4 Axis Tool Path question
Karl@CP PISTONS
I am trying to use the multi axis rotary for 4 axis output and can't figure out how to start the tool path at a different point. What I'd like is to start at the left side and retract, rotate and cut 1 way again. Am I missing a start point button somewhere? Any of the multi axis masters here have any suggestions? Still on X9 here if it matters.
Karl
I don't have X9 installed here at home but I typically would use a Multi-Surf driving by a cylinder and comp'd to that solid....
You'll have far greater control of the tool path
In MC2017, I was able to set Rotary 4-axis path to use Left side as the Planes/Working coordinate system (Top for Tool plane and Comp / construction  plane) and set the Tool axis control / Rotary axis to "Z axis".  And I picked the 4 axis point (on axis of rotation).  My path cuts from left to right.  But those same settings might encounter a bug in X9.
(I'll hunt around in the underlying source code to see if there is a reverse order switch  that could be exposed.)
I agree, Multi-surface, Cylinder pattern might be your X9 work-around (and offer more control options).
