Okuma Hi2NC/Hi Nurbs
Mick
Does anyone here use the Hi2NC/Hi Nurbs option for surface machining on their Okuma verticals? I'm interested in what settings you use, as we haven't had a lot of success with it, and our local agent isn't very helpful.
When running large 3 axis surface toolpaths, the machine motion seems to be very slow, even with a programmed high feedrate. I'm interested to hear from any other Okuma users utilising this option, and what settings are being used.
Cheers
I agree with gcode here. If this option is similar to Nurbs of other machines/controls, you need the positions of the control points for this to function properly. I'm guessing that you cut a spline, posted it, and trying to run that code. The increments are tiny that way. And although the toolpaths may appear "correct", this is what is causing the slow feeds because the control is calculating the spline based upon the points in the program.
If you don't know the points, or you're generating from an existing file, then MC can create the points for you. First determine if the spline is parametric or nurbs. If nurbs, just go " create > points > Cpts Nurbs " and select the spline. If its parametric, then you'll have to convert first. Go " modify > x to nurbs " and select the spline. Now create the control points for a nurb spline.
MC will program a nurb spline if you have the control points. You can program by selecting the control points using "Contour" toolpath. Then for the selection use the "Point" method. You have to select "point" each time for each point though. Otherwise you end up going point then accidently selecting some other type of chain.
PS: if you knew this already, then just ignore me biggrin.gif
I apologise, I used the wrong description. Its the Hi2NC function I want to know about. Its the high speed "look ahead" function for contouring/surface toolpaths. My experience with it so far, is that the machine motion is smooth sometimes, and other times it pauses, or shudders. We're using the DNC/DT transmission option (ethernet) so it isn't a data flow issue.
35K Chipper,
We have two machines, a U100M, and a E100M. According to the machine manuals, the Hi2NC can be switched on at the control, or using G130/G131. We cant get it to work with G130/G131 (neither can another couple of companies locally using the same machine). When it is functioning (we have it switched on at the control), it shows it on the control, flashing a display (I cant remember the actual text it displays).
My question is, what settings do you use? when I was running a Matsuura with a Yasnac i80M, and HON/HOF high speed machining, we just switched it on, and we naver had a problem. With the Okuma, it seems to work some of the time. Since there are several settings on the parameter page, I'm curious to see what other users are using for settings, when machining 3D surfaces.
Mick,
Something like this in your post should do the trick
if mi8 = one, n,"G131 J0 E0.001 D0.0005 I0", *feed, "(SUPER NURBS ACCURACY SETTINGS)", e
if mi7 = one, n,"G131 J0 E0.005 D0.001 I0", *feed, "(SUPER NURBS HIGH SPEED SETTINGS)", e
So the Gcode is
Blah
Blah
G131 J0 E0.01 D0.001 I0 F8000
Blah
Blah
Works fine in my old companies Okuma
Mick,
there are two prameter pages in the control that need to be set.
the first page is what i call the fall back mode or G130 mode. this
is how your machine will respond if you do not call G131 in your or
G130 in your program. the values in my machine are as follows:
execution mode = 1
feedrate upper limit = 400 -IPM-
machine mode = 0
machining tolerance value = 0.0002
program tolerance value = 0.0001
utilization level of reconstructed shepe = 3
this fall back mode is the slowest and most precice.
the second prameter page has three colloms this is the G131 modes.
High Quality Standard High Speed
machining tolerance 0.0002 0.0003 0.0006
program tolerance 0.0001 0.0002 0.0004
utilize reconst. shape 3 1 0
max block length 0.400 0.600 0.800
min block length 0.005 0.010 0.020
program filter mode 0 0 0
filter value: length 0.0003 0.0005 0.0012
filter value: angle 5 7 10
now is the fun part. the snips from one of my Okuma posts shows 24 different
modes that are selectable from mi8. this allows you to change HiNC modes for any
operation -ex can cycles or rapids- to the mode that best fits this operation.
the modes 1-12 are from the 3 machining modes 0,1,2 and the 4 shape reconstruction
levels 0,1,2,3. the modes 13-24 are the same as 1-12 with the filter values turned on.
machining mode = J
shape reconstruction = I
finter mode = K
____________________________________________________________
"SUPER Hi-NC"
[misc reals]
1. "'X' STEP AMOUNT [ + - 0.0000 ]" -mr1-? 0.0
2. "'Y' STEP AMOUNT [ + - 0.0000 ]" -mr2-? 0.0
3. ""
4. ""
5. ""
6. ""
7. ""
8. "Stock, Blank, or Part Thickness"
9. "Stock, Blank, or Part Width"
10. "Stock, Blank, or Part Length"
[misc integers]
1. "Starting WCS [1= G15H1 40= G15H40,etc.]" -mi1-? 1
2. "Sub Reps for all tools [0 - 40 Reps Max]" -mi2-? 0
3. "Sub Rep from each tool = 1 All tools = 0" -mi3-? 0
4. "Stage tools for OK 7 or 8 = 1 No Stage = 0" -mi4-? 0
5. "Merge an EXT file [1= Merge 0= No Merge]" -mi5-? 0
6. "Work shift in X = 0 , Work shift in Y = 1" -mi6-? 0
7. "Total number of work shifts for this part" -mi7-? 0
8. "Super Hi-NC OK8 only [0= off 1-24 on]"
9. "Spindle face air blast [OK8 only 1= ON]"
10. "Part Type Selector [0 - 20]"
phincoff # Super Hi-NC off selector
if mi8 = 0, "", e
if mi8 = 1, "G130", e
if mi8 = 2, "G130", e
if mi8 = 3, "G130", e
if mi8 = 4, "G130", e
if mi8 = 5, "G130", e
if mi8 = 6, "G130", e
if mi8 = 7, "G130", e
if mi8 = 8, "G130", e
if mi8 = 9, "G130", e
if mi8 = 10, "G130", e
if mi8 = 11, "G130", e
if mi8 = 12, "G130", e
if mi8 = 13, "G130", e
if mi8 = 14, "G130", e
if mi8 = 15, "G130", e
if mi8 = 16, "G130", e
if mi8 = 17, "G130", e
if mi8 = 18, "G130", e
if mi8 = 19, "G130", e
if mi8 = 20, "G130", e
if mi8 = 21, "G130", e
if mi8 = 22, "G130", e
if mi8 = 23, "G130", e
if mi8 = 24, "G130", e
if mi8 - 24, "", e
phinc # Super Hi-NC output selector
if mi8 = 0, "", e
if mi8 - 0 & mi8 < 25, phinca, e
if mi8 - 24, "", e
phinca # Super Hi-NC Control Selector
if mi8 = 1, "G131J0I0", e
if mi8 = 2, "G131J1I0", e
if mi8 = 3, "G131J2I0", e
if mi8 = 4, "G131J0I1", e
if mi8 = 5, "G131J1I1", e
if mi8 = 6, "G131J2I1", e
if mi8 = 7, "G131J0I2", e
if mi8 = 8, "G131J1I2", e
if mi8 = 9, "G131J2I2", e
if mi8 = 10, "G131J0I3", e
if mi8 = 11, "G131J1I3", e
if mi8 = 12, "G131J2I3", e
if mi8 = 13, "G131J0I0K1", e
if mi8 = 14, "G131J1I0K1", e
if mi8 = 15, "G131J2I0K1", e
if mi8 = 16, "G131J0I1K1", e
if mi8 = 17, "G131J1I1K1", e
if mi8 = 18, "G131J2I1K1", e
if mi8 = 19, "G131J0I2K1", e
if mi8 = 20, "G131J1I2K1", e
if mi8 = 21, "G131J2I2K1", e
if mi8 = 22, "G131J0I3K1", e
if mi8 = 23, "G131J1I3K1", e
if mi8 = 24, "G131J2I3K1", e
pblow # Spindle nose blow
if mi9 = 1, "M121", e
pblowoff # Spindle nose blow off
if mi9 = 1, "M9", e
pheader # File header
spaces_sav=spaces
sextnc = ucase-sextnc-
spathnc = ucase-spathnc-
if mi5 = 1 & mi2 <- 0, q1
"$", progname, ".", sextnc, "%"
"-PROGRAM FILE NAME - ", progname, ".", sextnc, "-"
"-OPERATION - ", *progno, "-", e
spaces=0
"-PROGRAMMER - MIKE JONES-"
"-POST NAME - ", snamepst, "-"
"-DATE - ", *smonth, "-", *day, "-", "20", *year, " TIME - ", *time, "-"
spaces=spaces_sav
psof0 # Start of file for tool zero
psof
psof # Start of file for non-zero tool number
if tplnout = one, ttplane = wbuf-one,wc1-
ptravel
pwritbuf5
pinit
if metric = 1, pmetric
tooltotal = rbuf-4,0- #Reads total tools used #Index!
if toolcountn <= tooltotal, nexttool = rbuf-4,toolcountn-
else, nexttool = first_tool
if mi5 = 0 & mi2 <- 0 & mi7 <- 0, pprtoff, e
pparts
spaces=0
if output_z = yes, "-PGM Z MAX ", *z_tmax, "-"
if output_z = yes, "-PGM Z MIN ", *z_tmin, "-"
spaces=spaces_sav
subprg = yes # Open subprogram file? yes/no
subprogno = progno
tlnxt = mi4
dumsub = mi3
if dumsub = 0, numsub = mi2
if dumsub-0, numsub = mi2 # Store number of subprograms
mi1org = mi1 # Original mi1 value
mergeext
*sg00, *sgabsinc, "G80", "G40", "G17", "G94", e
prv_absinc = c9k
"N", *t, e
"IF [VATOL EQ ", *t, "] N", *next_tool, nna, e
pblow, e
"T", *t, "M6", e
pblowoff, e
"N", *next_tool, nna, e
ptoolcomm, e #Tool!
comment, e
spaces=0
if output_z = 1, preadbuf5
if output_z = 1, "-", "MAX ", *max_depth, "-"
if output_z = 1, "-", "MIN ", *min_depth, "-"
if tlnxt = 1 & next_tool <- 1, "/T", *next_tool, " -IS THE NEXT TOOL-"
spaces=spaces_sav
if tplnout = one, ptplane
startflg = one
nobrk_sav = nobrk
nobrk = one
pstock #Stock!
pindex #Index!
last_op_id = op_id
ptoolend # End for current tool
!coolant, !opcode
ptlchg0 # Null tool change
toolcount = toolcount + 1 #Index!
prvtp = rbuf-3,toolcountp- #Index!
if tlplnno <- prvtp, "G0G30P1"
if tlplnno <- prvtp, pindex #Index!
if opcode = three, ptlchg0drl
spaces=0
comment
spaces=spaces_sav
if op_id<-last_op_id, pstock #Stock!
speed
smcool
last_op_id = op_id
ptlchg # Tool change
if numsub-0, phincoff, e
if numsub-0, "RTS"
if numsub-0, " "
if numsub-0, " "
subout = 0
mi1 = mi1
if numsub-0, n = nsav
pcooloff, e
"G0G30P1M5", e
phincoff, e
"M1"
pinit
if numsub-0, " "
"N", t, e
"IF [VATOL EQ ", *t, "] N", *t, *next_tool, nna, e
pblow, e
"T", *t, "M6", e
pblowoff, e
"N", *t, *next_tool, nna, e
ptoolcomm #Tool!
comment, e
spaces=0
if output_z = 1, "-MAX ", *max_depth, "-"
if output_z = 1, "-MIN ", *min_depth, "-"
if tlnxt = 1 & toolcount <- 1, "/T", *next_tool, " -IS THE NEXT TOOL-"
spaces=spaces_sav
startflg = one
nobrk_sav = nobrk
nobrk = one
pstock #Stock!
pindex #Index!
last_op_id = op_id
peof0 # End of file for tool zero
peof
peof # End of file for non-zero tool
if numsub-0, "RTS"
if numsub-0, "%"
subout = 0
pcooloff, e
"G0G30P1M5"
phincoff, e
pblow, e
if tlnxt = 1 & toolcount <- 1, "/M6"
if tlnxt = 0 & toolcount <- 1, "T", *first_tool, "M6"
"G0Y9.0"
pblowoff, e
mi1 = mi1org
*sgwcs
"M2"
if numsub=0, "%"
if numsub-0, " "
if numsub-0, " "
mergesub
clearsub
Mick hope this is some help to you.
ps.
i plan to use mr4-10 to allow you to plugin other values ie F,E,D,L,R,P,Q
no time now with multi seates of X to get up and running.
35K Chipper
Thanks for your replies!
I need to investigate this further. From what I can tell, our control doesn't recognised the G130/G131, but the Hi2NC is engaged in, as you describe, "fallback mode". The trouble is, it seems to me, that it needs to set for wach machining operation, ie: I might be doing a suface finish contour toolpath, and the settings that work well for that, may not work for a surface finish scallop toolpath, using a different tool/parameters.
I take it there is no "generic" setting that works well for all contouring code (ie no rapids or cycles). If not, it looks like I need to experiement a bit frown.gif
mick,
we have a vertical and horizontal with the U100 control
try this in your program
G187 F600 E.003
this sets max. feed at 600ipm and cut tolerance at .003
G186
this cancels a G187 command and returns to parameter settings in control
when I run 3d I manually type this in my program to speed up movements and am still able to hold tolerances. if you go to parameters and set work tolerance from .0001 to .003 you will notice some difference when you interpolate dowel holes.
cant explain what super hi-cut option is or does but these commands work for us.
good luck,
david
mick,
you need to find ought what you have in your control. Hi2-NC G187/G186 or Super Hi-NC G131/G130.
i don't think you can have both in the same control . also do you have linear encoders on these machines? call Okuma with the serial number they can tell you what you have. they are very good with keeping track of what was purchased or what was added.
35k chipper
Mick,
I have an Okuma with Super Hi NC with dnc-dt and it works great for us. I don't know a lot about it because our Okuma service department set it all up and I haven't had to do a thing to it. I do know that there are 3 settings in the parameters. one for less quality- more speed, one for more quality less speed, and another in between. You might want to consider calling my Okuma guys they are top notch. Hartwig inc in St Louis Mo 314-426-5300 ask for Roger, he's head of service.
