Please help with cavity
cadmonster66
Ladies and Gentlemen I posted a file called TEST CAVITY to the ftp i need some help with it.
The rough was no problem but i need a finish path other than the parallel one.
The finish tool i have is a 1.5 dia. insert Ball endmill and i just cann't get the tool to do a radial or scallop tool path form the top to the bottom ( that is the way i would like to machine the cavity )
please help thanks
John
Hi
Because there is . 377 radii in one area of the cavity.---------------
Try a 3/4 four flt finish ball,pocket spiral inside to outside .005 x,y steps with a half dozen finish passes at .002 ,and post.
Project onto your exisitng surfs ,this will give you a useable result.
No draft ?
I know that 4.750 is a little long for a 3/4 ball, so use the four flt because it is a little more rigid.
Cadmonster,
Please tell me this is what you want, using a 1.5 ball.
Please look at this Picture link here .
If this what you want i can put this file with this path back on my FTP.
this is scallop using the 1.5 ball at this time with a .05 step over,Started from the top down.
[ 10-11-2001: Message edited by: cadcam ]
Hi cadmonster,
Just so you know it does go to the bottom.
I stoped to get the picture so ther was know dought that it started from the top and goes down.
Cadmonster this will be MC8 so hope you are running that.
Hi
Good Morning
Jay's way is answering your question .
"( that is the way I would like to machine the cavity )"
I'm only telling you what I do for this kind of cavity. On the .377 rad question I looked at the part ,and visually noticed that some radii were to small for a 1.500 dia. ball mill and proceeded to find out what size they were. Here is what I did.
put cplane in 3-d,create,curve,one edge,---create ,point along entity =3= ------------
create, arc,3 points,points pick the points. analyze only arcs.-------------------------
Use the same way to create the pocket geometry. But for simple flat pocket geometry I put Cplane: T
