Modifying Coolant setting
Hertz
Hey guys, I just had a quick question to mod a coolant setting. On the machine I have, M140 turns on an air blast and M141 turns it off. I am not on maintenance so I would like to try to get this to work without calling the dealer. I don't really need anything fancy. I just want to edit the M07 mist coolant to be M140 air blow instead in my coolant properties. Is this a simple process and if so, could someone lend me a hand to do it?
Hertz, very simple to do if using the X style coolant.
# Coolant output code selection for X style coolant
# Note: To enable X style coolant, click on the General Machine Parameters icon
#   in the Machine Definition Manager, Coolant tab, disable first check box
#   Output of X style coolant commands in this post is controlled by pcan, pcan1, & pcan2
scool50 : "M8"				 #Coolant 1 on value
scool51 : "M9"				 #Coolant 1 off value
scool52 : "M7"				 #Coolant 2 on value
scool53 : "M9"				 #Coolant 2 off value
scool54 : "M88"			    #Coolant 3 on value
scool55 : "M89"			    #Coolant 3 off value
scool56 : "M8(Coolant4=ON)"    #Coolant 4 on value
scool57 : "M9(Coolant4=OFF)"   #Coolant 4 off value
scool58 : "M8(Coolant5=ON)"    #Coolant 5 on value
scool59 : "M9(Coolant5=OFF)"   #Coolant 5 off value
scool60 : "M8(Coolant6=ON)"    #Coolant 6 on value
scool61 : "M9(Coolant6=OFF)"   #Coolant 6 off value
scool62 : "M8(Coolant7=ON)"    #Coolant 7 on value
scool63 : "M9(Coolant7=OFF)"   #Coolant 7 off value
scool64 : "M8(Coolant8=ON)"    #Coolant 8 on value
scool65 : "M9(Coolant8=OFF)"   #Coolant 8 off value
scool66 : "M8(Coolant9=ON)"    #Coolant 9 on value
scool67 : "M9(Coolant9=OFF)"   #Coolant 9 off value
scool68 : "M8(Coolant10=ON)"   #Coolant 10 on value
scool69 : "M9(Coolant10=OFF)"  #Coolant 10 off value
scoolantx : ""				 #Target string
fstrsel scool50 coolantx scoolantx 20 -1
Change the section below the M88, M89 or just change them. Will need to go into the Control Definition through the Machine Manager to have them come up with what you have changed.
If you are using the V9 style not an easy task so need to know what you are using to help you proceed forward.
