Help with posting a G54
rjoyner
Right on bro !
Go to Operations Manager and open any op.
Now click on parameters right below the name of the op you opened. Next click on T/C Plane button, now click on the lower left button where it says Work offset and put "0" for G54, "1" for G55 etc.
Remember this is just "my" way of gettin u goin.
Ur reseller can help u setup ur post if u wanna get fancy.
Also the other folks in here will have some ideas.
Make sure this part of the post says This:
161. Enable Home Position button? y
162. Enable Reference Point button? y
163. Enable Misc. Values button? y
164. Enable Rotary Axis button? n
165. Enable Tool Plane button? y
166. Enable Construction Plane button? y
167. Enable Tool Display button? y
168. Check tplane during automatic work origin creation? y
Should be a cake walk from there unless you need to change this also:
 force_wcs   : no    #Force WCS output at every toolchange?
Then that should take care of you unless you are going to be doing 4th axis work then say yes to that button.
Crazy Millman
Also what is the Date on the Post you are using?
[ 12-01-2003, 08:10 PM: Message edited by: Millman^Crazy ]
Try turn on your misc integer 1 to 2.
Also, find out if you have this section in your post:
pwcs #G54+ coordinate setting at toolchange
if mi1 > one,
sav_frc_wcs = force_wcs
if sub_level, force_wcs = zero
if workofs <> prv_workofs | (force_wcs & toolchng),
if workofs < 6,
g_wcs = workofs + 54
else,
g_wcs = workofs + 104
if workofs >= 0 & workofs <= 25, *g_wcs
else, "ERROR - Invalid Work Coordinate System", e
force_wcs = sav_frc_wcs
!workofs
If you have this section of code in your post, turning on mi1 to 2 will enable otputting the WCS.
Make sure you call out pwcs in tool change or null tool change section.
If you still having problem posting wcs, try finding all the pwcs section in your post and paste it in this thread. We might be able to help you out.
