Sequence numbers at tool change
I added this function to a MPMaster post several years ago.
In the General output settings section:
tseqno      : 3     #Output sequence number at toolchanges when omitseq = yes
                    #0=off, 1=seq numbers match toolchange number, 2=seq numbers match tool number, 3 = Mastercam Operations Manager Operation Number
in the pprameter$ postblock add:
           if prmcode$ = 15240, opmgr_opno = rpar(sparameter$,1)      #Operation number
Turn off "Output sequence numbers in the CD:
2 hours ago, Doug Funny said:
I was able to add the line but, when I went to post I get an error. do I need to define  opmgr_opno as a variable name?
Yes, I'm sorry. In the Misc strings section add:
opmgr_opno  : 0    #15240 - Operation number
You are actually adding a string, not a variable.
The added line initializes the string
Hi Tim,
I want the N numbers to be sequential regardless of the tool number and only at the tool change. So not a Guru has gotten me to the point where I get N numbers on my tool changes but, there seems to be a bit of logic missing because they are all the same number.
N1 TXX M6
N2 TXX M6
N3 TXX M6
Try this:
#declaration of variables:
blockno : 0 #Mastercam operation number
#format statement
fmt  "N" 4 blockno     #Output mcam opperation no. to NC file
#add this starting in a first column:
pfn             #Output block numbers = mcam op number
	  blockno = opinfo(15240,0)
	  if op_id$ <> prv_op_id$ & blockno<>-99999,
	    *blockno
#add this where the toolchange is:
pbld, *pfn, *t$, "M6",e$
1 hour ago, Doug Funny said:
Hi Tim,
N1 TXX M6
N2 TXX M6
N3 TXX M6
In the ptlchg_com postblock
After this line:
          if tseqno = 2, n$ = t$
Add this line:
      if tseqno = 3, n$ = opmgr_opno
EUREKA! Thank you sir! I've been a Camworks user for most of my career and only recently started using Mastercam. This forum is so much better than any I've found for camworks. There are a lot of incredibly smart and helpful people here. More often than not, I get answers here quicker than from tech support...
Glad I was able to help. Sorry it took so many tries, it was a long time ago that I modded that post and I'm getting senile. :)
  • 1 year later...
I wondering ,can use sequence number to my lathe post ?
something like this
(TOOL - 3 OFFSET - 3)
(RIGHT TURRET - 80 DEG.  INSERT - CNMG-432)
(CANED RGH OD)    -------------------------------------------------------     N1   (CANED RGH OD)
G0 T0303
M8
G97 S114 M03
G0 G54 X11.7
G0 Z.1707
G50 S1500
G96 S350
something like this
G0 T0303
M8
G97 S114 M03
G0 G54 X11.7
G0 Z.1707
G50 S1500
G96 S350
Sure. Need to decide how are going to sequence them and how you want the output to be controlled.
Just now, mirek1017 said:
I like to get N block every operation
I have mine set so N# follows T#
N1 (OD 80 DEG)
G18 G20 G40 G54 G80 G99
G00 G53 X0. Y0. T0
T101
G40 G54 G80 G99
M155
M08
G50 S3500
G96 S450 M03
G00 X2.1 Y0. Z0.01
M88
M05
M89
G00 G53 X0. Y0. T0
M01
N3 (OD 55 DEG)
G00 G53 X0. Y0. T0
T303
G40 G54 G80 G99
M08
G50 S3500
G96 S450 M03
G00 X1.5787 Y0. Z0.0072
M88
M05
M89
G00 G53 X0. Y0. T0
M01
N1 (OD 80 DEG)
G00 G53 X0. Y0. T0
T101
G40 G54 G80 G99
M155
M08
G50 S3500
G96 S450 M03
G00 X2.1 Y0. Z0.01
M88
M05
M89
G00 G53 X0. Y0. T0
M01
N3 (OD 55 DEG)
G00 G53 X0. Y0. T0
T303
G40 G54 G80 G99
M08
G50 S3500
G96 S450 M03
M88
M05
M89
G00 G53 X0. Y0. T0
M01
yes  something like this
30 minutes ago, mirek1017 said:
so this work the same way in lathe post ?
I can find this in my lathe post
Something has to define the pfn logic. In MPLMASTER there is this switch:
tseqno       : 2     #Output sequence number at toolchanges when omitseq = yes
We then search the post to find where and how it was used:
ltlchg$          #Toolchange, lathe
. section not shown
. section not shown
. section not shown
. section not shown
      if not(synch_flg & tool_op$ = 67),     #Suppress tool output if cutoff during part xfer
        if omitseq$ = 1 & tseqno > 0,
          pbld, *n$, [if home_type = -1, *sgcode], *toolno, e$
        else, pbld, n$, [if home_type = -1, *sgcode], *toolno, e$
mtlchg$          #Toolchange, mill
. section not shown
. section not shown
. section not shown
. section not shown
pheader$         #Start of file
      pheader_custom
      if tseqno = 1 & omitseq$ = 1,
        seqno$ = 1
        seqinc$ = 1
        n$ = seqno$
Then from there we can see what variables where defined and how we want to adapt it to the post we are using.
. section not shown
. section not shown
. section not shown
. section not shown
. section not shown
. section not shown
. section not shown
. section not shown
      pheader_custom
        seqno$ = 1
        seqinc$ = 1
        n$ = seqno$
I hope  I can get only .00001%  your  knowledge
