O/T NPT Thread Milling
Peccator
I,m trying to thread mill an NPT 1-1/4 11.5 T.P.I.
It is an internal thread. I know that my minor hole diameter should be 1.485.
What I,m looking for is the major diameter to program my thread mill to. headscratch.gif Can y'all help me out,please?
I'm having a hard time trying to understand my Machinery's Handbook. banghead.gif
You must have a gage to check this with after you start cutting. I'd use that as a reference. But anyways the height of the thread is about .069. You of course realize that this is tapered 1 deg 47 minutes so the minor dia of 1.4876 only applies to the small end at the length of engagement. cheers.gif
Yes, we do have the mating part to to this. And, yes, I understnd about the taper. smile.gifsmile.gif
BTW.?
Is it easier to run an NPT thread insert or to single point thread mill? headscratch.gif
We are running this on a Mazak and using a single point mill and stepping out .01 each time til we achieve required fit.
Comp control is set to control.
Rookie 1,
Specs from ThreadTech program:
OSBORN PRODUCTS INC.
.............DATA FOR PIPE THREADS.............
................. 1 1/4-11.5 NPT ..............
Outside diameter of pipe....................... 1.6600
Threads per inch............................... 11.5
Decimal lead................................... 0.08696
P.D. at beginning of external thread (E0)...... 1.55713
Length of handtight engagement (L1)............ 0.4200
Number of threads engaged...................... 4.83
P.D. at length of handtight engagement and at
gaging notch or large end of internal thread(E1) 1.58338
Effective thread length of external thread (L2) 0.7068
Number of threads in effective thread length... 8.13
P.D. at effective thread length, external (E2). 1.60130
Length from handtight engagement to effective
thread length.................................. 0.2868
Number of threads from handtight engagement to
effective thread length........................ 3.30
Wrench makeup length for internal thread (L3).. 0.2609
No. of threads in makeup length for int. thd... 3
P.D. at makeup length for internal thread (E3). 1.54083
Vanish thread length........................... 0.3017
No. of threads in vanish thread length......... 3.47
Overall length of external thread.............. 1.0085
Nominal complete external thread length (L5)... 0.5329
P.D. at nominal complete ext. thread length(E5) 1.59043
Height of thread............................... 0.06957
Increase in diameter per thread advance........ 0.00543
Width of flat is...................from 0.0033 to 0.0073
Hope this helps.
