bullines..... i need help!!!
biss03
  • Replies 93
  • Created
  • Last Reply
Top Posters In This Topic
mAYDAY .
I had a exe once that killed the boot sector and made the hard drive virtually dead.
fOR THIS THINGS try this
boot From win 98 floppy disk
in prompt type
fdisk /MBR
(this is nonspecified inner Microsoft switch for Master boot record restoration )
Can be applied to any Win OS
WTHh
i'm still getting the trouble with updating the config files as stated in the original post. however, i've been able to get further into the reinstall and everytime it restarts it tries to update again and gets the same problem. it seems to be continuing with the reinstall but i'm not sure what effect not being able to update the config files will have. anyone have any ideas.
yes the floppy drive works. i used it to back up all her files.
by booting up do you mean putting it in the drive and then powering up the computer? if yes, then no. i've been unable to boot with the floppy. i've never been given the option with the A:> prompt. how do i get it? is there any other way?
In your BIOS, you must be sure that the floppy drive is your first boot device. Save your changes and reboot with the boot disk in the floppy drive.
If this doesn't work, you could try something a little sneaker. I'm assuming you have no problems booting from a CD. If that's the case, borrow a Windows 2000/XP CD from someone and boot off of that. Start the setup and when it gets to the point that you can format, format your drive with FAT (NTFS is unreadable by Windows 95/98/ME). When it's done formatting, but before it begins to copy files, reboot the computer and put your WinME CD in right away (removing the other CD first, of course). The ME installation should then find a cleanly formatted drive to install itself on.
I've never seen it not find a CD-ROM driver yet for any CD Drive. It's the only thing MS did 100%
I mentioned it b/c it happened to a friend of mine. He had an older Packard Bell PC and when he wanted to reinstall Windows after formatting the HD, it wouldn't recognize the CD-ROM drive at all! At the time, I downloaded a driver for him that he had to manually install in order to proceed but it set him back a bit of time. I can't recall now but it was some off-brand CD-ROM drive that came with the computer when he bought it. Anyway, it worked out in the end but I never forgot that experience. It's a beautiful thing when we can learn from the mistakes of OTHER PEOPLE! wink.gif
Man ,you kill me ,you said bfore that you do made boot from floppy .
Select teh legacy floppy drive in Bios settings as a first boot device !
Teh outcrier
Make sure you really have format.com file on floppy !
Type
a:
dir for*.*
to see if you really have it
You must see in reply something like
Format.com size ....
If you do not have it ,copy it from win98 computer
Or I can put it on ftp for a dos version you
really have
in prompt type command :
ver
put here the reply that dos makes
WTHH
