Pending VBScript Update Information
Guys,
CNC Software appreciates all your suggestions, requests and support that you have given us since implementing VBscript in Mastercam.
Here is a listing of new functions, changes, fixes, etc to our VBScript functionality in Mastercam. We anticipate release of this update shortly, stay tuned.
NEW FUNCTIONS
GetCPlaneNumber
SetCPlaneNumber
GetTPlaneNumber
SetTPlaneNumber
GetCPlaneEqualGView
SetCPlaneEqualGView
SetLevelVisibleByNumber
SetLevelVisibleByName
SetBackGroundColor
GetBackGroundColor
DoBitmapfile
GetNestedSheetCount
MakeNestedSheetBMP
GetOperationTypeFromName
GetGViewNumber
SetGViewNumber
DeleteAllEntities
DeleteEntity
GetToolLength
GetToolFluteLength
GetToolOffsetNumber
GetJobSetupMaterial
GetJobSetupStockSizeX
GetJobSetupStockSizeY
GetJobSetupStockSizeZ
GetJobSetupStockOriginX
GetJobSetupStockOriginY
GetJobSetupStockOriginZ
GetNciNameFromOperationID
SetNciNameFromOperationID
GetToolComment
GetToolNumberFromOperationID
GetToolName
MakeOperationFromID
GetOperationNameFromID
GetOperationTypeFromID
SetContourOperationSideFromName
GetContourOperationSideFromID
SetContourOperationSideFromID
GetNciMinZFromOperationID
GetNciMaxZFromOperationID
FormatValue
GetOperationIDFromSheet
RunMastercamChook
mc_appmodule
mc_applevel
mc_appversion
NEW CONSTANTS
mcVIEW_TOP
mcVIEW_FRONT
mcVIEW_BACK
mcVIEW_BOTTOM
mcVIEW_SIDE
mcVIEW_LSIDE
mcVIEW_ISO
mcCPLANE_3D
mcTPLANE_OFF
mcTITLE
mcBACKSLASH
mcPERIOD
mcOPERATION_CONTOUR
mcOPERATION_POCKET
mcOPERATION_DRILL
mcOPERATION_ROUTER_CNTR
mcOPERATION_ROUTER_POCK
mcOPERATION_ROUTER_CUTOFF
mcOPERATION_ROUTER_BLOCK_DRILL
mcOPERATION_SRF_RGH_PARALLEL
mcOPERATION_SRF_RGH_RADIAL
mcOPERATION_SRF_RGH_PROJECT
mcOPERATION_SRF_RGH_FLOWLINE
mcOPERATION_SRF_RGH_CONTOUR
mcOPERATION_SRF_RGH_POCKET
mcOPERATION_SRF_FIN_PARALLEL
mcOPERATION_SRF_FIN_RADIAL
mcOPERATION_SRF_FIN_PROJECT
mcOPERATION_SRF_FIN_FLOWLINE
mcOPERATION_SRF_FIN_CONTOUR
mcOPERATION_SRF_FIN_PENCIL
mcOPERATION_SRF_FIN_LEFTOVER
mcOPERATION_SRF_FIN_STEEP
mcOPERATION_SRF_FIN_SHALLOW
mcOPERATION_SRF_FIN_CONSCALOP
mcOPERATION_SRF_RGH_PLUNGE
mcOPERATION_SRF_FLOW5AX
mcOPERATION_SRF_4AX
mcOPERATION_MERGED_NCI
mcOPERATION_5AX_SWARF
mcOPERATION_5AX_ROLLDIE
mcOPERATION_FACE
mcOPERATION_5AX_MSURF
mcMILL_EXE
mcLATHE_EXE
mcWIRE_EXE
mcDESIGN_EXE
mcDRAFT_EXE
mcROUTER_EXE
mcAPPLEVEL_ENTRY
mcAPPLEVEL_1
mcAPPLEVEL_2
mcAPPLEVEL_3
FIXES
DoMetafile works as expected
RunPostAll works as expected
SaveMCAs saving thumbnail works as expected
Reading/Writing to CArc.VIEW works as expected
mcCHAIN_CCW/mcCHAIN_CW fixed, values were wrong
CHANGES
Many 'GetTool*' functions now take TOOL NUMBER in place of TOOL ID
Changed SaveMC() now a function that returns true/false
AskYesNo() now returns mcMSG_YES/mcMSG_NO
OTHER
Option Explicit automatically added to your scripts (internal to chook)
Can't execute a script while another is running.
ayup. I've held off messing with my HTML setup sheet any further (still couldn't get the formatting right) until the new VBscript stuff comes out. Then of course, I'll have to follow through with learning VBscript. I >think< one can send the information to WORD, if I understood the book I was reading right. That would save us a step.
John
John T,
Here's a quick example.
Tip: With any VBA enabled program, Word, Excel, AutoCAD, etc, open the program and then the VBA Editor and then press F2 to open the object browser, select the program from the drop down list to see all the methods and propeties available. I would recommend writing your code in the VBA editor for debuging purposes before porting over to VBS.
'// Author: Mick George [email protected]
'// Date: 07/12/2003 04:16 PM
'// File Name: Word.vbs
'// Description: Open Word
'// Comments:
Const wdWindowStateMaximize = 1
Const wdAlertsNone = 0
'///////////////// My Global Variables //////////
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim Word
On Error Resume Next
' -- Open word
Set Word = CreateObject("Word.Application")
' -- Ok?
If Err Then
ShowString "Could not get an instance of Word"
Else
' -- Got word so do something with it...
With Word
.Visible = True
.WindowState = wdWindowStateMaximize
.DisplayAlerts = wdAlertsNone
' -- Do something ....
End With
If askYesNo("Close Word?") =mcMSG_YES Then Word.Quit
End If
If IsObject(Word) Then
Set Word = Nothing
End If
End Sub
[ 12-08-2003, 07:17 PM: Message edited by: Mick from CNC Software, Inc. ]
Just wanna share this after I looked at Mick's code.
'// Author: CAM Desciple w/script borrow from Mick
'// Date: 12/08/2003 09:50 PM
'// File Name: Export Op to Word
'// Description: Export a list of operation id and name to Word Document
'// Comments: Just try to have some fun here. Fun's over when it work!
Dim wordDoc
' -- Start Script
Call Main
' Sub Declaration
Sub Main()
Dim maxOpNum,numTool
Dim strOperName(), strOpID()
Dim i
'create an instance of Word Application
Set wordDoc = CreateObject("Word.Application")
'check to see any problem
If Err Then
'Show error description
ShowString "Error # " & CStr(Err.Number) & " " & Err.Description
Else
'create new document
wordDoc.Documents.Add
With wordDoc
.Visible = True
.ActiveDocument.Words(1).Font.Size = 14
.ActiveDocument.Words(1).Bold = True
.ActiveDocument.Words(1).Text = "Your Company Name" & vbNewLine & "Op_ID" & vbTab & "Op Name" & vbNewLine
End With
'get operation number count
maxOpNum = GetOperationCount("")
' declare array size
If maxOpNum > 1 Then
ReDim strOperName(maxOpNum)
ReDim strOpId(maxOpNum)
End If
'get operation name
strOperName(0) = GetFirstOperationName("")
For i = 1 To maxOpNum
strOperName(i) = GetNextOperationName()
Next
'get op id
strOpId(0) = GetFirstOperationID("")
strOpId(i) = GetNextOperationID()
Next
'write to Word Document
For i=0 To maxOpNum-1
WriteToWord(" " & strOpId(i) & vbTab & vbTab &strOperName(i) & vbNewLine)
Next
If askYesNo("Close Word?") = mcMSG_YES Then Word.Quit
End If
'clean up, set word object to none
Set Word = Nothing
End If
End Sub
' Sub Declaration
Public Sub WriteToWord(strOutText)
Dim wordCounts
With wordDoc
wordCounts = .ActiveDocument.Words.Count
.ActiveDocument.Words(wordCounts).Bold = False
.ActiveDocument.Words(wordCounts).Font.Size = 12
.ActiveDocument.Words(wordCounts).Text = strOutText
End With
End Sub
If I can get hold of all the new API function, man, I can output a lot of information from MasterCAM...
The GetNextOperationID() and GetNextOperationName() seems to increment a global count and cannot call subsequently... can you veify this, Mick?
Please let me know if you have anything interesting to add to this script. I would like to learn more from you guys. Thanks
Correct. They go with GetFirstOper... blah blah and have to be done incrementally. This won't be a problem for long, though... wink.gif
'Rekd
Yup, it's easy to automate Word, Excel or anyother Office program
(maybe not Visio)
using VBS.
I don't about about earlier versions of Visio, but with Visio 2003 ->
You can write programs to control Microsoft Visio in Microsoft Visual Basic for Applications (VBA), Microsoft Visual Basic, C++, or any programming language that supports Automation.
Yeppers, looks like the .set files and html setup sheets may go the way of the dodo bird
Remember folks the information in the operations is not necessarily equal to what is output in a .set file. The values in an operation are just parameters used to generate the nci file. So there's a level or two of separation between the operation and the nc/doc/html file. You can and will get differences.
That being said, outputting all the data to a sheet is a great way to look at all the parameters in a operation. ie A great way to check that all the clearance planes are set correct without going through each and every operation in the op manager.
