add ptoolcomment to post
connormac
When I had some problems ya'll suggested that I run MPfan to see if it was a post problem or what. I noticed that MPfan had ptoolcomment that put in some cool stuff. Question is is it worth having. Do any of you use it. And how big of a pain would it be to get in my post's. I just can't leave stuff alone
Thanks for your input
Not a big PITA at all. Well worth it if you ask me. You can be as detailed as you want to be or just use a simple desc.
Here's my snippet...
ptoolcomment    #Comment for tool
tnote = t
toffnote = tloffno
tlngnote = tlngno
tldianote = tldia
"(", pstrtool, *tnote, *toffnote, *tlngnote, *tldianote, ")", e
Hi
T00L TABLE AT THE TOP OF PROGRAMS
fmt 12 day
fmt 12 year2
year2 = year + 2000
fmt TOOL- 3 tnote # Note format
then . . .
pheader # file name
progno, " (", progname, ")"
"( ", mon, " ", day, " ", year2, ")"
"(PROGRAM NO.", *progno, ")"
"(TOOLS)
Along with this:
# Tooltable Output
pwrtt # Write tool table, scans entire file, null tools are negative
tnote = t
strtool = ucase(strtool)
if t >= 0, "(", tnote, "-", strtool, ")"
if t >= 0, tcnt = tcnt + 1
Set the variable tooltable to yes (1) or add to variable if not there to enable the execution of pwrtt.
Here are two lines of code that will help.
bldnxtool : yes # Build next tool table
tooltable : 1 # Read for tool table and pwrtt
tcnt : 0 # Count the number of tool changes
Just to add soemthing to this guys if you want a little more information is over a netwrok you can add this to the post also:
"(MC9 FILE - ", smcpath, smcname, smcext, ")", e
"(PROGRAM LOCATION - ", spathnc, snamenc, sextnc, ")", e
This tells you where on the network the files was placed if doing DNC and also tells you where the MC9 file is also.
Results:
O1001 (204014_23300_SM1 )
( Apr 1 2004 )
(PROGRAM NO. O1001 )
(TOOLS)
( TOOL-1 - 5/8" ---GT SPOT DRILL )
( TOOL-2 - 5/16 ---GT DRILL )
( TOOL-3 - 11/32 FULLERTON 30812 BALL EM )
( TOOL-4 - 13/64 ---GT DRILL )
( TOOL-5 - 9/64 ---GT DRILL )
( TOOL-6 - 3/32 FULLERTON 30609 CEM 4-FLUTES )
( TOOL-7 - OSG HYPRO 45 DEG CHAMFER TOOL )
( TOOL-8 - 1/4-20 TAP )
Hi
Also could add
Example:
:0000 (258A4720NC)
(HOVIS- MACHINE CNC: HAAS VF-8/50 )
(MATERIAL -STEEL inch - 4140 - 400 BHN)
(POST - MPHAAS_VF8_3X_POST)
(DATE: 16-08-04)
(PROGRAM GENNERATED IN MASTERCAM vers_no 9.)
(PROGRAMER: DON S)
(STOCK SIZE: X20. Y20. Z.1 )
(STOCK ORIGIN: X0. Y0. Z0. At Center, Z at Top)
#Select stock orientation note
stk0 "At Center, Z at Top"
stk1 "Upper Left corner, Z at Top"
stk2 "Upper Right corner, Z at Top"
stk3 "Lower Right corner, Z at Top"
stk4 "Lower Left corner, Z at Top"
stk5 "Upper Left corner, Z at Bottom"
stk6 "Upper Right corner, Z at Bottom"
stk7 "Lower Right corner, Z at Bottom"
stk8 "Lower Left corner, Z at Bottom"
stknote
fstrsel stk0 stck_crnr stknote
fmt 12 day
fmt 12 year2
year2 = year + 2000
fmt X 11 stck_ht # X - Stock Height
fmt Y 11 stck_wdth # Y - Stock Width
fmt Z 11 stck_thck # Z - Stock Thickness
fmt X 2 stck_x # X origin of block
fmt Y 2 stck_y # Y origin of block
fmt Z 2 stck_z # Z origin of block
fmt 2 stck_crnr # Origin corner of stock
#at pheader
"(MATERIAL -", *stck_matl, ")", e
"(POST - ", spostname, ")", e
"(DATE: ", date,")", e
"(PROGRAM GENNERATED IN MASTERCAM ", *vers_no ,")", e
"(PROGRAMER: ", perg1, sperg1,")", e
"(STOCK SIZE: ", *stck_ht, " ", *stck_wdth, " ", *stck_thck, " ", ")", e
"(STOCK ORIGIN: ", *stck_x, " ", *stck_y, " ", *stck_z, " ", *stknote, ")", e
#Added
pstock_info # output stock information if requested
#End of added
