Drilling op posts differently between 1 or more points
wdg5555
If I have two points selected in a drilling cycle it posts like this.
G56H2Z3.
M08
Z.1
G94
G71Z.1
G73Z-.625R.1Q.05F10.M54
X-3.595Y.4682
G80 M3
Z3.
M09
If i have one point selected it looks like this
G56H2Z3.
M08
G94
G71Z3.
G80 M3
M09
The machine crashed on the secound cycle. Since it did not retract in Z. Any ideas?
Using X9 and mpmaster 11.0.06347.
It's an issue with Mastercam with an operation that has a single drill point. The issue is if the NCI File contains the retract point, or not.
You can see that with 2 points, you get a "Z3." Move after the "G80". With only 1 point, you dont.
There is a post mod you can do to force the Clearance move...
Below is the section where I need to change it. I'm not sure exactly how though. I'm assuming gcode$ is a nill value so it skips all of the if statements for the prapidout.
If you could give me some direction I would greatly appreciate it.
pncoutput #Movement output
if subreps & subout$ = 0, subout$ = 3 #Subrep
pcom_moveb
comment$
if coolant$ <> 0 & coolant$ <> sav_coolant,
pbld, n$, sm09, e$
sav_coolant = coolant$
if coolant$ = 1, sm09 = sm09_0
if coolant$ = 2, sm09 = sm09_1
if coolant$ = 3, sm09 = sm09_2
if cool_zmove = yes$ & (nextop$=1003 | (nextop$=1011 & t$<>abs(nexttool))), coolant$ = zero
pcan
if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
if gcode$ = zero, prapidout
if gcode$ = one, plinout
if gcode$ > one & gcode$ < four, pcirout
if mr_rt_actv, #Restore absolute/incremental for G51/G68
absinc$ = sav_absinc
mr_rt_actv = zero
pcom_movea
  • 3 weeks later...
'pncoutput' really isn't the best place to do this. You only want the Clearance Plane output after the 'G80'.
The best place to do this is in 'pcanceldc$'.
Look at the MPMaster post (available on this website) for a good example of how to do this. IHS uses some Parameter read logic to capture if the 'use clearance only at start/end' checkbox is enabled. They also read the parameter for 'number of points in the Drill Cycle'.
If there is only 1 point, and the check box is enabled, then they force out the clearance plane.
You should be able to Initialize two variables, add the code to capture the data in 'pparameter$', and add the logic in 'pcanceldc$'.
