MPLOkuma.pst and G87 LAP cycle
Mick
Hi there,
I've been trialling MPLOKUMA.PST, so see how its LAP cycle output works. Whilst it looks like the format is pretty close to what I want, I can't get it to generate a G87 LAP finishing cycle at all. Even though I choose Canned Finishing as the toolpath, it doesn't output it.
Is anybody here successfully using it?
I'm running it in V9.1MR0304.
Cheers,
Mick,
Is this what you are looking for?
$T.MIN%
(PROGRAM NAME - T )
(DATE=DD-MM-YY - 09-07-04 TIME=HH:MM - 07:59 )
(TOOL - 1 OFFSET - 1 )
(LCAN_ROUGH OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432 )
G0X10.Z10.
T0101
G97S145M03M41
G0X5.268Z2.8158M08
G42X5.168Z2.7658
G50S3600
G96S200
NAT01G81
G0X-.7662Z2.7658
G1X.7526Z1.6115
X2.0949Z-.4159
X4.8793Z-1.0703
G3X4.9152Z-1.0972I-.0133K-.0283
G1G40X5.168Z-4.0604
G80
G85NAT01U.02W.01U.2F.01
G0Z2.7658
T010101
M09
G42X-.7662
G87NAT01
G0X0.Z5.
M05
M02
Mine runs fine using V9.1-MR0304
$L1234.MIN%
(DATE JUL -09 -04 )
(PROG. No. L1234 LB15)
(PART No. T REV. --)
(P/NAME CAP)
CLEAR
DEF WORK
PS RC,[0,0],[10,30]
END
DRAW
M1
( ROUGH/FINISH )
( 80DEG INSERT .016R )
N10 G40 G90 G95
G0 X40. Z40.
T0303 M86
G50 S1100
G96 S450 M03 M42
G0 X.75 Z1. M08
Z.1
G85 NAT12 U.02 W.005 D.2 F.004
NAT12 G81
G0 X-.016 Z.1
G1 Z0.
X.4819
G3 X.5158 Z-.007 K-.024
G1 X.5664 Z-.0323
G3 X.5806 Z-.0493 I-.0169 K-.017
G1 X.5805 Z-.0594
G3 X.594 Z-.0761 I-.0173 K-.0167
G1 Z-.2516
G3 X.625 Z-.274 I-.0085 K-.0224
G1 Z-.4
G80
G0 Z.1
( FINISH PASS )
X.75
G87 NAT12
G0 Z1.0
X40. Z40. T0 M09
M05
M1
M30
If you are using the "CANNED CYCLES" in Mastercam V9, you may have a small glitch when trying to use a canned lap rough and canned finish cycle. It is especially a problem if you choose the highlighted tool path on the second paramter page.
If you use a different tool for the finish, the post will sometimes throw the code for the finish cycle to a spot in the program that is after the M2 command. It was a real challenge to figure out what was happening.
If this has happened to anyone, just don't use the "canned finish". Choose a normal finish and rechain. It works like it should then.
Hmm...Well, mine doesn't output the G87 at all. It is indeed when I select the highlighted toolpath on the second parameter page. This post is potentially great, but it would be nice to be able to output it. Why would it work for some, and not for others (ugh, I know...software... smile.gif )
Anyway, I'd like to get to the bottom of it. I also note that the post supports G82 (facing). Has anyone generated the G82 using the canned cycles?
Heya Ron,
Thats correct. You dont have to set the Misc Reals etc (as in the old MPLOSP posts)
These new ones, using the Canned cycles, look to have the makings of great output for the OSP controls. I think (at least for my needs) they need a bit of refining )
Cheers
Mick
The new MPLOKUMA is a pretty good post but it does require SOME tweaking to get the clean code that I like personally. The post will output G82 but it doubles the DOC eek.gif for this cycle just like it does for the G81 [since DOC is diametric in the Okuma]. This is a [hack] mod that I made for this:
# Lathe canned cycle output
pg85 #Output G85 Bar Turning Cycle block
if gcodecc = 2, depthcc = depthcc * .5 # Modified for correct facing DOC (cdm)
pbld, n, *scclgcode, *fcc_NAT, *xstckcc, *zstckcc, *depthcc, pffr, e
I haven't tested this in every possible situation but it seems to work OK
C
Chris,
Hehehehe....Yes, we downunders do have a crazy time zone. Thing is, we're in the right time, and you guys are lagging....hehehehehhee smile.gif
DavidB: Thats true...They both need to have the same nose radius. But either way, I can make the post generate a G87 :/
The post is very close to the way I'd like to be able to output the LAP cycles. I really want a foolproof system for the guys at work :/
Cheers
Chris,
Yes, I did try the edit. It worked sweet. The bummer is, I still can't get it to generate a G87 :/
Why would it work for some MC installations, and not others? Is it the MP.DLL version?
Sorry about the delay in replying....I've been really busy :/
Cheers
