.4903F200.
X2.342Y-.6871R.9565
X2.517Y-.9933R1.2268
X2.6168Y-1.3416R1.9058
X2.6684Y-1.7434R3.6236F224.4
X2.6864Y-2.0767R7.7701F220.
G03X2.6903Y-2.0978R.075F200.
G02X2.7795Y-2.429R2.8375
G01X2.7836Y-2.4452Z-1.3543F220.
X2.7894Y-2.4608Z-1.3536F240.
X2.7966Y-2.4759Z-1.3529F250.
X2.8569Y-2.5657Z-1.3483F270.
X2.8686Y-2.581Z-1.3475F280.
X2.8821Y-2.5949Z-1.3466F260.
X2.8971Y-2.6071Z-1.3458F240.
X2.9133Y-2.6176Z-1.345F220.
G03X2.9963Y-2.6394R.1688F200.
X3.1651Y-2.4706R.1688
X3.1176Y-2.3534R.1688
G01X3.018Y-2.2503F240.
X2.9682Y-2.1988F260.
X2.9184Y-2.1472F280.
X2.8686Y-2.0957F260.
X2.8188Y-2.0442F240.
X2.769Y-1.9927F220.
G02X2.731Y-1.9023R.1354F200.
G03X2.723Y-1.7693R4.7446F240.
X2.6865Y-1.4382R4.7447F220.
X2.6033Y-1.0781R2.2982F200.
X2.452Y-.7519R1.4291
X2.1599Y-.4456R1.0456
X1.7947Y-.2891R1.0355
X1.5329Y-.2541R1.7189
X1.404Y-.2483R8.9806F240.
X1.3395Y-.246R8.9806F260.
X1.2749Y-.2443R8.9807F246.85
X1.2104Y-.243R8.9806F226.85
G02X1.119Y-.24R3.0791F206.85
X1.0357Y-.1995R.135F200.
G01X.9412Y-.1017F240.
X.8939Y-.0528F260.
X.7994Y.045F240.
X.7522Y.0939F220.
G03X.6308Y.1454R.1688F200.
X.462Y-.0234R.1688
X.4812Y-.1014R.1688
G01X.491Y-.118Z-1.3458F220.
X.5028Y-.1333Z-1.3466F240.
X.5162Y-.1472Z-1.3475F260.
X.5313Y-.1597Z-1.3483F280.
X.6188Y-.2228Z-1.3529F250.
X.6336Y-.2306Z-1.3536
X.6491Y-.2368Z-1.3543F240.
X.6651Y-.2415Z-1.355F220.
G02X.9035Y-.3102R2.8375F200.
G03X1.0658Y-.3439R.9634
X1.3268Y-.3672R3.9206F233.41
G02X1.5623Y-.3892R3.7588F220.
X1.8268Y-.4518R1.3034F200.
X2.2596Y-.763R.9726
X2.4361Y-1.0679R1.2334
X2.538Y-1.4158R1.8977
X2.593Y-1.8374R3.6037F220.
G03X2.5991Y-1.8615R.075F200.
G02X2.6988Y-2.1238R2.8375
G01X2.7048Y-2.1394Z-1.3543F220.
X2.7122Y-2.1544Z-1.3536F240.
X2.7211Y-2.1685Z-1.3529F250.
X2.7909Y-2.2511Z-1.3483F290.
X2.8044Y-2.265Z-1.3475F280.
X2.8193Y-2.2773Z-1.3466F260.
X2.8355Y-2.2878Z-1.3458F240.
X2.8528Y-2.2964Z-1.345F220.
G03X2.919Y-2.3099R.1688F200.
X3.0878Y-2.1411R.1688
X3.0379Y-2.0214R.1688
G01X2.942Y-1.9262F240.
X2.8941Y-1.8785F260.
X2.8462Y-1.8309F280.
X2.7503Y-1.7357F260.
X2.7024Y-1.688F240.
X2.6545Y-1.6404F220.
G02X2.616Y-1.5638R.135F200.
G03X2.5346Y-1.1885R2.427
X2.3918Y-.8624R1.4934
X2.1063Y-.5429R1.0834
X1.7305Y-.3681R1.0478
X1.4598Y-.3252R1.7539
X1.3697Y-.318R4.6136F220.
G02X1.2845Y-.2791R.1351F200.
G01X1.1916Y-.1868F240.
X1.1451Y-.1406F260.
X1.0987Y-.0944F280.
X1.0522Y-.0483F260.
X1.0058Y-.0021F240.
X.9593Y.044F220.
G03X.8404Y.093R.1687F200.
X.6717Y-.0757R.1687
X.6855Y-.1428R.1687
G01X.6942Y-.16Z-1.3458F220.
X.7048Y-.1762Z-1.3466F240.
X.7172Y-.191Z-1.3475F260.
X.7314Y-.2045Z-1.3483F280.
X.8142Y-.2737Z-1.3529F250.
X.8284Y-.2825Z-1.3536
X.8434Y-.2898Z-1.3543F240.
X.859Y-.2957Z-1.355F220.
G02X1.072Y-.3728R2.8374F200.
G03X1.2316Y-.4133R.9331
X1.3721Y-.4365R6.9282F240.
X1.4425Y-.447R6.9282F220.
G02X1.6936Y-.5053R1.7373F200.
X2.2142Y-.8851R1.0112
X2.3759Y-1.1928R1.3159
X2.4691Y-1.5391R2.0438
X2.4822Y-1.616R2.9402F202.13
G03X2.4905Y-1.6402R.075F200.
G02X2.6126Y-1.8929R2.8375
G01X2.6199Y-1.9079Z-1.3543F220.
X2.6286Y-1.9222Z-1.3536F240.
X2.6387Y-1.9355Z-1.3529F250.
X2.7154Y-2.0117Z-1.3483F290.
X2.73Y-2.0244Z-1.3475F280.
X2.7459Y-2.0353Z-1.3466F260.
X2.763Y-2.0444Z-1.3458F240.
X2.781Y-2.0514Z-1.345F220.
G03X2.8334Y-2.0597R.1687F200.
X3.0021Y-1.891R.1687
X2.9509Y-1.7699R.1687
G01X2.8488Y-1.6708F240.
X2.7977Y-1.6212F260.
X2.7467Y-1.5717F280.
X2.6956Y-1.5221F300.
X2.6445Y-1.4726F280.
X2.5935Y-1.423F260.
X2.5424Y-1.3734F240.
X2.4914Y-1.3239F220.
G02X2.4513Y-1.2508R.1493F200.
G03X2.299Y-.9179R1.4801
X1.9871Y-.5905R1.0858
X1.6378Y-.4345R1.1282
G02X1.5736Y-.4176R1.2189
X1.5272Y-.3881R.135
G01X1.4307Y-.2945F240.
X1.3825Y-.2477F260.
X1.3343Y-.2009F280.
X1.2378Y-.1073F260.
X1.1896Y-.0604F240.
X1.1413Y-.0136F220.
G03X1.0238Y.034R.1687F200.
X.8551Y-.1347R.1687
X.865Y-.1919R.1687
G01X.8726Y-.2097Z-1.3458F220.
X.8822Y-.2265Z-1.3466F240.
X.8936Y-.2421Z-1.3475F260.
X.9069Y-.2564Z-1.3483F280.
X.9852Y-.3307Z-1.3529F250.
X.9988Y-.3404Z-1.3536
X1.0133Y-.3487Z-1.3543
X1.0285Y-.3555Z-1.355F230.85
G02X1.2325Y-.4436R3.1993F210.85
G03X1.3756Y-.4916R1.291F200.
G02X1.5034Y-.529R4.1985F240.
X1.5668Y-.5492R4.1985F220.
X1.8146Y-.6618R1.2776F200.
X2.161Y-.9971R1.0751
X2.3111Y-1.3059R1.3987
X2.3362Y-1.3833R1.7975
G03X2.346Y-1.4038R.075
G02X2.5069Y-1.6708R2.8375
G01X2.5155Y-1.6852Z-1.3543F220.
X2.5254Y-1.6986Z-1.3536F240.
X2.5366Y-1.711Z-1.3529F250.
X2.6196Y-1.7803Z-1.3483F270.
X2.6353Y-1.7916Z-1.3475F280.
X2.6521Y-1.8012Z-1.3466F260.
X2.6699Y-1.8087Z-1.3458F240.
X2.6884Y-1.8142Z-1.345F220.
G03X2.7267Y-1.8186R.1688F200.
X2.8955Y-1.6498R.1688
X2.8423Y-1.5269R.1688
G01X2.7342Y-1.4252F240.
X2.6801Y-1.3744F260.
X2.6261Y-1.3236F280.
X2.572Y-1.2728F300.
X2.518Y-1.2219F320.
X2.4639Y-1.1711F340.
X2.3558Y-1.0695F320.
X2.3017Y-1.0186F300.
X2.2477Y-.9678F280.
X2.1936Y-.917F260.
X2.1395Y-.8661F240.
X2.0855Y-.8153F220.
G03X1.9707Y-.7074R1.2609F200.
G01X1.8668Y-.6097F240.
X1.8148Y-.5608F260.
X1.7629Y-.512F280.
X1.7109Y-.4631F300.
X1.659Y-.4143F320.
X1.607Y-.3654F340.
X1.555Y-.3166F320.
X1.5031Y-.2677F300.
X1.4511Y-.2189F280.
X1.3992Y-.1701F260.
X1.3472Y-.1212F240.
X1.2953Y-.0724F220.
G03X1.1797Y-.0266R.1687F200.
X1.011Y-.1953R.1687
X1.018Y-.2437R.1687
G01X1.0246Y-.2618Z-1.3458F220.
X1.0332Y-.2791Z-1.3466F240.
X1.0438Y-.2953Z-1.3475F260.
X1.0563Y-.3104Z-1.3483F280.
X1.1304Y-.3889Z-1.3529F250.
X1.1434Y-.3993Z-1.3536
X1.1574Y-.4083Z-1.3543F247.
X1.1723Y-.416Z-1.355F227.
G02X1.4301Y-.5486R3.0835F207.
G03X1.5652Y-.6174R4.8791F220.
G02X1.7871Y-.7519R1.6321F200.
X2.0929Y-1.0823R1.1845
G03X2.1007Y-1.0925R.075
G02X2.351Y-1.4112R2.8375
G01X2.3629Y-1.4268Z-1.3542F220.
X2.3765Y-1.4409Z-1.3533F240.
X2.3917Y-1.4533Z-1.3525F260.
X2.4083Y-1.4639Z-1.3517F280.
X2.4259Y-1.4725Z-1.3508F300.
X2.4444Y-1.479Z-1.35F320.
X2.4636Y-1.4833Z-1.3492
X2.4831Y-1.4853Z-1.3483F300.
X2.5027Y-1.4851Z-1.3475F280.
X2.5222Y-1.4825Z-1.3467F260.
X2.5412Y-1.4778Z-1.3458F240.
X2.5596Y-1.4708Z-1.345F220.
G03X2.6596Y-1.3167R.1688F200.
X2.6046Y-1.1921R.1688
G01X2.4949Y-1.092F240.
X2.44Y-1.0419F260.
X2.3852Y-.9919F280.
X2.3304Y-.9419F300.
X2.2755Y-.8918F320.
X2.2207Y-.8418F340.
X2.1658Y-.7917F360.
X2.111Y-.7417F380.
X2.0562Y-.6917F400.
X2.0013Y-.6416F380.
X1.9465Y-.5916F360.
X1.8916Y-.5415F340.
X1.8368Y-.4915F320.
X1.782Y-.4414F300.
X1.7271Y-.3914F280.
X1.6723Y-.3414F260.
X1.6174Y-.2913F240.
X1.5626Y-.2413F220.
G03X1.4489Y-.1972R.1687F200.
X1.2891Y-.3115R.1687
G01X1.2839Y-.3304Z-1.3458F220.
X1.2809Y-.3498Z-1.3467F240.
X1.2801Y-.3694Z-1.3475F260.
X1.2817Y-.389Z-1.3483F280.
X1.2855Y-.4082Z-1.3492F300.
X1.2915Y-.4269Z-1.35F290.
X1.2997Y-.4448Z-1.3508F270.
X1.3098Y-.4616Z-1.3517F250.
X1.3219Y-.477Z-1.3525
X1.3356Y-.491Z-1.3533
X1.3509Y-.5033Z-1.3542F240.
X1.3675Y-.5138Z-1.355F220.
G02X2.1095Y-1.1023R2.8375F200.
G01X2.1213Y-1.1142Z-1.3543F220.
X2.1342Y-1.1248Z-1.3536F240.
X2.148Y-1.1341Z-1.3529F250.
X2.2557Y-1.1864Z-1.3478
X2.2749Y-1.199Z-1.3468
X2.2922Y-1.214Z-1.3458F240.
X2.3054Y-1.2289Z-1.345F220.
G02X2.3373Y-1.2918R.1813F200.
G03X2.3569Y-1.3281R.1688
G02X2.8899Y-3.002R2.8948F200.57
X2.8891Y-3.0741R2.8948
G03X2.8986Y-3.126R.1988F200.
G02X2.9025Y-3.1616R.1654
X2.9019Y-3.1748R.1654
G01X2.9012Y-3.1831Z-1.3454F220.
X2.8968Y-3.2057Z-1.3463F240.
X2.8893Y-3.2274Z-1.3473F260.
X2.8789Y-3.2481Z-1.3483F280.
X2.8247Y-3.3415Z-1.3529
X2.8185Y-3.357Z-1.3536F260.
X2.8138Y-3.373Z-1.3543F240.
X2.8107Y-3.3894Z-1.355F220.
G02X2.7471Y-3.7105R2.8375F200.
G03X2.7185Y-3.9139R1.4436
X2.71Y-4.0568R6.4816F240.
X2.707Y-4.1283R6.4816F260.
X2.7048Y-4.1999R6.4816F280.
X2.7033Y-4.2715R6.4816F300.
G02X2.6991Y-4.4194R5.859F260.
X2.6956Y-4.4933R5.859F240.
X2.6911Y-4.5672R5.8591F220.
X2.6488Y-4.8289R1.4897F200.
X2.3128Y-5.342R.9564
X2.0065Y-5.517R1.2268
X1.6583Y-5.6168R1.9061
X1.2565Y-5.6684R3.6243F224.42
X1.1233Y-5.6773R7.771F264.42
X.99Y-5.6839R7.7709F240.
X.9234Y-5.6864R7.7709F220.
G03X.9022Y-5.6903R.075F200.
G02X.571Y-5.7795R2.8375
G01X.5548Y-5.7836Z-1.3543F220.
X.5392Y-5.7894Z-1.3536F240.
X.5241Y-5.7966Z-1.3529F260.
X.4343Y-5.8569Z-1.3483F300.
X.419Y-5.8686Z-1.3475F280.
X.4051Y-5.8821Z-1.3466F260.
X.3929Y-5.8971Z-1.3458F240.
X.3824Y-5.9133Z-1.345F220.
G03X.3606Y-5.9963R.1688F200.
X.5294Y-6.1651R.1688
X.6467Y-6.1176R.1688
G01X.7497Y-6.018F240.
X.8013Y-5.9682F260.
X.8528Y-5.9184F280.
X.9043Y-5.8686F260.
X.9558Y-5.8188F240.
X1.0074Y-5.769F220.
G02X1.0976Y-5.731R.1354F200.
G03X1.2306Y-5.723R4.7455F240.
X1.5616Y-5.6865R4.7456F220.
X1.9217Y-5.6033R2.2986F200.
X2.248Y-5.452R1.4293
X2.5543Y-5.16R1.0456
X2.7108Y-4.7948R1.0355
X2.7459Y-4.533R1.7182
X2.7517Y-4.4041R8.9708F240.
X2.754Y-4.3396R8.9708F260.
X2.7557Y-4.2751R8.9709F247.04
X2.757Y-4.2105R8.9708F227.04
G02X2.76Y-4.1191R3.0846F207.04
X2.8005Y-4.0358R.135F200.
G01X2.8983Y-3.9413F240.
X2.9472Y-3.894F260.
X3.045Y-3.7995F240.
X3.0938Y-3.7522F220.
G03X3.1453Y-3.6309R.1687F200.
X2.9766Y-3.4622R.1687
X2.8986Y-3.4812R.1687
G01X2.882Y-3.4911Z-1.3458F220.
X2.8667Y-3.5028Z-1.3466F240.
X2.8527Y-3.5162Z-1.3475F260.
X2.8403Y-3.5313Z-1.3483F280.
X2.7772Y-3.6189Z-1.3529
X2.7694Y-3.6337Z-1.3536F260.
X2.7632Y-3.6491Z-1.3543F240.
X2.7584Y-3.6651Z-1.355F220.
G02X2.6898Y-3.9034R2.8375F200.
G03X2.6562Y-4.0657R.9628
X2.6328Y-4.3267R3.9167F233.3
G02X2.6109Y-4.5622R3.7627F220.
X2.5482Y-4.8266R1.3039F200.
X2.2371Y-5.2595R.9726
X1.9322Y-5.4361R1.2332
X1.5843Y-5.538R1.8974
X1.1626Y-5.593R3.6031F220.
G03X1.1385Y-5.5991R.075F200.
G02X.8762Y-5.6988R2.8375
G01X.8606Y-5.7048Z-1.3543F220.
X.8457Y-5.7122Z-1.3536F240.
X.8315Y-5.7211Z-1.3529F260.
X.7489Y-5.7909Z-1.3483F300.
X.735Y-5.8044Z-1.3475F280.
X.7227Y-5.8193Z-1.3466F260.
X.7122Y-5.8355Z-1.3458F240.
X.7037Y-5.8528Z-1.345F220.
G03X.6902Y-5.9189R.1687F200.
X.8589Y-6.0876R.1687
X.9786Y-6.0379R.1687
G01X1.0739Y-5.942F240.
X1.1215Y-5.8941F260.
X1.1691Y-5.8462F280.
X1.2644Y-5.7503F260.
X1.312Y-5.7024F240.
X1.3596Y-5.6545F220.
G02X1.4362Y-5.616R.135F200.
G03X1.8117Y-5.5346R2.4267
X2.1377Y-5.3917R1.4933
X2.4572Y-5.1062R1.0834
X2.6319Y-4.7303R1.0479
X2.6748Y-4.4596R1.7547
X2.682Y-4.3697R4.6177F220.
G02X2.7209Y-4.2844R.1351F200.
G01X2.8132Y-4.1915F240.
X2.8594Y-4.1451F260.
X2.9056Y-4.0986F280.
X2.9517Y-4.0521F260.
X2.9979Y-4.0057F240.
X3.0441Y-3.9592F220.
G03X3.0931Y-3.8403R.1687F200.
X2.9244Y-3.6716R.1687
X2.8572Y-3.6855R.1687
G01X2.84Y-3.6941Z-1.3458F220.
X2.8238Y-3.7047Z-1.3466F240.
X2.809Y-3.7171Z-1.3475F260.
X2.7955Y-3.7313Z-1.3483F280.
X2.7263Y-3.8142Z-1.3529
X2.7175Y-3.8283Z-1.3536F260.
X2.7102Y-3.8433Z-1.3543F240.
X2.7044Y-3.859Z-1.355F220.
G02X2.6272Y-4.072R2.8375F200.
G03X2.5867Y-4.2317R.9338
X2.5635Y-4.3722R6.9491F240.
X2.5529Y-4.4426R6.9491F220.
G02X2.4947Y-4.6937R1.7363F200.
X2.1147Y-5.2143R1.0112
X1.807Y-5.376R1.3161
X1.4607Y-5.4692R2.0444
X1.384Y-5.4822R2.9411F202.16
G03X1.3598Y-5.4904R.075F200.
G02X1.1071Y-5.6126R2.8375
G01X1.0921Y-5.6199Z-1.3543F220.
X1.0779Y-5.6286Z-1.3536F240.
X1.0646Y-5.6387Z-1.3529F260.
X.9884Y-5.7154Z-1.3483F300.
X.9757Y-5.73Z-1.3475F280.
X.9647Y-5.7459Z-1.3466F260.
X.9556Y-5.763Z-1.3458F240.
X.9486Y-5.781Z-1.345F220.
G03X.9403Y-5.8334R.1687F200.
X1.109Y-6.0021R.1687
X1.2301Y-5.9509R.1687
G01X1.3292Y-5.8488F240.
X1.3788Y-5.7977F260.
X1.4283Y-5.7467F280.
X1.4779Y-5.6956F300.
X1.5275Y-5.6445F280.
X1.577Y-5.5935F260.
X1.6266Y-5.5424F240.
X1.6761Y-5.4913F220.
G02X1.7491Y-5.4514R.1491F200.
G03X2.0819Y-5.2991R1.4804
X2.4094Y-4.9872R1.0859
X2.5654Y-4.638R1.1281
G02X2.5824Y-4.5737R1.2339
X2.6118Y-4.5273R.135
G01X2.7055Y-4.4308F240.
X2.7523Y-4.3826F260.
X2.7991Y-4.3343F280.
X2.8927Y-4.2379F260.
X2.9395Y-4.1896F240.
X2.9863Y-4.1414F220.
G03X3.034Y-4.0239R.1687F200.
X2.8653Y-3.8552R.1687
X2.8081Y-3.8651R.1687
G01X2.7903Y-3.8727Z-1.3458F220.
X2.7735Y-3.8822Z-1.3466F240.
X2.7579Y-3.8937Z-1.3475F260.
X2.7436Y-3.9069Z-1.3483F280.
X2.6693Y-3.9852Z-1.3529F290.94
X2.6596Y-3.9988Z-1.3536F270.94
X2.6513Y-4.0133Z-1.3543F250.94
X2.6445Y-4.0286Z-1.355F230.94
G02X2.5564Y-4.2325R3.2018F210.94
G03X2.5084Y-4.3758R1.2925F200.
G02X2.4709Y-4.5035R4.1906F240.
X2.4507Y-4.5669R4.1905F220.
X2.3381Y-4.8147R1.2772F200.
X2.0028Y-5.1611R1.0751
X1.694Y-5.3111R1.3989
X1.6167Y-5.3362R1.7977
G03X1.5962Y-5.3459R.075
G02X1.3292Y-5.5069R2.8374
G01X1.3148Y-5.5155Z-1.3543F220.
X1.3014Y-5.5254Z-1.3536F240.
X1.289Y-5.5366Z-1.3529F260.
X1.2197Y-5.6196Z-1.3483F300.
X1.2084Y-5.6353Z-1.3475F280.
X1.1988Y-5.6521Z-1.3466F260.
X1.1913Y-5.6699Z-1.3458F240.
X1.1858Y-5.6884Z-1.345F220.
G03X1.1814Y-5.7267R.1688F200.
X1.3502Y-5.8955R.1688
X1.4731Y-5.8423R.1688
G01X1.5748Y-5.7342F240.
X1.6256Y-5.6801F260.
X1.6765Y-5.626F280.
X1.7273Y-5.572F300.
X1.7781Y-5.5179F320.
X1.829Y-5.4638F340.
X1.9306Y-5.3557F320.
X1.9815Y-5.3016F300.
X2.0323Y-5.2476F280.
X2.0831Y-5.1935F260.
X2.134Y-5.1394F240.
X2.1848Y-5.0854F220.
G03X2.2924Y-4.9709R1.2621F200.
G01X2.3901Y-4.867F240.
X2.439Y-4.815F260.
X2.4879Y-4.7631F280.
X2.5367Y-4.7111F300.
X2.5856Y-4.6591F320.
X2.6344Y-4.6071F340.
X2.6833Y-4.5552F320.
X2.7322Y-4.5032F300.
X2.781Y-4.4512F280.
X2.8299Y-4.3993F260.
X2.8788Y-4.3473F240.
X2.9276Y-4.2953F220.
G03X2.9734Y-4.1797R.1687F200.
X2.8047Y-4.011R.1687
X2.7563Y-4.0181R.1687
G01X2.7381Y-4.0247Z-1.3458F220.
X2.7208Y-4.0333Z-1.3466F240.
X2.7046Y-4.0438Z-1.3475F260.
X2.6896Y-4.0563Z-1.3483F280.
X2.6111Y-4.1304Z-1.3529F287.04
X2.6007Y-4.1435Z-1.3536F267.04
X2.5916Y-4.1575Z-1.3543F247.04
X2.584Y-4.1723Z-1.355F227.04
G02X2.4514Y-4.4302R3.0845F207.04
G03X2.3826Y-4.5652R4.8932F220.
G02X2.2481Y-4.7872R1.6316F200.
X1.9177Y-5.0929R1.1846
G03X1.9075Y-5.1007R.075
G02X1.5888Y-5.351R2.8375
G01X1.5732Y-5.3629Z-1.3542F220.
X1.5591Y-5.3765Z-1.3533F240.
X1.5467Y-5.3917Z-1.3525F260.
X1.5361Y-5.4083Z-1.3517F280.
X1.5275Y-5.4259Z-1.3508F300.
X1.521Y-5.4444Z-1.35F320.
X1.5167Y-5.4636Z-1.3492
X1.5147Y-5.4831Z-1.3483F300.
X1.515Y-5.5027Z-1.3475F280.
X1.5175Y-5.5222Z-1.3467F260.
X1.5222Y-5.5412Z-1.3458F240.
X1.5292Y-5.5596Z-1.345F220.
G03X1.6833Y-5.6596R.1688F200.
X1.8079Y-5.6046R.1688
G01X1.908Y-5.4949F240.
X1.9581Y-5.44F260.
X2.0081Y-5.3852F280.
X2.0581Y-5.3304F300.
X2.1082Y-5.2755F320.
X2.1582Y-5.2207F340.
X2.2083Y-5.1659F360.
X2.2583Y-5.111F380.
X2.3083Y-5.0562F400.
X2.3584Y-5.0014F380.
X2.4084Y-4.9465F360.
X2.4585Y-4.8917F340.
X2.5085Y-4.8368F320.
X2.5585Y-4.782F300.
X2.6086Y-4.7272F280.
X2.6586Y-4.6723F260.
X2.7087Y-4.6175F240.
X2.7587Y-4.5627F220.
G03X2.8028Y-4.4489R.1688F200.
X2.6885Y-4.2892R.1688
G01X2.6696Y-4.2839Z-1.3458F220.
X2.6502Y-4.2809Z-1.3467F240.
X2.6306Y-4.2802Z-1.3475F260.
X2.611Y-4.2817Z-1.3483F280.
X2.5917Y-4.2856Z-1.3492F300.
X2.5731Y-4.2916Z-1.35F320.
X2.5552Y-4.2997Z-1.3508
X2.5384Y-4.3099Z-1.3517F300.
X2.5229Y-4.3219Z-1.3525F280.
X2.5089Y-4.3357Z-1.3533F260.
X2.4966Y-4.351Z-1.3542F240.
X2.4862Y-4.3676Z-1.355F220.
G02X1.8976Y-5.1096R2.8375F200.
G01X1.8858Y-5.1214Z-1.3539F220.
X1.8752Y-5.1342Z-1.3529F240.
X1.8659Y-5.1481Z-1.3518
X1.8188Y-5.2455Z-1.345F200.
G00Z3.
(CUTTER COMP USED)
M39
S3000M3
X3.075Y-2.8125
Z.1
G01Z-1.375F65.
G41D8X3.
G03X2.8125Y-3.R.1875
G02X0.Y-5.8125R2.8125
X-2.8125Y-3.R2.8125
X0.Y-.1875R2.8125
X2.8125Y-3.R2.8125
G03X3.Y-3.1875R.1875
G01G40X3.075
Z-1.275
G00Z3.
G91G28Z0Y0M5
Hi Hertz,
I looked at Your file. I think it ramps up to 1180IPM because your stock is lying partially outside of your part. It thinks it's cutting air so it ramps up to 1180 (according to what You said - it's the value You put for air-cutting). Take a look at your stock definition.
