G54 then G55
bogusmill
How do I run the same program on two similar parts at different locations on the same machine table?
I know I can copy the ops from the G54 location, change those to G55 and post it all together. I also know there is a way to post it so the ops run at both locations without doubling the size that the copied ops will generate. I've just never had to do this before.
I've used that before but if I'm thinking right that still doubles the program size or I have to post it twice which is what I'm trying to get away from. What I'm thinking of is a kind of subprogram. Run this routine at G54 then at G55 kind of thing.
Make your source toolpaths and try this with transform.
Should give you what you're looking for.
That didn't work. I ran it with the same settings in your example but it just started to run the first part again. If I enter the X & Y distance between G54 & G55 I could see it working
Just use sub programs.
O1000(MAIN)
G54
M98 P1
M1
G55
M98 P2
M30
I've never run sub programs before but that's how I thought it would be done. Is there a tutorial on it?
Sub programs are exactly like regular programs, except that they end with M99 instead of M30.
Main programs call subs with M98 Pxxxx
Be careful that the sub program ends with the machine in exactly the same state that it was in when the sub started. For example, if the main program is in G90 and the sub is G91, make sure there is a G90 at the end of the sub.
Work good here.
This is the code you should be seeing out of the generic Hass post that comes with MasterCam according the settings in the pictures that I put up.
Is this what you're getting?
O0
(TEST)
(DATE=DD-MM-YY - 03-07-14 TIME=HH:MM - 12:45)
(MATERIAL - ALUMINUM INCH - 2024)
(ENDMILL)
G20
G0 G17 G40 G49 G80 G90
T1 M6
G0 G90 G54 X.1875 Y.0063 A0. S4000 M3
G43 H1 Z.25
M98 P0001
G90 G55 X.1875 Y.0063 Z.25 A0.
M98 P0001
M5
G91 G28 Z0.
G28 X0. Y0. A0.
M30
O0001
Z.1
G1 Z0. F25.
G41 D1 X.1625
G3 X.1563 Y0. I0. J-.0063
G2 I-.1563 J0.
G3 X.1625 Y-.0063 I.0062 J0.
G1 G40 X.1875
G0 Z.25
M99
I am going to differ on that. Subs work best when they contain the full code. Except in his case, minus the G54/G55.
That way, when you start from the main, you do not have to worry about any other code problems, like G90, G40 H/D comps. spindle rpms, etc.
In this case he could just use the same P# in his M98 call since the only thing that should change is the G54/55:
O1000(MAIN)
G54
M98 P1 (SAME P#)
M1
G55
M98 P1(SAME P#)
M30
Any Fanuc program book has examples of subs.
If you're moving to absolute positions to run subs switching G90 to G91 and back to G90. When outputting subs to run at G54 + work offsets you can remain in G90 because the subroutine is working from the new offset origin.
Bog are you using an older post that was updated from an earlier version of Mcam?
There's nothing wrong with restating the initial offset position for the work offset as in Oscar's example.
