Custom Right Click Menu Chook
bryan314
  • Replies 166
  • Created
  • Last Reply
Top Posters In This Topic
Well.... I'm usig it here on an NT4.0 System and my system at home is XP Pro. I would imagine that if it works on those two platforms, it should work on 2k Pro.
:shrug:
James teh geek novice
Expanded screen middle click. You can now assign Gview dynamic, Gview pan, Gview zoom, or Zoom Window to screen middle clicks:
Middle-click
Shift-Middle-click
Ctrl-Middle-click
Shift-Ctrl-Middle-click
I have a suggestion, the user begins rotate/zoom/pan with MMB, is there a way to stop rotate with the middle-button again instead of LMB?
kwolf,
I did some behind-the-sceens-magic with the MMB and it's already biggrin.gif that way.
(shift/ctrl/whatever) MMB down and held-down starts gview dynamic, pan, etc.... Releasing the MMB (MMB up) exits.
For example my Shift-MMB is gview pan. I press the Shift and then press and hold the middle mouse button. I can than pan (drag) the part. When I release the middle mouse button...back to normal. Same for all four MMB 'actions'.
It's realy frickin cool. Your suggestion worked out nicely. Thanks.
I am having a problem with mmouse.dll. I am not getting the same menu as Rekd did on the 2nd post above. I am only getting the standard menu and the middle button only zoom in and out.
My System Configuration under the Start/Exit tab reads:
Startup NONE
Exit NONE
Default MMOUSE.DLL
What am I doing wrong?
Code_Breaker
Many Thanks for this Bryan. It's a very good ideea to use right click, and the middle click function it's also a very good ideea. I used dynamic pan for middlew click (Logitech mouse)since "94(an autolisp under Autocad12).
But I want to modify to have dynamic pan on middle click ..default.. not dynamic rotate.
How can I do this? It's possible?
Many thanks again.
