huskermcdoogle
5ax DWO on Heidenhain TNC530i
Anyone know the details of doing Dynamic Work Offsets, or TCP/WSEC like behavior on a Heidenhain TNC530i control for mainly planar work?  Also would be nice to program in part coordinates, instead of from rotary center.  The books are clear as mud, and offer zero examples or explanation of such activity.  I'm not interested in a post for this at this time, but may be in the future.
What manuals are you looking at?  I've always found Heidenhain manuals to be excellent.
Anyway, you can define a plane in several ways.  The old way was cycle 19, but you should be using the PLANE function if it's available.  The PLANE function has several options for how to define a plane...
  • Spatial angles
  • Projection angles
  • Euler angles ZXZ
  • Two vectors
  • Three points
The plane function also allows you to specify other options...
  • SEQ + or -; this chooses the rotation solution
  • MOVE, TURN, STAY.  MOVE will move the rotary axes and the tool when the command is executed.  TURN will move only the rotary axes.  STAY will do the math but will not cause motion.  A retract can also be specified
  • TABLE ROT or COORD ROT; move the rotaries or move the coordinate system
The above lists are not exhaustive.
When I was an AE for Mikron spatial angles were the most popular.  If you have a BC machine, SPA would be 0, SPB would be the B-axis angle, and SPC would be the C-axis angle.
On the machine this works great, but in the post this involves some mapping/rotating because the two angles don't fully define a plane.  The code would look something like this...
 PLANE SPATIAL SPA+0 SPB-45 SPC+0 SEQ- TURN MBMAX FMAX TABLE ROT
So that says I want to define the plane by spatial angles(PLANE SPATIAL); set the B-axis at 45 degrees(SPA+0 SPB-45 SPC+0); choose the negative solution(SEQ-); move only the rotaries(TURN); before you move, retract along the tool axis to the limit switch(MBMAX); do everything at max feed rate(FMAX); rotate the table(TABLE ROT).
The above is from memory, it's best to build a few cycles at the control; it walks you through every step.  Heidenhain also offers a free simulator.
I personally like the two vectors method because Mastercam gives you the toolplane matrix.
Hope that helps.
I'm not sure I am being clear with what I am looking to do.  I want to eliminate a time sucking task our programmers have to do all the time due to tooling maintenance.  They are constantly reposting jobs with a different tooling gage/line, which suffice to say is nothing more than a shift value in the post.  The post has values associated with the machines rotary offsets, as well as the distance from the rotary center to the center of rotation and then spits out the program accordingly.
I'd like to eliminate that activity of reposting jobs if the fixture length change is say less than .25".  I have no problem redefining the method of which the parts programs are constructed using the post as they are output with macros, and looping for repeated features.  I'd like for the operator to just edit a header line variable of the fixture length and the program would run, likely verified by probing and limits set in a sub or internal label call.  Hence removing the need for the jobs to make two trips through the programming office unless they need a serious change.
  • Huh? 1
I believe I understand how the PLANE functions work, but it is possible for me to shift the entire program using them.  Also how or can you shift the coordinate system to a new local coordinate system? Such as you can with G68.2 on a Fanuc.
I have Vericut, but I have no idea what functions our digital machines support or don't support.   The machines are Hermle C600U and C30U.  I don't think it is out of the realm of possibility that both types of machines could use identical programs as well....  I say that because currently our programs posted between them are only different by coordinate shifts, otherwise structure and syntax are 100% the same.
Can I ask why you are programming for COR?  It seems that your issue would solve itself if you used the PLANE functions.
WESC is not something the 530 offers out of the box.  As you may or may not be aware you can not add a secondary axis (a or b) value in the preset table and have M128 or the PLANE function work.  I thought Hermle had a cycle 300-something to work around this but I was a Mikron guy.
Cycle 7 or TRANS DATUM if the machine is newer.
Our programs currently use Cycle 7 Datum Shift, I wonder if the Vericut just doesn't respect things properly, and or if the lack of plane function or M128 would be the reason.
They may, but I don't have access to any of the Hermle docs.
Thanks for the advise so far.  I will look into what things would look like if I were to use the PLANE functions to get the functionality we need.
Way before my time, this decision was made....  I'm just helping this plant out, being that it is one of our own, I have to be careful what I propose... Hence why I am asking for some guidance.
@mkd, You have some insight here?
Man... something ain't right. Reposting because of a tool length change... that's OLD school. I'd take a serious look at how programming is doing things. I'm no Heid/Siemens expert, but that just seems WAY off. I've got probably at least a half-dozen customers with Siemens and/or Heidenhein and they program all their machines the same way and NONE require a repost for a tool length change. EVER. Even on their Head/Head type machines.
So... they're not using tool length offsets?  That's insanity.  TBH, idk if I'd even know how not to use G43.  I guess I've been fortunate in all of my career.  All the way back to a Cincinnati pallet changer with Acramatic  (Vicker's) 2100e that even then had "rotate offsets" to track around the table on a hori.
I'll never understand why people aren't willing to try new methods.  Try it, worst case it doesn't work and you keep doing what you were.
I miss spoke, it's not tooling per say, it's the workholding.   Which happens to be tool holders most of the time...   Hence why i misspoke.  Believe me they aren't that far out of whack...
Don't have much to add on top of what Zaffin has stated, yeah they are way off.
Heidenhain is super simple to program and even simpler to setup. You barley even need to be thinking of 5axis anything, just don't run into the vise and dont run the head into the table.
 Plane spatial post output handles everything as far as tracking your probed xyz zero from center of rotation.
#300 cycles are reserved by HH for OEMs so they will b e different between Mikron and other lesser machines😂.
g49 g53
g92 x0y0
g92 z0
or
just zero the absolute page.
Bringing back the HBM with no tool changer days..
i'd like to hear more on this.
Post output, like siemans, only needs to vary insofar as outputting the rotary moves the machine actually has. *assuming your using plane commands*
 if you want to goof around manually to get a feel for plane spatial you can softkey to the 3D ROT screen and input rotation values there and activate them for a prog run or jogging or both.
 sounds to me that an investment into CAMplete would have a near immediate payback, so yes, wee feel your pain.
Not much more to it.  PLANE VECTOR requires two vectors defined by the values BX, BY, BZ (the base vector) and NX, NY, NZ (the normal vector).
The normal vector is the Z vector of the tool plane.  I can't remember, but I think the base vector is the X vector of the tool plane, but it could be the Y vector; it's been awhile.
Did I miss it or did you not mention what machine this is on?
if you are on a Heidenhain 530 or newer and are not using the plane commands and or M128 you are suffering needlessly.
By using these commands you can place the part anywhere (within reason) and probe it to set your part zero, then run.
You can adjust globally when using M128.
Attend adjust independently for each plane when using plane commands .
A machine with a 530 HH is capable of taking a program created on Mcam, where you don't need to know anything about the tool lengths or the distance from
 the part from the Centers of rotation .  You can position your part anywhere on your table and you will get an identical part every time with no reposting.
For that you need a post using the  PLANE or CYCLE 17 command for 3+2 work and M128 for 5-axis work.
Mastercam has finally created a Generic 5-axis post which you can try out before making any monetary decisions.  Programming a 5-axis machine using COR
can be a thing of the past...
Gracjan
