changing . NC to .H
rickcact1
guy, I did a search of "sextnc" and there was none found. I looked through the post one line at a time, and couldn't find anything about extention name, or .NC for that matter. Sorry to be asking about a post. I didn't think it was going to that type of question.
Iowajim, where should I add this line to my post.
Greg, I am trying to avoid having to change .nc to .h.
# General Output Settings
spaces : 1 #No. of spaces to add between fields
omitseq : no #Omit sequence no.
seqmax : 99999 #Max. sequence no.
arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype : 1 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
helix_arc : 2 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
maxrad : 999 #Maximum arc radius
breakarcs : 0 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
force_wcs : no #Force WCS output at every toolchange?
stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools
datum_style : 1 #Datum Shift style, 0=Tables, 1=Values
tooltable : 1 #Call 'pwrtt' for pre-processing of tooltable
cool_zmove : yes #Output coolant off with last move
maxfeedpm : 100 #Limit for feed in inch/min
maxfeedpm_m : 2540 #Limit for feed in mm/min
use_gear : 0 #Output gear selection code, 0=no, 1=yes
max_speed : 1600 #Maximum spindle speed
min_speed : 6.9 #Minimum spindle speed
zretr : 20 #Safety Z height - 0 for M92 style retract
drillret : 1 #Full clearance retract moves during drilling, 0=no, 1=yes
cycl32 : 0 #Output CYCL 32.0 tolerance cycle, 0=no, 1=yes
eobchar : 0 #End of block '*' character, 0=no, 1=yes
sm92 M #M92 retract string
sextnc H
# Rotary Axis Settings
Here is a section of my post showing where the .h extennsion is called out. HTH
