mpgen5x & vectors
MIL-TFP-41
I am hoping to work on a modification for the mpgen5x post to get it to post out vectors to control the tool axis. This is for a Siemens 840DI control. I need the vector output in order for 3d comp to be used (the siemens command is TRAORI). The vectors are output as A3, B3, C3.
guess I am wondering if mpgen5x will support this kind of output.
Thanks!
Here is what they cover in the post Documation:
4- or 5-axis vector variables
􀂋 mill5
􀂋 vtoolx, vtooly and vtoolz
mill5 set to 1 or 2 defines a 5-axis toolpath. Vectors must be in the plane that is being resolved. This is
not a function of the post executable but relies on the set up being correct when the toolpath is
generated.
With either 5-axis positioning or 4-axis positioning, the post customization file uses vtoolx, vtooly and
vtoolz as the tool direction to resolve the angles.
This is a very basic description and the reader should refer to Volume 3, Numeric Variables for the
variable information and also to the MPFAN.PST.
Then there is this:
Swarf5ax Nci parameters:
12177 Floor normal X vector
12178 Floor normal Y vector
12179 Floor normal Z vector
Curve5ax Nci parameters:
12251 Tool axis plane X vector
12252 Tool axis plane Y vector
12253 Tool axis plane Z vector
Drill5ax Nci parameters:
12054 Tool axis plane X vector
12055 Tool axis plane Y vector
12056 Tool axis plane Z vector
That is a few I found not real tiem to help but this is also from the post CD. I recommend you call your dealer and get it from them if you are going to tackle this post yourself.
