Rotary unwinding
We have a new VF-4 with the HRT-210 rotary, we're using the rotary for the first time on this machine and so I wrote some test programs to make sure everything moved correctly.
My tester was a spiral shaped contour along X and I used axis substitution for Y so the spindle basically just sits at Z and moves along X while spinning the rotary, now after 10 or so revolutions the rotary winds up to about 4000 degrees, and when the spindle retracts for a second pass & commands A0, the rotary has to unwind all the way back to 0 which is suuuuuper slow.
G91 G28 A0 fixes the problem but I have to punch it in manually between passes. I tried browsing through the post to see if I could find something for it to no avail.
I went into the MD on mcam and selected "Shortest direction, absolute angle" instead of "Signed continuous" and that didn't change anything either.
Could someone help me out?
If you look inside the post, there is a "switch" variable: 'frc_cinit'. This stands for "force C initialize". This will cause the post to output "A/B" or "A/C" zero. You can modify that post block to output the Incremental return for the rotaries. It will be a simple post edit. In order to make sure it resets between toolpaths, you might need to use "Force Tool Change" on the next operation, to make it force a return to zero...
I searched that variable and it comes up three times.
Once in the Rotary Axis Settings section:
frc_cinit    : yes$
Once in the Start of File and Toolchange Setup section, about 40 lines down from "pretract #End of tool path, toolchange"
 #cc_pos is reset in the toolchange here
      cc_pos$ = zero
      gcode$ = zero
      if use_rot_lock & rot_on_x,
        if (index = one & (prv_indx_out <> fmtrnd(indx_out)) | (prv_cabs <> fmtrnd(cabs)))
          | nextop$ = 1003 | frc_cinit, prot_unlock
And once more in the same section but further down,
protretinc      #Reset the C axis revolution counter
      if frc_cinit & rot_on_x,
        rev = zero
        sav_rev = zero
        cabs = zero
        csav = zero
        indx_out = zero
        if index, e$, pindxcalc, pindex
        else, *cabs
        prvcabs = zero
        !csav, !cabs
rot_on_x is turned on, and use_rot_lock is off.
I'm not sure what i'm supposed to change..
I'd rather not have to force a toolchange because then it puts an M01 after each pass. I put M01's in the program sometimes in case i need to tell the operator to do something, and if op-stop is on, then it retracts and stops all the time which defeats the purpose of it...
What post are you using?
Also you can set your rotary limits in your machine def to what is on the attached screenshot. I use MPMASTER and it does not "wind up" with the these settings.
I'm using the included "Generic HAAS 4X Mill." If I set my min/max to those values, what will happen if I post a axis-sub toolpath like the one that commands 4k degrees?
I've been reluctant to switch to MPMASTER because I don't know how the machine will behave. I'm having a hard time understanding the post and how to modify it without fcking anything up.
Here's a snip of my program for reference, you can see where I had to manually add the G91 G28 A0 & G90.
N66460 G94 G1 Z1.0067 F5.
N66470 G42 D2 X-.4429 A-298.034
N66480 X-.4061 A-297.959
N66490 X-.3696 A-297.606
N66500 X-.3337 A-296.981
N66510 X-.2988 A-296.091
N66520 X-.2652 A-294.943
N66530 X-.2332 A-293.549
N66540 X-.2032 A-291.922
N66550 X-.1754 A-290.079
N66560 X-.1501 A-288.036
N66570 X-.1275 A-285.814
N66580 X-.108 A-283.433
N66590 X-.0915 A-280.917
N66600 X-.0784 A-278.29
N66610 X-.0687 A-275.578
N66620 X-.0625 A-272.806
N66630 X-.06 A-270.
N66640 G93 X1.14 A4050. F.1
N66650 G40 A4410. F.8
N66660 G0 Z1.2567
N66670 X-.8178
G91 G28 A0.
N66680 G90 Z1.2067
N66690 G94 G1 Z.76 F5.
N66700 G42 D2 X-.4429 A-298.034
I've done this already, hence why I explained that manually typing in G91 G28 A0 works in my op.
