Thread Higbee
  • Please log in to reply
12 replies to this topic
#1 Kevin Goddard
Kevin Goddard
    Member
  • Members
  • PipPip
  • 66 posts
Posted 16 October 2002 - 05:36 AM
Is the a method to higbee (blunt start) a stub acme thread in Mastercam? Been hand writing them and would like a better way if possible. Thanks in advance.
#2 McRae
McRae
    Advanced Member
  • Members
  • PipPipPip
  • 1,218 posts
Posted 16 October 2002 - 05:47 AM
Show me the code that you want so that I can see what a higbee is.  Anything is possible given enough time or money...
#3 kinglouie V
kinglouie V
    walking wounded
  • Members
  • PipPipPip
  • 1,875 posts
Posted 04 April 2008 - 03:49 AM
This has just come up for me and was wondering if anyone came up with anything? I have a formula that I can't remember what all of it means and I'd like to share for feed back. I am currently waiting for an install of MCX and writing by hand anyway. This formula calculates finish (vanish) point in "Z".
Z.1+Z(1)+MCC
DELTA RPM / PITCH / SERVO LAG CONSTANT = MCC
(NOTE: Z(1) "little one" is relative to tool tip.
I'm a little foggy on this one)
TIA
#4 Kevin Goddard
Kevin Goddard
    Member
  • Members
  • PipPip
  • 66 posts
Posted 04 April 2008 - 06:23 AM
I have not heard of a solution in Mastercam but I am not a poweruser post guru type. I higbee a lot of threads but I hand write em. I am sorry for the lack of help.
#5 kinglouie V
kinglouie V
    walking wounded
  • Members
  • PipPipPip
  • 1,875 posts
Posted 04 April 2008 - 07:27 AM
Kevin,
so how do calculate and do you comp the servo lag?
#6 Rick Henrickson The Boeing Co.
    Advanced Member
  • Members
  • PipPipPip
  • 1,531 posts
Posted 04 April 2008 - 07:56 AM
I use to use a thinbit less then the thickness of root, use the standard thread cyle move my ref in z out 1/2 the pitch and program 1 theard pitch deep.
#7 kinglouie V
kinglouie V
    walking wounded
  • Members
  • PipPipPip
  • 1,875 posts
Posted 04 April 2008 - 08:28 AM
we are told to cut them at a slower rpm usually at 100 rpm so that's why I'm calculating the servo lag.
(loss of pitch at encoder when speed changes)
the idea is to be a little gentle on the ball screws. no other reason I can think of.
#8 Rick Henrickson The Boeing Co.
    Advanced Member
  • Members
  • PipPipPip
  • 1,531 posts
Posted 04 April 2008 - 08:53 AM
Louie you are correct there I forgot to add you need to slow rpm way down.
The first time I tried was on a 3 start thread and I forgot to chande the rpm the insert did not like that much.
#9 nofalloff
nofalloff
    Member
  • Members
  • PipPip
  • 103 posts
Posted 04 April 2008 - 02:48 PM
Kevin,
I've done it, but it was like forever ago. The way I think I did it was to create a second threading op using a square face grooving or cutoff tool. The tool only ran the Z depth to blunt the first third of a revolution of thread which was in my case about .062. the key was to program the lead out with a .01 z component and a .1 X component this retracted the tool over where the actual thread is to begin. program it as threading so that you can easily cut the blunt in a number of passes so its clean.
#10 35K chipper
35K chipper
    Advanced Member
  • Members
  • PipPipPip
  • 599 posts
Posted 04 April 2008 - 03:33 PM
Kevin
seco tools had a program you could download for there thread mills that had the highbee option in it. worked well. have not used in years. i think its still on an old p3 computer.
35k
#11 kinglouie V
kinglouie V
    walking wounded
  • Members
  • PipPipPip
  • 1,875 posts
Posted 04 April 2008 - 05:11 PM
when I was a kid I used to cut them on a mill to prep the blanks for LoneStar gage. NOBODY I've ever worked for turned higbees for fear of tearing up the machine. By the end of the day I had the formula wired. TGIF!
when I have my notes in front of me I'll share for those interested and to save for search later in case I lose the thing.
cheers!
#12 nofalloff
nofalloff
    Member
  • Members
  • PipPip
  • 103 posts
Posted 04 April 2008 - 05:55 PM
I'm in the process of trying to mod a post to output threading correctly and in playing with it tonight i realized the Mastercam doesn't have a Z pull off component nor can you specify the pull off angle. I seem to remember programming that higbee in Gibbs actually. that would really have been along time ago.
suppose you could add it in manually. maybe it will be in X3?
#13 kinglouie V
kinglouie V
    walking wounded
  • Members
  • PipPipPip
  • 1,875 posts
Posted 04 April 2008 - 06:16 PM
that would be sweet.
