Radius output
MSL
57 minutes ago, MSL said:
Attached is a zip-2-go file.
Test Part.ZIP
I just tested with your files and changing dia_mult to 1 changed all the X values from Diameter to Radius.
modified post attached.
Code below.
ORIGNAL
O0010
(BUSHING)
(DATE=DD-MM-YY - 29-11-17 TIME=HH:MM - 15:59)
(MCX FILE - C:\USERS\ALEX.DALES\DESKTOP\OPEN POST MODS\EMC\TEST PART.MCAM)
(NC FILE - C:\USERS\ALEX.DALES\DOCUMENTS\MY MCAM2018\LATHE\NC\BUSHING.NC)
(MATERIAL - ALUMINUM MM - 2024)
G21
(TOOL - 1 OFFSET - 1)
(OD GROOVE CENTER - NARROW  INSERT - N151.2-185-20-5G)
(2MM BOTTON TOOL)
G28 U0. V0. W0.
G50 X250. Y0. Z250.
G00 T0101
G18
G97 S750 M3
G00 X18.268 Z-1.381
G99 G01 X16.268 F.5
G18 G2 X13.506 Z0. R1.381
X11.42 Z-.419 R1.508
X9.55 Z-2.608 R3.032
G1 X7.55 Z-2.609
G28 U0. V0. W0. M5
T0100
Changed
O0010
(BUSHING)
G21
(2MM BOTTON TOOL)
G28 U0. V0. W0.
G50 X125. Y0. Z250.
G00 T0101
G18
G97 S750 M3
G00 X9.134 Z-1.381
G99 G01 X8.134 F.5
G18 G2 X6.753 Z0. R1.381
X5.71 Z-.419 R1.508
X4.775 Z-2.608 R3.032
G1 X3.775 Z-2.609
G28 U0. V0. W0. M5
T0100
Generic Haas SL 4X MT_Lathe.zip
58 minutes ago, MSL said:
Thank you very much Alex and JParis for the help. Sorry my bad, I was outputting from wrong post.
I hate it when that happens!
Also note, if you happen to put a copy of the PST file in the same folder as your Mastercam File, and that PST file has the same name as the PST that is linked in the Machine Definition that is loaded in your Mastercam File, then Mastercam will grab the "Local" copy of the Post file, even though it "shows" the correct File Path in the Machine Group Properties. (I've been bit by that many times.)
If you are ever in doubt, as to "which Post" is being run, you can "override" the Post being used.
Press the "G1" button to Post the Operations. When the Post Processing Dialog Box pops-up, use CTRL + SHIFT + ALT + P. This will enable the "Select post" button, and you can override which Post is being used to output your NC Code "on-the-fly". Just ignore the warning message that pops up...
