Files opening as Design Files
Snaglpuss
Just started using M2017.
I'm doing for instance "save some" then opening that file, it opens as a Design file and switches MC to Design instead of Mill.
As a workaround if I do a File - Save As, give it a different name, it will open as a Mill file then I wipe out what I don't want, PITA
I have start product set to Mill.
Never had this problem in any other previous versions.
Can I switch products with a drawing open so that I can turn the design file to Mill?
Never had to do it like this before????
Thanks for reading this.
Edit-
Just realized I can go Machine - Mill - Default and turn it to a Mill file but is there any way to just open as a Mill right away like it used to in previous versions?
  • Yes, more clicking around.
I don't get this new stuff, I haven't found anything in this yet were it makes me say" wow, cool, this is something I can use, or this saves a lot of time or any time.."
It seams like I have to click through more stuff to get were I want, before I had the icons I wanted on the screen and didn't have to click from tab to tab...
Thad,
The item you pointed to is semi-related. (R-08285)
It’s when dealing with importing (non-Mastercam) files.
I know that issue has been logged.
I don't know if the changes made for that issue# affects when we're talking about opening MCAM files.
I can check on that tomorrow with the people who kn​ow. (aka. not me :no)
There were changes in 2017 in regards to File-New.
When you open a file you’re essentially doing a File-New and then the file is opened.
File-New in this case no longer “forces” a Machine on you.
It sounds to me if you’re looking for...
If you open any file and it doesn’t already have a Machine (group),
it should add the default one of the  type you have specified in Config – Startup Product.
Only if the Startup Product is set to ‘Design’ would no Machine (group) get added.
Correct?
Yes, always open with your default product ( In my case Mill )
It was always like this as long as I remember.
As another person said many people are probably always running one product or machine and not starting
as a design product unless that's all they are paying for.
Also, what happened to Alt-U  undo?
Edit- I started digging around,it is now Cntrl-Z??
Where did that come from?
Changed it back to Alt-U
Correct?
Correct.
I could be wrong, but I believe it has functioned like that since the control/machine defs were introduced.
