G03 conflicts with G40 at the same line.
Hi,
I'm having alarm with the CANCEL CUTTER COMP with G03 and G40 at the same line. Is there away I can make like this (please see G-CODES below). I'm guessing that it is in the pncoutput and not sure how to fix it.
Please help.
PS: This is a POCKET FUNCTION.
Thanks a million.
O1936 (715-181936-001-REVA-OP1.NC)
(P/NAME= SPRT, WFR, FGR, LOAD LOCK)
(UNPROVEN SOURCE PROGRAM)
(SOURCE= 715-181936-001-REVA.MCX-7)
(POSTED ON JUN.26.2014 AT 10*06AM)
(MATSUURA VERTICAL PITCH TAP)
(TOOLS LIST)
(T8 - .1094, 7/64 TICOATED 4FLT .500LOC - H8)
N8(.1094, 7/64 TICOATED 4FLT .500LOC )
G0 G17 G40 G49 G53 G80 G90 Z0
T8 M6(ROUGH AND FINISH SLOT, CUT#13)
G0 G90 G54
X-.8 Y.25 S2000 M3
G43 H8(D38) Z1. M8(DOC= Z-.215)
Z.0625
G1 Z0. F2.
X-.7957 Y.261 Z-.01
G3 X-.8043 I-.0043 J0.
G1 Y.239
G3 X-.7957 I.0043 J0.
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.01
X-.7957 Y.261 Z-.02
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.02
X-.7957 Y.261 Z-.03
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.03
X-.7957 Y.261 Z-.04
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.04
X-.7957 Y.261 Z-.05
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.05
X-.7957 Y.261 Z-.06
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.06
X-.7957 Y.261 Z-.07
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.07
X-.7957 Y.261 Z-.08
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.08
X-.7957 Y.261 Z-.09
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.09
X-.7957 Y.261 Z-.1
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.1
X-.7957 Y.261 Z-.11
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.11
X-.7957 Y.261 Z-.12
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.12
X-.7957 Y.261 Z-.13
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.13
X-.7957 Y.261 Z-.14
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.14
X-.7957 Y.261 Z-.15
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.15
X-.7957 Y.261 Z-.16
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.16
X-.7957 Y.261 Z-.17
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.17
X-.7957 Y.261 Z-.18
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.18
X-.7957 Y.261 Z-.19
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.19
X-.7957 Y.261 Z-.2
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.2
X-.7957 Y.261 Z-.21
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.205
X-.7957 Y.261 Z-.215
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.205
X-.8093 Z-.215
G41 D38 Y.239
G3 X-.7907 I.0093 J0.
G1 Y.261
G3 X-.8093 I-.0093 J0.
G1 Y.25
Y.239
G3 G40 X-.7958 Y.2307 I.0093 J0. (Orginally)
G40 (I would like it to be like this)
G3 X-.7958 Y.2307 I.0093 J0. (I would like it to be like this)
G0 Z1.
M9
M5
G53 Y0
M1
T8 M6
I went to PCIROUT1 (please see below) and made PCCDIA a separate line like this. Is this the right way?
Thank you.
pcirout1 #Output to NC of circular interpolation
pccdia, e$
pcan1, pbld, n$, sgcode, sgabsinc,
pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e$
My out put is
G0 G90 G54
X-.8 Y.25 S2000 M3
G43 H8(D38) Z1. T10 M8(DOC= Z-.215)
Z.0625
G1 Z0. F2.
X-.7957 Y.261 Z-.01
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.01
X-.7957 Y.261 Z-.02
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.02
X-.7957 Y.261 Z-.03
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.03
X-.7957 Y.261 Z-.04
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.04
X-.7957 Y.261 Z-.05
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.05
X-.7957 Y.261 Z-.06
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.06
X-.7957 Y.261 Z-.07
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.07
X-.7957 Y.261 Z-.08
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.08
X-.7957 Y.261 Z-.09
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.09
X-.7957 Y.261 Z-.1
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.1
X-.7957 Y.261 Z-.11
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.11
X-.7957 Y.261 Z-.12
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.12
X-.7957 Y.261 Z-.13
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.13
X-.7957 Y.261 Z-.14
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.14
X-.7957 Y.261 Z-.15
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.15
X-.7957 Y.261 Z-.16
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.16
X-.7957 Y.261 Z-.17
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.17
X-.7957 Y.261 Z-.18
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.18
X-.7957 Y.261 Z-.19
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.19
X-.7957 Y.261 Z-.2
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.2
X-.7957 Y.261 Z-.21
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.205
G1 Y.239
G1 Y.261
G0 Z.125
X-.8 Y.25
Z.0625
G1 Z-.205
X-.8093 Z-.215
G41 D38 Y.239
G1 Y.261
G1 Y.25
Y.239
G40
G0 Z1. M9
M5
G53 Y0
M1
Guest MTB Technical Services
You can't engage or cancel CRC with an arc move.
Change your lead-out in the operation settings.
Do NOT edit your post.
This is NOT a post issue.
Indeed, it is a common mistake. Using CRC and only having an arc lead in/out. If I am using CRC I *always* have a lead in line, then the arc. The CRC cancel will always be on the last linear move then. With one post I worked on a while ago, I made the post generate an error if it encountered CRC cancel on an arc. It was handy :)
