machining vertical walls
gmenzies
if i pick multiple surfaces . with one surface being vertical . and use contour finish. mastercam has difficulty maching that surface with out jumping up and down.
if i pick the one vertical surface . mastercam will only machine it , if i use (edge settings) roll tool over all surfaces.
and then it works.
but when i select the rest of the surfaces,
mastercam jumps around.
any suggestions
level 3--- 7.2c
I had something like you describe, try tool center boundary. By the way I had a trouble with surface radial finish. I solved it with technical support from Mastercam.
They sent me latest patch for machining multisurface for Mastercam 7.2c
Ask them or I can share if you wish.
[This message has been edited by Jamie Mattison (edited 08-04-2000).]
ak762
i did get support from mastercam. what we discouver was a surface normal issue. when i
set my normals . the vertical walls pointed out. after dynamically selecting them .and reversing to the proper orienation . the tool path worked fine. we also increased the gap settings to 400%. i have all the latest patches.
regards
[This message has been edited by gmenzies (edited 08-04-2000).]
