editing a solid
notso
I've got a parasolid that I've imported from UG and it turns out that I need to move a few holes around (threaded holes). When I try to select a hole to translate it (using "window tool") it doesn't move all of the geometry associated with the hole. Can any of you tell me what I'm doing wrong?
Hi Notso, AS robk said,
When you import a parasolid body in mastercam, it comes as dumb solid, i.e. there is no history tree. The arcs and lines created on the edge are not associated with the solid. If you want to move ahole in it do as follows.
Solid--»next menu--»form feature
select hole.
It will create new arcs at the edge of holes and extrude cut operation in history tree. These new arcs are now associated with the solid body. If you move them and then regenerate the solid it should change as per your requirement.
Good Day notso,
Do you have solids??
I dont think UG brings in history tree for solids.
You might be moving the edges and not the surface/
solid.
Tony G
CNCiT Precision Machine - Hudson,NH
X Beta Site
Almost Employed Senior Programmer
N.E Massachusetts - Southern New Hampshire
_________________________________________
End mills and tooling are like The "AMMO"
And coolant and chips are like the enemy
Under your boots as you advance in the
Manufacturing Battle
Good Eve,
You need solids add-on in order to edit a solid.
If you move the hole, you can still use that
geometry for chaining or a drill geometry.
The best way is to have the hole moved in UG
and then (Import parasolid and )use the good geometry.
Tony G
X Beta Site
You may have what they call a dumb solid. A dumb sold is still workable. Since you have the the edge curve it is still easy. use the edge curve and create a solid and add the body to close the whole. Move the geo into a new place with copy. Then cut another hole where the new one is.
jim
notso,
There are several things you can do with the solid, even as a "dumb body" imported from UG. medaq gives some good advice, as well as Steve Biehl, and others. An imported solid is just referred to as a "brick". You can still perform other solid features to this solid. For Mastercam to work properly with solids, you need good, closed 2-D geometry for adding to, or cutting, a solid body. Once the solid feature has been added, or cut, to the solid "brick", the geometry is associated with that feature. Move the geometry and regenerate the solid and you will have a new solid shape. That's the beauty of Solids. "Find Features" is just another way to generate solid features on a "brick" without doing it all manually. HTH cheers.gif
