manual entry question
Joeyls319
Morning all
I have a question regarding manual entry and posting it out.
How can I get the post to post out blank lines in the program?
example:
Manual entry:
( ALIGNMENT )
T01 M06 ( 5/8 SPOT DRILL - 0.625" )
G00 G90 G55 X-1.9445 Y-1.9445
G43 H01 Z8.0
G01 Z6.6 F10.0
M00
(AFTER ALIGNMENT, PRESS CYCLE START)
G00 G49 G53 Z0.0
__________________________________
posted code:
( ALIGNMENT )
G43 H01 Z8.0
G01 Z6.6 F10.0
M00
G00 G49 G53 Z0.0
NCI output method
I have it selected as code.
FYI, using X9
Joey
I can think of two ways. Add an invisible character (eg ALT+255) as a line in your manual entry. Your control or DNC file transfer may or may not filter it out. Or, modify your post so that certain strings represent an empty line in the code. For example, if you used the word "SPACE" as an empty string, the post would look like this in the pcomment2 section:
if gcode$ = 1006, #Manual entry - as code
if scomm$ = "SPACE", " ", e$
else, scomm$, e$
Try using a semi colon in your notes. When you load it into the machine they will see it as an EOB and you will have a blank line.
N3 M01
( T3 1/8 FLAT ENDMILL )
G0G53G90Y0
M0( PLACE NOTE HERE )
T3 M6
G0 G54 G90 X2.4869 Y.0173 S7000 M3
G43 H3 Z.1
M8
When you save back from the machine you will have blank lines.
N3 M01
G00 G53 G90 Y0
M00 ( PLACE NOTE HERE )
T3 M06
G00 G54 G90 X2.4869 Y0.0173 S7000 M03
G43 H03 Z0.1
M08
