Mazak post help.
Bruce Caulley
I have a mazak post for a palatech system that outputs a feedrate on the line after a tapping cycle
 (M3 FORM TAP TOOL - 73)
N110G52X0Y0Z0
N112G0X-177.644Y95.128S2000M3
N114Z3.M8
N116G98G84Z-12.497R3.F.5
N118X-135.834Y119.372F1000.
N120X-177.644Y44.887
N122Y-5.113
N124Y-61.063
N126Y-108.462
How do I get rid of the feedrate? I thought I got around it when I altered a Makino post to output pitch insted of feedrate on the G84 line but lo and behold, the feedrate popped up on the next line again.
Any help appreciated.
Jimmy,
thanks for the reply. My post does not have a block called ptap2
It has the following
ptap #Canned Tap Cycle
pdrlcommonb
if istpi=0, pitch1=25.4/pitch1
pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
prdrlout, pitch1, strcantext, e
I think that the problem is somewhere else because if the pitch is a feedrate as per the makino post there is no problem. However if the pitch is the actual pitch then a feedrate is added after. It is as if the post must use a feedrate before it will move to a second point. I am wondering if it somewhere in the motion output section:-
 prapidout       #Output to NC of linear movement - rapid
pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, strcantext, scoolant, e
plinout #Output to NC of linear movement - feed
pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, feed, strcantext, scoolant, e
pcirout #Output to NC of circular interpolation
pcan1, pbld, n, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e
pcom_moveb #Common motion preparation routines, before
pxyzcout
ps_inc_calc
pncoutput #Movement output
pcom_moveb
comment
pcan
if cuttype = zero, ppos_cax_lin #Toolplane rotary positioning
if gcode = zero, prapidout
if gcode = one, plinout
if gcode > one & gcode < four, pcirout
if mr_rt_actv, #Restore absolute/incremental for G51/G68
absinc = sav_absinc
mr_rt_actv = zero
pcom_movea
pcom_movea #Common motion preparation routines, after
pcan2
pe_inc_calc
Bruce
Look for the ptap_2 block. It probably calls pdrill_2. So you will need to copy the contents of pdrill_2 to ptap_2 and the edit it from there.
This is from the mpmazakm post from the cd.
This is how it looks:
ptap_2 #Canned Tap Cycle
pdrill_2
Change it to something like this:
pdrlcommonb
pcan1, pbld, n, pxout, pyout, pzout, pcout, prdrlout, dwell,
strcantext, e
pcom_movea
