Sequence numbers at tool change
37 minutes ago, crazy^millman said:
Something has to define the pfn logic. In MPLMASTER there is this switch:
tseqno       : 2     #Output sequence number at toolchanges when omitseq = yes
                     #0=off, 1=seq numbers match toolchange number, 2=seq numbers match tool number
We then search the post to find where and how it was used:
ltlchg$          #Toolchange, lathe
. section not shown
. section not shown
. section not shown
. section not shown
      if not(synch_flg & tool_op$ = 67),     #Suppress tool output if cutoff during part xfer
        if omitseq$ = 1 & tseqno > 0,
          if tseqno = 2, n$ = t$
          pbld, *n$, [if home_type = -1, *sgcode], *toolno, e$
        else, pbld, n$, [if home_type = -1, *sgcode], *toolno, e$
mtlchg$          #Toolchange, mill
. section not shown
. section not shown
. section not shown
. section not shown
pheader$         #Start of file
      pheader_custom
      if tseqno = 1 & omitseq$ = 1,
        seqno$ = 1
        seqinc$ = 1
        n$ = seqno$
Then from there we can see what variables where defined and how we want to adapt it to the post we are using.
I am find  this in my post
# Motion NC output
ptool_insp      #Tool inspection point
      #Modify following lines to customize output for tool inspection points
      if posttype$ = two, #Lathe tool inspection point
        pcool_off #Coolant off before tool inspection
        pbld, n$, pnullstop, e$
        pbld, n$, scoolant, e$
        if prmcode$ = 29999, #Only output tool insp comment if one was entered with this insp point
          sparameter$ = ucase(sparameter$)
          pbld, n$, *sm00, sopen_prn, sparameter$, sclose_prn, e$
        else, pbld, n$, *sm00, "(INSPECT TOOL)", e$ #Output just the stop if no comment
        pbld, n$, *sgcode, *toolno, e$              #Restate tool number
        pbld, n$, pfsgplane,                        #Restate plane code
        if css_actv$, #Restart Spindle
          if css_start_rpm, prpm, pcssg50, pcss   #Direct RPM startup for programmed CSS
          else, pcssg50, pcss  #NO RPM start - just output the CSS
        else, prpm  #Direct RPM was programmed
        result = force(feed)           #Force output of feed next time it's called for output
        prv_gcode$ = c9k
        prv_workofs$ = c9k
        pinsp_cool_on #Coolant on after tool inspection
      else,#Mill tool inspection point
        pbld, n$, sm00,"(CAUTION POST GENERATING MOTION FOR TOOL INSPECTION)", e$
        pbld, n$, *sg28ref, "U0.", [if y_axis_mch, "V0."], "W0.", e$
        pbld, n$, sm00, "(INSPECT TOOL)", e$
        pbld, n$, pfsgplane, e$        #Restate plane code
        pspindle
        prpm #Restart Spindle
        pbld, n$, *sgcode, pwcs, pfxout, [if y_axis_mch, pfyout], pfzout, e$
prapidout       #Output to NC, linear movement - rapid
      if lathecc = zero,
        if millcc_flag & (abs(cuttype) = four | abs(cuttype) = two) & cutpos2$ = zero,  #Polar interpolation is active & Y-axis subs or Right face or Left face & before start point of operation geometry
          if abs(cuttype) = four,  #Y-axis substitution, output C first on separate line
            pcan1, pbld, n$, pexct, psgcode, pcout, e$
            pbld, n$, pexct, pxout, pyout, pzout, pscool, strcantext, e$
          else,  #Right or Left face cut, output Z last on separate line
            pcan1, pbld, n$, pexct, psgcode, pxout, pyout, pcout, pscool, strcantext, e$
            pbld, n$, pexct, psgcode, pzout, e$
        else,
          pcan1, pbld, n$, psgplane, pexct, psgcode, psccomp, pwcs, pxout, pyout,
          pzout, pcout, pscool, strcantext, e$
      else,  #Lathe canned turning cycle
        pcan1, pbld, n$, pexct, psgcode, psccomp, pxout, pyout, pzout, pcout, pscool, strcantext, e$
      if force_feed, result = force(feed)  # Force output of feed next time it's called for output
      if rpd_typ$ = 7, ptool_insp      #Tool inspection point
plinout         #Output to NC, linear movement - feed
      pcan1, pbld, n$, psgplane, sgfeed, pexct, psgcode, psccomp, pwcs, pxout,
        pyout, pzout, pcout, pfr, pscool, strcantext, e$
pcirout         #Output to NC, circular interpolation
      pcan1, pbld, n$, psgplane, sgfeed, pexct, psgcode, psccomp, pxout,
        pyout, pzout, pcout, parc, pfr, pscool, strcantext, e$
# Motion NC output
        prv_gcode$ = c9k
        prv_workofs$ = c9k
        pspindle
      if lathecc = zero,
        else,
That has nothing to do with what you're trying to accomplish. It will be in the toolchange logic for the lathe tools is only a lathe post. If it is a mill and lathe post combined then it will be in both sections like I showed in what I posted up. I suggest watching Colin's youtube videos on Post editing. You have many things to learn and understand about MP post and how the process works and what it does.
