4th axis
TheePres
Yes it does here is what my MPMASTER is set up like for our HAAS machines.
# Typical Vertical
srotary "A" #Rotary axis prefix
vmc : 1 #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x : 1 #Default Rotary Axis Orientation, See ques. 164.
#0 = Off, 1 = About X, 2 = About Y, 3 = About Z
# Typical Horizontal
#srotary "B" #Rotary axis prefix
#vmc : 0 #0 = Horizontal Machine, 1 = Vertical Mill
#rot_on_x : 2 #Default Rotary Axis Orientation, See ques. 164.
# #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 0 #Axis signed dir, 0 = CW positive, 1 = CCW positive
ret_on_indx : 0 #Machine home retract on rotary index moves, (0 = no, 1 = yes)
index : 0 #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable : 5 #Degrees for each index step with indexing spindle
one_rev : 1 #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)
lock_codes : 0 #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes)
use_frinv : 1 #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
rot_feed : 1 #Use calculated rotary feed values, (0 = no, 1 = yes)
maxfrdeg : 2000 #Limit for feed in deg/min
maxfrinv : 999.99#Limit for feed inverse time
frc_cinit : 1 #Force C axis reset at toolchange
ctol : 225 #Tolerance in deg. before rev flag changes
ixtol : .01 #Tolerance in deg. for index error
frdegstp : 10 #Step limit for rotary feed in deg/min
Then I use the G154 P for fixture offset and that si doen by changing the PWCS to this:
pwcs            #G154+ coordinate setting at toolchange
if wcstype = two | wcstype > three,
sav_frc_wcs = force_wcs
if sub_level, force_wcs = zero
if sav_mi9 = 1, workofs = sav_workofs
if workofs < 0, workofs = 0
if workofs <> prv_workofs | (force_wcs & toolchng),
p_wcs = workofs
if p_wcs = 0, # This Will Output P1 is Work offset is 0
p_wcs = 1
"G154", *p_wcs
force_wcs = sav_frc_wcs
!workofs
Then I have also added this to my post Thanks to Rekd:
pcorner_round	#corner rounding ()
if mi5 = 1 & mr5 > 0 & flg_mi5 = 0,
sav_mr5 = mr5,
pbld, n, "G187", *sav_mr5, e
flg_mi5 = 1
if mi5 = 1 & mr5 = 0,
"( WARNING!! CORNER ROUNDING CONTROL HAS )", e
"( BEEN ENABLED WITHOUT A VALUE SET! USE )", e
"( MISC VALUES-MISC REALS TO SET A VALUE )", e
"( CORNER ROUNDING CONTROL IS DISABLED )", e
if mi5 = 0 & flg_mi5 = 1,
n, "G187", e
flg_mi5 = 0
I also have manunally index:
pindexman   #Manunal Indexing ()
if mi4 = 1,
sav_mr4 = mr4,
pbld, n, *sav_mr4, e
And then I have automatic program numbering if I dont have it done.
pheader         #Call before start of file
if met_tool = one, #Metric constants and variable adjustments
ltol = ltol_m
vtol = vtol_m
maxfeedpm = maxfeedpm_m
result = nwadrs(srotary, cabs)
result = nwadrs(srotary, cinc)
result = nwadrs(srotary, indx_out)
"%", e
spaces=0
if progno = 0,
progno = 10000
if mi6 = 0,
None of mine helping you get your post the way you want but you know we dont give away fully tweaked posts. Have a good night and hope that help. All information is given to help not hinder and use it at your own caution.
Gorn I like the MpMaster because it has alot more information to give to the operators than the others. I have also added other things to my post like a Mi6 control to strip all nc commnets out of the post for ethernet or right of the the hard drive running or programs on our HASS mills. I also thanks to Rekd have canned cycles in our post using the Drilling cycles. I think it really boils down to each person and what they like but I think that is a good post just some resaons why I like the MpMaster post and going from there.
